Question about Five Star TTN-331-7SW Gas Range
Converted to propane,oven burner keeps burning at the orfice ,adjusted air and orfice to no avail
    Sergeant:
    Champion:
  • 289 Answers
Safty valve is not closeing.did you convert the regulater.
Posted on Nov 19, 2009
The wall behind my propane oven is black, why?
possibly the air shutters were not adjusted when new for propane use,most units come set-up to burl natural gas but need conversion to burn l.p. gas by changing the orfices on the top burners,then turning the orfice spuds down on the bake and broil orfices as to control the flow of a heavier gas and also opening the air shutters on these venturi gas feed tubes next to these orfices
Dec 12, 2012 | Kenmore Ovens
Can you sucessfully convert a Dayton Model 3E368C,
The orifices have to be made smaller for propane. You have to go 10 drill bit sizes smaller. Also the air gap on them burners has to be tweaked. Primary air is added to the lp at the orifice. The gas/air mix has to be close or the nasty yellow smutty stuff happens. The gas valve needs to be set for LP gas pressure and the pilot orifices need to be changed. Nothing to it old man.
Dec 26, 2009 | Dayton (3E386) Heater
We have a gas whirlpol that was converted to
on the gas valve there is a orfice a pin hole you can ajust the size of the orfice by tighting the ajustment a little a 1/4 turn . it is on the valve where the gas gos out to the bunner usualy a 1/2 in open wrench fits on it its made of brass you have to open the top to see it there is also a air ajustment where the bunner fits over the gas valve orfice if the flame is red open it more if its to hot close the air a little make the flame red then turn the gas down tell its blue agin
Oct 20, 2009 | Whirlpool Ovens
How do i change from lp gas to natural gas on wall oven
First thing you will need to do is find out from the manufacturer of the oven if there is a conversion kit available and if the appliance is convertable. If there is then you can order the kit and follow the installation instructions. Also check the back of the oven for an envelope that may contain the gas orfice replacement heads to convert the appliance to natural gas. If you find the replacement orfice then you will need to remove the lp orfice from the burner and install the natural one. Then the appliance gas regulator will need to have the pressure adjusted lower for natural gas. There is usually a removable cap on top of the regulator on the oven. When you remove this cap there is usually a small metal ring that you can remove and flip over. It will say "nat" on one side and "lp" on the other. You will need to turn this ring over and re-insert so it displays "nat". This will change the gas pressure from 13 inches W.C. to 4 inches W.C. Some appliances only require the orfice change and no regulator adjustment but make sure that is the case with your oven because if you feed 13 inches W.C. pressure to a burner with a natural gas orfice...YOU WILL GET A HUGE BURNER FLAME AND MAY BURN/FLASH YOURSELF...So use extreme caution when converting a gas appliance. And if the oven has a pilot you will need to adjust the pilot pressure or change it's orfice if it has one. If it is electronic ignition no adjustment to that will be needed. Also unplug the electrical power the the unit while working on it.
Oct 11, 2009 | Ovens
Propane stove burns yellow & creates soot
clean the orfices and tubes and then if possible adjust your air mixture setting also
Sep 21, 2009 | Frigidaire FGB24S5A Gas Single Oven
Ge propane kitchen range changed to natural gas.can't get the ove
Hi, Did you flip the cap on top of the regulator? As far as adjusting the bake/broil orfices, all you will nee to do is turn them 2 full turns counter clockwise. Start the oven and watch the flame. It should have blue tips as much as possible.
You might have to raise or lower the orfice adjustment as needed.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
How do you adjust flow regulator in gas oven
how do I adjust my regulator on a gas range
Dec 02, 2008 | Kitchen Ranges
GAS RANGE
Msmaytag it sounds like the oven wasn't converted properly if at all to propane. If you look at the bake burner while the oven is on you should see very little yellow on the flame. If you see mostly yellow, try adjusting the air to more open. This will changed the air/fuel and may resolve the issue. If not, follow the directions for converting to propane and see if the orfice hood was either replaced or tightened down. I am not quite as familiar with the maytag is why I ask you to follow the directions. The issue with propane is that it runs at 10wc instead of the 5wc of natural gas. So double the pressure, you need more air to thin the fuel. Hope this helps.
Jun 13, 2008 | Kitchen Ranges
GE XL44 and soot from burners
propane burns very dirty.you need to remove the burners and orfices and clean them good with oven cleaner.make sure their rinsed and dried well before installing,this should solve your problem.
Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Five Star TTN-331-7SW Gas Range Logo
65 people viewed this question
Top Five Star Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ray gallant
Are you a Five Star Kitchen Range Expert? Answer questions, earn points and help others
