Question about Fellowes DM15C Shredder
Shredding paper and it just stopped. Light is on and the teeth look clear
  • 71 Answers
My shredder stops if it gets too warm. It will run OK once it cools off.
Posted on Nov 19, 2009
My omnitech shredder is jammed by excessive paper. I've cleared all the paper strips that I can see and I also spray some oil to its shredding teeth. But it is still jammed. Thanks in advance!
You have to expose the shredding mechanism and remove all embedded material bit by bit. Oiling is not recommended maintenance and won't help prevent clogging.
May 07, 2017 | The Office Equipment & Supplies
My shredder won't shred
If the motor will not run, then probably there's paper clogged in the shredder. Turn over the shredder, after unplugging the power cord, and remove the papers.
If the motor will run but not shredding any paper, then the drive gear has broken teeth. This is not usually worth fixing.
Hope this helps.
Mar 27, 2015 | Shredder Office Equipment & Supplies
Royal 85x paper shredder: The shredder will start to shred but stops shortly after "grabbing" the paper. In order to get it shredding again, I have to put the machine in reverse, remove the...
Sometimes spraying shredder oil on the cutting teeth wil work.
You should shred paper with a light weight machine oil poured on the paper to keep the cutting teeth working freely.
Good luck.
P.S. If this doesn't work then just take the head off and cleanj/lubricate any bearings you find.
Mar 23, 2011 | Royal 85X Shredder
I tried to put too many sheets through the shredder at one time and it stopped working. I tried switching it to reverse, but it wouldn't move. I unplugged the shredder, pulled out the sheets, and cleared...
Try removing the shredder and unscrew it from the base. Using a small screwdriver, advance the teeth one row at a time to remove unseen clots of paper around the wheel, then brush with graphite for lubrication.
Aug 16, 2010 | Compucessory CCS60061 Shredder
Shredder will not start when paper is inserted. switch is on auto. This happened after a long session of shredding
Two possible problems;
  1. Teeth underneath lid are jammed; sometimes (especially after a long session) although the papers go through, debris builds up and can get caught in the teeth; to clear unplug and with tweezers or a tina flathead screwdriver, pull out shreds of paper still caught
  2. Motor is overheated; once cool, try it again (move switch to reverse to see if motor is still working). If motor is working, see Step 1 for a jam; some jams can be cleared by running it in reverse. Royal doesn't recommend "long" shredding sessions. My unit recommends sessions of 20 pages or less. If you try to overwork the shredder, it will overheat and in some cases, fry the motor.
I hope this helps answer your problem. Best of luck!
Greg
Nov 12, 2009 | Royal 10X Shredder
Staples spl-710sh paper shredder stopped shredding
This exact thing has happened to my unit as well. Ive disassembled it to discover that 5-7 teeth on the gear that the motor drives have been stripped off. Unless the gear can be replaced (which is probably not worth the expense), then the unit is toast. Sorry. Good luck.
Jun 16, 2009 | Office Equipment & Supplies
Shredder stops in the middle of shredding and won't shred.
Is the paper bin full?....mine always shuts down when the paper bin is a little over half full.
Jan 21, 2008 | Fellowes 220 Powershred Strip-Cut Shredder...
Wont stop running
The auto switch is stuck. Feed more paper in it to clear it, and kick once for me. The shredder has a paper jam. You can try 3 or more sheets at one time to clear it. Also try 'paper shred oil'. You can buy it at Office Depot or Office Max.
Jul 06, 2007 | Office Depot Ativa DQ60M Shredder
My shredder keeps running and won't stop in on/auto mode
Does the shredder have the electronic eye to sense paper? Sometimes dust will collect on the sensor causing it to keep running.
Apr 07, 2007 | Tech Solution TS-4500 Shredder
Fellowes DM15C Shredder Logo
188 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
