Question about GE Monogram® ZET3038 Dual Single Oven
How do I access the door handle mounting screws on a ge monogram
How do I access the door handle on a ge monogram ZET3038 built-in oven. One side of the door handle is becoming loose.
5 Suggested Answers
  • 116 Answers
SOURCE: ge monogram single convection wall oven
There is usually a micro switch that is activated when the lock lever is in place - very likely this switch is still activated or has failed closed (defective) .
Posted on Aug 31, 2008
  • 384 Answers
SOURCE: GE Advantium SCA1000DBB03 handle replacement
open door look at side there some are some screws remove them the outer door part will come off now don t be afraid to use screwdriver to help take it off good luck later
Posted on Apr 02, 2009
  • 189 Answers
SOURCE: GE Monogram Trivection - self-clean cycle with oven racks in
Hello- First off, do not use 'self clean', or as most Techs call it: "Self- Destruct".  This 'feature' cheerfully sold by the salesman destroys more oven and range components than any other failure. Now- the racks had a thin layer of grease on them when the oven tried to turn stuff inside the oven to ash.  The grease is now a hard rubbery coating on the surface of the rack.  To solve this problem, you must determine by observation, where the rack touches the sides of the oven. These contact areas need to be cleaned thoroughly with scotchbrite and a small portion of oven cleaner. Make sure you use gloves. Sliding rack in and out to 'mark' these small spots works pretty good.  Once cleaned and wiped down, they should work fine. I recommend cleaning by removing as much 'stuff' by scraping and wiping down with moist cloth.  Turn on to 450deg for 30 min.  Much safer, less costly.                                                       Please acknowledge this posted solution if helpful.  Have more info if needed-  Thanks  -Ed
Posted on Mar 24, 2010
SOURCE: My GE ZET3038 Trivection Oven is completely dead.
I know the problem of my oven triton ZET3038 is the main logic board. Where can I by the piece?
Posted on Dec 04, 2010
GE monogram double oven . Self cleaning top oven and F9 in red showing and beeping noise
F9 is a problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, it's probably a problem with the lock mechanism.
A common problem on many built-in GE ovens (you don't say if yours is built-in or free standing...) is air circulation in the control panel. The fan that keeps the panel cool either stops working or gets clogged with dirt/dust and can't move any air. This causes the panel to overheat and can cause all kinds of odd problems and error codes. If you have a built-in, check to make sure the fan is working and the mesh screen behind it is clean.
Jul 17, 2016 | GE Monogram ZET3058SHSS Stainless Steel...
How to tighten loose handle
Remove the door gasket, that should give you access to removing door plate. Door handle may need to be replaced.
Oct 26, 2013 | Combi Steamer electric built in steam...
Oven displays "Supply Open Neutral" What does
I got this problem on my GE Trivection oven after a 2 minute blackout. "Supply Open Neutral" showed up and no other buttons worked. I shut off the breaker to the oven from outside and it still didn't work. I then turned the breaker off of the other appliances in the kitchen and turned the Trivection oven breaker on first and then it worked. I don't know if it was the order or whether I just turned it off for a longer period of time, but the oven started working normal again.
Nov 29, 2010 | GE Monogram® ZET3038 Dual Single Oven
It won't get to temp, then it beeps and it says f9...it continues to beep, and inside light is off
Disconnect power to the oven.
Open the oven door. Remove three screws from underneath the oven's control panel. Lift the control panel straight up to disengage the mounting pins on the top corners of the panel, then tip the panel toward you.
Inspect the door lock mechanism. The mechanism is in the lower left area of the space behind the control panel. Rotate the cam on the door lock mechanism to be certain it moves without binding. Replace the mechanism if its mechanical parts do not function properly.
Inspect the wires that connect the door lock mechanism to the control panel. Check for pinched or broken wires. Check for wires with frayed insulation. Repair wires as needed if defects are present.
Locate the six-pin connector on the door lock motor on the right end of the door lock mechanism.
Rotate the cam on the door lock mechanism to the unlocked position. Test the resistance between Pin 3 and Pin 1 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 2 of the door lock mechanism if the resistance reads other than 0.
Rotate the cam on the door lock mechanism to the locked position. Test the resistance between Pin 3 and Pin 2 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 1 of the door lock mechanism if the resistance reads other than 0.
Contact a certified GE appliance repair facility if the source of the F9 code has not been discovered. Troubleshooting the oven with the electric power turned on is a job for a certified technician.
Mar 05, 2010 | GE Monogram® ZET3038 Dual Single Oven
Door won't close properly
Very common problem, when door is not closing all the way. You need to pull it out a few inches and readjust hinges on each side.
Ge monogram oven repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | GE Monogram® ZET1038 Single Oven
Oven light doesnot turn off
HI, This will be a simple fix here. The light switch will be the culprit. The circuit is damaged, thus, allowing for a continuously closed circuit. Simply replacing the switch will solve this issue. The switch should be mounted on the control panel. remove the control panel front trim screws, to access the switch housing.
Nov 22, 2009 | GE Monogram ZET3058SHSS Stainless Steel...
My GE ZET3038 Trivection Oven is completely dead. Checked 240 at the oven but nothing from there. Any tips?
Jul 09, 2009 | GE Ovens
New Wall Oven wiring
on a 220v unit you dont use the 110 ,,, connect the red and black as power and the white as ground / larry
Dec 12, 2008 | GE Monogram® ZET3038 Dual Single Oven
Oven mystery....need the best GURU or Wiz....CHALLENGE! Please help!!!
was the thermistor that connects to the heat board replaced?this is the bulb inside the oven that monitors the heat,it should have 2 wires going to the board.try wiggling these wires and see if it starts to heat,if so the thermistor is bad.
Jan 06, 2008 | GE Monogram® ZET3038 Dual Single Oven
GE Monogram® ZET3038 Dual Single Oven Logo
178 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
