Question about Apple iPhone Smartphone
My iphone will not turn on. What can I do?
MY IPHONE DIED AND NOW WONT TURN BACK ON
First check to make sure your charger is working, plug it up to the computer and see if the battery charging display comes up.
Second I would check to make sure the battery is actually charging.
Third try a cold boot, hold the power and home keys down while it boots it could just simply be locked up.
Jan 09, 2013 | Apple iPhone4 4G iPhone 4
My iphone 3 wont turn on
Connect it to iTunes, you might need to activate it, or restore it.
that's all that means. There's no verifiable OS active on the phone
Nov 12, 2011 | Apple iPhone Smartphone
My iphone 3gs shut off and won't turn on... tried rebooting it but saw nothing. How long should I hold the "Home" button and the "Power" button?? If this doesn't work, what should I do??Please help...
If something isn't working right, restarting, force quitting an application, or resetting
iPhone will likely solve the problem.
Restart iPhone: Press and hold the Sleep/Wake button until the red slider appears.
Slide your finger across the slider to turn off iPhone. To turn iPhone back on, press and
hold the Sleep/Wake until the Apple logo appears.
If you can't turn off iPhone or if the problem continues, you may need to reset. A reset
should be done only if turning iPhone off and on doesn't resolve the problem.
Force quit an application: Press and hold the Sleep/Wake button on top of iPhone
for a few seconds until a red slider appears, and then press and hold the Home button
until the application quits.
Reset iPhone: Press and hold the Sleep/Wake button and the Home button at the
same time for at least ten seconds, until the Apple logo appears.
Oct 06, 2010 | Apple iPhone 3G
My phone is locked up and wont turn off. how do i turn it off to reset?
Oct 05, 2010 | Apple iPhone 3G
I just installed a jvc kd g825 and i have a iphone 4 when i plug it in it says reading file and starts charging my iphone but wont play any thing any solutions?
I had a similar problem after I updated my iPhone 3g's software to 4.0.1. I read that if you turn off your iPhone, then with your car/stereo turned off, plug in your iPhone. Now turn on the car/stereo which will turn on your iPhone automatically and "re-initialize" the relationship with the iPhone. This worked for me. Hope this helps. If not, check the Apple forums.
Aug 11, 2010 | JVC KD-G820 CD Player
Iphone
You can restore your iPhone if you don't know the passcode this can be done by :
  1. While your iPhone is turned on connect it to iTunes via USB cable
  2. Once iTunes has recognised the iPhone turn your iPhone off and DO NOT disconnect it.
  3. Turn your iPhone on while pressing the home key
  4. When the Apple Logo appears let go of the power key but keep pressing the home key until the screen goes blank
  5. This will put your iPhone in recovery mode and your PC will recognise it as "iPhone DFU mode"
  6. Once this happens go back to iTunes and you will have the option of restoring your iPhone.
Aug 30, 2009 | Apple iPhone Smartphone
My iphone won't charge or turn on and its just at a black screen
Hold the on-off button and home buttons together for 5 sec as the iphone is connected to a charger, then release both buttons. Then press the on-button. The iphone should now turn on if it was just frozen. If not, you may have a hardware issue. There is an iPhone Repair Guide that shows how to open an iphone and replacement parts are available on Ebay.
Apr 03, 2009 | Apple iPhone Smartphone
My iphone turns on automatically
UNLOCK YOUR IPHONE FOR ONLY $19 WE CAN UNLOCK IPHONE 3G 3GS 2G, EASY STEP BY STEP TUTORIAL VISIT US AT WWW.UNLOCK-IPHONE.ORG
Mar 29, 2009 | Eforcity Orange Textured Silicone Skin...
Restoring iPhone
Hi. My 2G iphone was connected to Itunes and it was accidently disconnected...now the screen is showing a UBB cord with an arrow pointing towards the Itunes logo. can you help?
Oct 05, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
114 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
