Question about HP Vs17 17" LCD Flat Panel Monitor
My speakers on my monitor are not playing any sound at all i checked all the sound menus in the control panel but still have no success
  • 115 Answers
Pls check that the sound card is enable or not in the system BIOS ,if not pls enable it .and check it ,if still not working pls check the audio cable from monitor to CPU its properly connected and check .if still issue then replace the audio cable with goods one .if still issue then check the sound driver and re-install.if every thing ok then issue with your sound card .call vendor for repair.
Posted on Nov 19, 2009
I want to make my monitor speakers play sound
Make sure that you have the cable plugged into the monitor and going to the computer if there is one. Some older model monitors operated that way.
Click Start/Control Panel and check your Audio/Sound properties to make sure the drivers are ok. Look for either sound or audio or device manager under the control panel.
Does the sound work for external speakers? Does the sound work for a headphone? Did the computer and monitor come together when you purchased it?
Mar 24, 2012 | HP Computers & Internet
Sound not playing correctly via the speakers on the monitor Back ground music but no voice
sounds to me like you may have the monitor speakers connected to the wrong port. It typically connects to the computers Green speaker jack. If it is connected properly, look in the control panel for audio/ speaker properties, change the speaker configuration to stereo speakers, instead of 5.1 speakers. you are likely hearing the rear channel of 5 speaker setup at the moment.
Aug 29, 2010 | NEC MultiSync LCD1735NXM (Silver, Grey)...
When I plug the speakers into my computer they do not play the sound. I have windows 7 64 bit. The computer says there is sound but none plays through my speakers
You'll have to got into your control panel, audio sound devices and set them. It will mean drilling down through the menus, have a dig and a good look, you should be able to set them to your needs.
Also, ensure your audio drivers are up to date.
Jul 16, 2010 | Computers & Internet
No sound, checked control panel, all shows the
No sound, checked control panel, it shows all sound at the max.
Feb 25, 2010 | HP 22" Widescreen Flat Panel TFT LCD HD...
My computer will no longer play music or any kind of noise
Check that your speakers are plugged into the right jack either in your sound card or the sound panel on the motherboard. If no sound then try plugging speakers into another computer and see if they are working and have power. Go to "control panel" and click on "Sound and Audio Devices" and under the volume tab under Device Volume make sure that the "Mute" box isn't checked. Also check the "place Volume icon in the taskbar" box if it isn't already checked. Go to the Volume control on the task bar and check out the audio volume levels and make sure they're not turned all the way off. Also under "Sound and Audio Devices" underl Volume tab click on "Advanced" and make sure that you have selected the proper kind of speakers in the speaker setup box.
YOu didn't say so, so I'm assuming that you're using Windows XP. If you're not the menus may be a little different but similar.
Sep 29, 2009 | Microsoft Windows XP Home Edition
No sound
Are you connecting the speakers to the green port on the sound card. If so, check in "Control Panel" that the P.C can see the sound card and that it is the "Preferred" play back device.
Sep 12, 2009 | Fujitsu Siemens Premium Line P19-1 19" LCD...
Can not get this monitor to play sound on PC using XP Version 5.1. a driver needed?
there is not a windows xp 5.1 so I am going to take a wild guess and you mean you want 5.1 surround sound
If your computer plays sound through its own speakers normally then you do not need a driver.
I took this from the FAQ
  1. Make sure the audio cable is plugged in to the back of the monitor and in to the Green port in the back of the computer.
  2. Press the Right Arrow button on the monitor itself and set the volume to 10.
  3. Double check your audio settings on your computer and make sure nothing is muted.
This is not one of the better monitors in this price range having only a VGA input but is suitable for most people.
Aug 14, 2009 | Sylvania CL772B 17" Flat Panel LCD Monitor
Built in speakers will not play any sound
going to seem a dumb Q,
but is the audio cable plugged in, next to vga hp have a separate audio socket, the cable(supplied- 1/8 inch stereo plugs each end) fits between sound card speaker out, and monitor.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00307478&lc=en&cc=us&product=459838&dlc=
Jun 24, 2008 | HP vs15 15"LCD Flat Panel Monitor
Speakers
make sure windows volume control is up.
its the speaker next to the time and date ,on tool bar ,bottom left normally.
play a song or video or such.
then check the cable in back of monitor it has a plug/connector that looks like a headphone jack /plug
follow it to the back of computer its color coded.
be certain the speakers have power if needed they will plug into monitor dc jack if the speakers are removable.
and check the vol control on the speakers.
May 11, 2008 | Mag Innovision InnoVision LT 765S 17" Flat...
Pc hook-up/sound issues
on the bottom of the monitor there is a audio input. you must connect you pc output(green) to the monitor input with a male to male audio cord. you can also use a rca cord with two adapters.
Oct 24, 2006 | ViewSonic N2750w 27 in. HD-Ready LCD...
HP Vs17 17" LCD Flat Panel Monitor Logo
132 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
