Question about Fuji FinePix J10 Digital Camera
Will not turn on battery good right now plugged in computer terminal press on nothing happens. its a fine pixJ100
Clock resetting and power button malfunctioning on my Gateway NV53A laptop.
Replace the CMOS battery. In the Control Panel, Power Options, set to High Performance, open Advanced power settings, set Sleep and Hibernate to Never, Adjust other settings to your preference. Set Screen Saver Time. Always turn off the computer and unplug when not in use, it will prolong life and a reboot every day will reset the computer. I would say you have a issue with the outlet connections/plug. If you have a multimeter you can verify.
Jan 18, 2013 | Gateway Computers & Internet
I was trying to view my pics on my computer. i plugged the usb in the computer turned the camera on and nothing happened. then i unplugged the usb frm the computer with the camera turned on and now my...
remove batteries. try and turn camera on, of course it wont work without batteries but this may clear any capacitors.now fit new batteries or just refit the old if you know they are good. and try again, does it work now?
Nov 09, 2011 | Fuji Cameras
2006 Mazda 6 will not start
U must find out why the starter is not cranking to start the engine. Have you checked battery terminals for cleanliness and lack of corrosion? Starter terminal wire good and solid? Solenoid any good? Connections? Relay issue?
Try getting a schematic so you can trace it out and find source of anomaly.
Sep 03, 2017 | 2006 Mazda 6
My laptop fell down and now my screen does not display anything
try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
Mar 03, 2010 | Dell Inspiron 6000 Notebook
Computer does not turn on when I press the power button
do u have the power adapter plugged in, or are you using battery power? the first thing i would try is disconnecting the battery. just compleatly remove it and set it aside. then try starting it with the adapter plugged in. sometimes the batteries go bad and are corrupt. i had this happen to a compaq laptop a few years back. after i got rid of the battery it worked fine. if it works u can always buy a new battery.
Feb 26, 2009 | Averatec 2371 AMD Turion Notebook
Acer 3680 will not turn on at all
take out the memory from bottom, and battery, plug into wall, and try again..
Mar 20, 2008 | Acer Aspire 3680 Laptop
Not turning on
try plugging the usb lead in and dont press  nothing on the mp3 player plug it into your computer it should switch itself on and you should be able to open the file on your computer and see whats on it if this dont work then it is beyond repair if it comes on and your computer can download files off and onto it then its is a battery problem might be that a wire has come off the battery terminal if this is the case and it works when plugged into your computer then it is possible to repair it you will need to take the case off and look at the wires that go onto the battery terminal this is usually the problem but to repair it you will need a small soldering iron but it would be cheaper to get to an electrical shop and they should do it for you for about 5 to 10 pound if it dont work when plugged into pc then ii is beyond repair sorry hope this is not the case good luck hope this is some help to you.............
Jul 23, 2007 | MixSonic MX-31000 (1 GB) MP3 Player
Fuji FinePix J10 Digital Camera Logo
19 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
