Question about Toshiba Satellite P205D-S7802 Notebook
Power light comes on, but the computer does not boot
Power light comes on, but the computer does not nothing. I can here the fan come on and the dvd drive works.
  • tampaIT May 11, 2010
    AMD?
    Video chip
  • 458 Answers
You need to Try plugging a desktop PC monitor into the serial port/vga on the laptop.. You're doing this to see if windows shows up on the external screen, if it does, you have Issues with your Display.. Which would be... The Display Panel or possibly the Display Cable
If No External Video....
You Have Video Issues .. Faulty Graphics/GPU Chip
Posted on Nov 19, 2009
3 Suggested Answers
ProsunPal
  • 60 Answers
SOURCE: computer wont boot
Try disambling the system. Clean it with a wind blower. Check BIOS battery capacity. Replace if possible. Power on the laptop. Do you hear humming sound from hard disk ? If you hear sssssssshhhhh sound from hard disk; it's OK. Replace RAM with new one. If problem still exists Than change main board. Hope that not happen. Keep informing.
Posted on Feb 22, 2009
  • 1087 Answers
SOURCE: power light comes on, but will not boot, also fan doesen't come o
Without looking at it sounds like a dead motherboard. You should be able to take it to a local shop and have then check it out for about $35-$50
Posted on Dec 29, 2009
Testimonial: "thank you!"
Sony PCV RZ44G irresponsive
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.Just because you see lights around the power button does not mean that the Power Supply is ok. I've seen many times when the Power Supply makes the light around the power button come on and makes the light on the motherboard come on, but it does not have enough power to make the Fan inside the power supply come on or anything else.
Apr 22, 2012 | Sony VAIO PCV-RZ44 (PCV-RZ44G) PC Desktop
I have a fujitsu e8410 which will not start up properly, when i push the start button it shows power but then the fan comes on and the cap num and shift lock leds flash and nothing else. can you help?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 31, 2012 | Computers & Internet
I have a Presario SR1950NX that is not booting. After turning on power, the fans come on and the DVD drive flickers, then nothing else happens. The keyboard and maonitor stay dormant. Normally, a loud fan...
It may be the clogged fan that caused this problem then resulted to overheat. possibly you need to replace the motherboard. or first, try using a bootable cd to boot your pc up. it may also be an issue with your hard drive not booting up.
Mar 29, 2010 | HP Compaq Presario SR1950NX PC Desktop
The computer powers on-the fans work,dvd bay opens but there is nothing on the screen. I removed the hard drive and checked it Had another computer same model and mother board and it boots. checked all...
Sometimes the CD or DVD going bad will keep it from booting.
I'd disconnect them and try a boot. Just might work and you'll save yourself the cost of a new motherboard.
Another thing to try is swapping out memory.
Feb 22, 2010 | E-Machines eMachines Desktop PC
Had trouble booting the computer over time. Sometimes power light would come on and nothing else. By unplugging, waiting 15sec it would power up. Over time this stopped working. Eventually power light...
Time to look for a new computer. That and take out your hard drive to copy your files over.
Sounds like motherboard problem. Probably not worth repair.
I've got an HP desktop with similar problems. It turned on one day just fine. The next day not. I don't even get the boot up screens. Disconnecting Hard Drive and CD/DVD components do not help. I should at least get some BIOS POST beeps and a Hard Drive Not Found or such. I do not. On occassion it will boot to a blank screen with white cursor in upper left. Most the time no screen at all. On rare occassion it comes right on and boots Windows. I guess it could be the power switch ... but I doubt that.
Nov 22, 2009 | E-Machines eMachines Desktop PC
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Sony Vaio laptop vgn-fs640-w problems
The motherboard controls the fan speed - and laptops often turn it off entirely when it is not needed. This sounds like a motherboard issue where an internal trace is broken and sometimes it makes contact, other times not. There's probably nothing you can do except replace the motherboard.
Jan 18, 2009 | Computers & Internet
Acer T180 will not boot or power on. It has a bad attitude!
Try tapping F2 as it is booting to get in safemode. If that works we're in business.
Dec 29, 2008 | Acer Aspire™ T180 PC Desktop
Computer randomly fails to boot
how many video cards do you have installed?
Nov 14, 2008 | E-Machines eMachines Desktop PC
When I hit power button on computer, power light doesn't come on...and the fan kicks on, but nothing else happens. nothing shows up on monitor except the test screen with 3 colors...the computer doesn't...
THis sounds like a power supply issue.. I had a similar issue with mine. my fan would kick on for about 2 seconds then shut off.
Hope that helps
Ciza
Oct 29, 2008 | Gateway (4000274) Motherboard
Toshiba Satellite P205D-S7802 Notebook Logo
446 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
