Question about Gateway FPD 1730 17" Flat Panel LCD Monitor
HANNS-G Model# HX191
This monitor is not showing any images. However, the monitor is getting power. The power light is flashing which would normally indicate that the computer is sleeping however, this is not the case. I have checked all of the connections and switched monitors and even plugged this monitor into my laptop and nothing. Could this be a faulty monitor?
  • 5 more comments
  • Vinny1 Jan 12, 2008
    No, there are no images at all. The power light flashes as if it were in sleep mode though.
  • Vinny1 Jan 14, 2008
    thats what I thought Thanks Fixya
  • madcat920 Feb 13, 2008
    I have the same problem...the monitor keeps going black. I got this monitor from a friend and I don't know if I need to "set" something with the keys that are on the front of the monitor (ie OSD, Auto/Set). Any information would be helpful...thanks!
  • jason12345 May 07, 2008
    I just set up the computer and all the connections are set but when you turn the computer on the light for the monitor turns on but the start up windows don't show.
  • Mr Noise May 24, 2008
    my hanns g hx191 tells me there is no signal when i switch my pc on. the orange light stays on and doesn't turn green like it used to. I've checked all cables and my pc works fine with an old monitor i borrowed from a friend. Help i'm clueless!!
  • vampiro0 Oct 01, 2008
    HEEEELP, my hx191 hanns g monitor displays the LOOOWEST resolution like 4 bits something and i can't change it at all and i can't find the drivers, I instert the cd and it wont detect it from the automatic install drive, I open it directly from my pc but i can't see a thing since the resolution sux, I reallly need help on this one please
    john
  • dorrielaw Feb 14, 2009
    Green light flashes but there is image on the monitor.
The issue here is most probably to do with your PC & not the monitor. You need to go into the display settings & check the multiple monitor support is on. I've just gotten one of these monitors & had the same problem.
GKS
Posted on Jun 26, 2009
    Master:
  • 788 Answers
Seems like it. Can you see a very faint image of the screen if you hold your nose up to it?
Posted on Jan 11, 2008
  • Dean Joly
    Dean Joly Jan 12, 2008
    Does the monitor's menu come up at all? If not then the screen is definitely faulty.
6ya staff
SOURCE:
LG Monitor L194WT - Indicator Lights Flashing
hi n hello
tried restarting the computer ?
Jun 19, 2008 | Computers & Internet
When I turn on the aspire one note book it goes to a white screen and will flash once and go to white screen and stays there, owver all other lights on the panel flash normal, but will not boot up. this is...
If you're still under warranty, you can diagnose one possible problem easily enough. Blank white screen with the LED indicator lights running normally otherwise will almost always mean that the LCD panel is bad. If you don't have an external monitor available, find a friend with one and hook up the laptop to that monitor. Be sure to have the laptop power off when you attach the monitor cable. Press the power up button and then the Fn+F? (whatever F key has a little icon on iyt showing a monitor) combo to switch to an external monitor. If your laptop's Operating System shows up on the monitor, you know for certain it's jus your LCD panel that's bad and you can ask the manufacturer to replace it.
Dec 05, 2009 | Acer Aspire One PC Notebook
Monitor shows on receiving signal, will not display image.
The Viewsonic VX2235WM has a known issue with the power supply going out. The flashing power light or no picture is the classic symptoms of this issue. Check out our web site at: www.ccl-la.com. We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: [email protected]
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jun 02, 2009 | ViewSonic VX2235WM Monitor
Blank Display, using exernal monitor, can see display info w/flashlight, display flashes light at startup
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S4407 Notebook
Pc does start but monitor is blank but its light is on
What connection are u using? DVI to DVI? VGA to VGA? or are u using DVI+ adapter to change the source to VGA?
Nov 21, 2008 | LG L1717S-BN 17" LCD Monitor
Green led light flashing on 700p proview flat panel and no picture
Usually when the power light flashes and the screen remains blank and unlit, your power board is in fact malfunctioning. This is not always the case, as the problem can sometimes reside in the input or inverter boards. I would first recommend that you feel comfortable with opening up your screen and looking at components. It can be a little overwhelming at first. BEFORE PROCEEDING, UNPLUG POWER TO MONITOR. If inclined to check, carefully open the casing around your screen. I have not worked on your particular model, but some are easier to open than others.
Once opened, you need to gain access to the circuit boards. Sometimes they are not protected by metal, other times they are completely encompassed. The flashing power light usually indicates that a capacitor(s) is(are) malfunctioning. To see if this is the issue, locate the power board (usually the one with larger-size components) and look for any capacitors having bubbled or raised tops and/or oozing a brownish liquid. If not on the power board, look elsewhere for the same symptom.
PLEASE BE CAREFUL!!! If you have recently had your monitor plugged in, the larger capacitors can still carry a charge. If you cross the leads of a capacitor while it carries a charge, it will discharge. It won't hurt any other components, but if you cross the leads with something that is in direct contact with yourself, you can get quite a jolt! There is usually a large voltage capacitor (normally just one) on the power board of these screens. I tested one with a multimeter after immediately unplugging it, and it still held a 166V charge! So please, do this with caution.
If a bad capacitor has been found, simply remove the old one and solder a new one in its place!
Nov 26, 2007 | Computers & Internet
MONITER LIGHT IS GREEN BUT ONLY SHOWS A NORMAL SCREEN FOR 1/2 SECOND THEN TURNS BLACK
HI. I had the same problem with mine. It would flash the screen on for a split second and then turn black, the whole time the power light remained green. Upon opening up the case, I pulled the combo power supply board/inverter board out for inspection. I noticed one of the capacitors had a bulge on top indicating it was bad. It was the the 680uf 25v capacitor. I desoldered it, and soldered in the new one. After hooking everything back up, bingo!! Monitor now works perfectly. I couldn't find an exact match to the capacitance locally, but I had a 1000uf 35v cap in my utility box. It worked fine as a replacement. You can usually go within 30 percent of tolerance and be alright. Just don't go under on capacitance or voltage. I hope this helps.
Nov 25, 2007 | LG Flatron L1710M 17" LCD Monitor
Open Questions:
See all Gateway FPD 1730 17" Flat Panel LCD Monitor Questions
Gateway FPD 1730 17" Flat Panel LCD Monitor Logo
694 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
