Question about Sanyo DP19649 LCD TV
Sanyo tv randomly turned off. tried umplugging and plugging back in. worked for 2 minutes and shut back off
  • Sanyo Master
  • 19,396 Answers
Hi.
The TV must be tested.
The problem is often a faulty power supply, that on this unit is integrated with inverter: POWER SUPPLY
As I told you, the part must be tested, and unless you have training and experience, better ringing the number listed on the owners manual to get a quote, or see if an extended service plan is available.
Regards.
Posted on Nov 19, 2009
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
Tv shuts off
You may want to check the below article for a wide list of Sanyo models exhibiting "random turn off" problem along with repair options for them.
http://blog.coppelltvrepair.com/2012/07/sanyo-dp47460-dp42840-dp46819-and.html
All in all the first thing you need in order to get meaningful help is providing information about which particular model and chassis is your TV.
Both are on the label at the back.
Mar 19, 2014 | Sanyo Dp32640
3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Dec 13, 2009 | Sanyo DP32746 32 in. LCD Television
TV shut off randomly. Unplugged for a while, worked for 2 minutes then shut off again.
Hi.
Random shut down can be caused by faulty power adapter, faulty inverter and faulty controller board, add buttons, shorts, bad fan and IR sensor.
The TV must be tested to find out the problem.
I suggest contacting Sanyo by calling the number listed on the owners manual.
Parts and part price available here.
Nov 19, 2009 | Sanyo DP19649 LCD TV
My tv just randomly shut off. I unplugged it for a while and plugged it back in and it came back on for like 2 minutes then shut off again.
Sounds like a faulty power supply. You can test wires from power supply to main board with a voltmeter to see if it is sending power
Nov 19, 2009 | Sanyo DP32746 32 in. LCD Television
Philips/Magnavox TV, model MS3250C321 shuts off randomly.
TV shutting off automatically means its a problem with the Lamp. Contact Pioneer or any local tech shop or Best buy and get the same replaced.
Turning off after specific time : Go to the timer option and disable the Automatically Switch off option. This will resolve the issue. Please let me know if it worked. If you need the user manual or instruction manula please click on the link below
http://www.generalmanual.com/Televisions/Sanyo-DP19647-Wide-Screen-Integrated-Digital-LCD-HDTV.htm. Hope this will be of help to you.
Thanks
Oct 17, 2008 | Televison & Video
Tv randomly shuts off
Replace power relays on power board...
Bill
Oct 08, 2007 | Philips 55PP9401 55" Rear Projection...
TV shuts off after few minutes
tap it on its side then try to turn it on and see if it stays on if it does bad solder connections
Aug 11, 2006 | Sanyo DS31520 31" TV
Sanyo DP19649 LCD TV Logo
130 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
