Front wheel bearings were installed too tight, the wheel has zero play and the brake caliper will not release properly
When you say "the wheel bearings are too tight, & there is no play". Is this on the rotor, or axle hub? When you depress your brake pedal, a number of things are in play. The twin pistons, within the Brake master cylinder is pushing hydralic Brake fluid to your caliper, under extreme pressure. When your foot is removed from the pedal, all there is to get that caliper to release, is a clean, wrking piston in the caliper, & THE MOST Mis-Diagnosed problem I have noticed on all makes,brands & models, ever since the inception of disc brakes...........is those "flexible, high pressure brake hoses. As fluid is pushed thru at extreme pressure, & only returning spring, non piston pressure, a "deteriorated hose", will actually work as a one way "check" valve. It will set the caliper, but, not release it. The gop bad at about 75,000 miles & up, depending on conditons the vehicle is used in.
