Question about Celestion C6-S Speaker
Cirwin vega home sub
The light on the amp turns green and you can feel the sube working through the box but has no volume
  • 492 Answers
Make sure that there are not any power cords near the leads from the amp to the sub.
Posted on Mar 07, 2008
Powered subwoofer amp repair? On and off works fine.. very weak signal to sub. All wires checked and working fine.
For starters, it is a home theater in a box. With that being said, highly consider upgrading before spending more money on the system. If thats not even an option, have you tried adjusting the level of signal being sent from the receiver out to the sub? It sounds stupid, but this is often over looked and can sometimes be tricky depending upon the type of receiver you are using, to adjust the level being sent to the sub... Typically when a subwoofer has little to no sound, this is the issue. Also, is the sub powered (does it have its own amplification using a power cord that plugs into an electrical outlet? If so, does it have a volume knob on the back, and does it respond when turning the knob? If its not powered, than your problem is what I described above, unless you've already done that. If that is the case, your speaker is fried... Hope this helps
Jun 19, 2014 | Cerwin Vega CMX 5.1 Home Theater Package...
My 10" subwoofer is hitting hard but no vibration, why? please help me to fix this issue.
You need a low pass crossover set at 80 hz & below. It will stop the music you hear in the sub. Don't expect the feel of a single 10 in a room to be like the same sub in a car. A car fills with pressure & gives the feel you want. A ported box designed to work with your sub will give you 3db or more output than a sealed box.
Jan 14, 2014 | Alpine SWS-1041 Car Subwoofer
I just pick up a used LW 10 Powered sub and 2 channel sherwood receiver.What is the preffered method of hook up up the sub with out a pre sub out?
"Sherwood Receiver" doesn't really tell us much about that end of the scenario.
Look at this picture of the sub amp.
http://cgi.ebay.com.sg/CERWIN-VEGA-LW-10-SUBWOOFER-AMPLIFIER-Speaker-Blade-Amp-/350444290153
You COULD run the Main speaker output to the large Red/Black speaker inputs, then some more wires Out from the other Red/Black connectors to your Main Speakers. That way your amp volume control will affect both equally.
Tweak the sub volume, crossover and phase to match it up to your mains.
May 15, 2011 | Cerwin Vega LW10 Subwoofer
2 15" and a 10" sub
10" subs need 1 cubic feet. 15" subs need 2.5 cubic feet. install them on its own volume of the box...
Jul 17, 2009 | Cerwin Vega IT-15.0 Car Subwoofer
1000 w sony xplode works at low volume then red lights at volume5
Most likely one of your subs are blown, or the Ohm's are too low for the ampliphier. Try hooking up one speaker at a time to the amp and see if it does the same thing. If it shuts off on one of the two speakers, that speaker is most likely blown.
Apr 19, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Box dimensions for 15 in cerwin vega
do you want the box ported or unported (holes or no holes) if you don't got a lot of room than you dont want a ported box. keep in mind the box has to have the correct amount of cubic air space or you could seize your sub... if you're building it make sure you use OSB board (oriented strand board) or MDF board(medium density fiber) your sub needs .7cubic feet of air space in an unported box
Feb 14, 2009 | Cerwin Vega IT-15.0 Car Subwoofer
Subwoofer goes to sleep
The receiver automatic speaker set-up set the sub volume at -12 and since it was not getting any signals from the receiver it was doing what it is supposed to be doing (going to the standby mode). This was troubleshooted by Onkyo tech support on a Sunday. All the best about Onkyo customer support.
Apr 12, 2008 | Audio Players & Recorders
Red light
something is shorted in the circuit, or your subs. unhook the subs first and try it again, if it is still in protect then it is most likely the output transistors.
Feb 22, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Subwoofer Trouble
Turn the bass gain all the way down., Turn up your your volume on bass test song. Crank up the little box next to the steering wheel wide open . Now go gradually turn up the bass gain on the RF amp until you get distortion. Turn the gain down slightly. Now you can enjoy playing the bass from one end of the little boxes setting to the other without ovrloading your amp and subs. Open a can of whoopass on anyone who tries to crank up on your gain.
Nov 09, 2007 | Car Audio & Video
SubWoofer
Sounds like your original and this sub have bad amps. The amp for the sub is not the same as the amp for the other speakers. The old unit has a dead amp and this new one is on the way out. (Pulling too much current on high bass)
Mar 30, 2007 | JVC TH-M505 System
Celestion C6-S Speaker Logo
142 people viewed this question
Top Celestion Audio Players & Recorders Experts
 Grubhead
Grubhead
michael wilkins
Level 1 Expert
Wbix
Are you a Celestion Audio Player and Recorder Expert? Answer questions, earn points and help others
