Question about Frigidaire ATF6000ES Front Load Washer
I explained my issue to your experts Monday and at your advice I replaced the Motor Control Board and now I get error 47 which states the Control board thinks the door is unlocked and wont allow to sppin in the Darin spin mode! Do I have to replace the main controler board now? or is it something different
  • mhelmerga Nov 20, 2009
    theis was rite on
  • 11,896 Answers
Door switch is likely faulty. It is best to test before replacing a device. When machine doesn't turn on, the control board or door switch is usually the culprit. You can test the switch with an ohmmeter to see if it is good or not. For future problems, you can also check the power to and from the main control board before replacing it. I recommend checking the door switch itself.
Posted on Nov 19, 2009
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
I have a Frigidaire front loader. Model ATF6000ES1. We got error code 23. The tech manual in the machine said it's the pump relay. Check wiring or replace control board. We checked the wiring to the...
An E23 error code on your Frigidaire Washer indicates a failure of the drain pump relay. Depending upon the model, your washer may be under warranty for up to 25 years, so check your warranty's status before attempting any repairs yourself.
Yor previous diagnostic its right; are you replace the control board... OK (other cases need replace it two times). Are you check the pump relay and wires, and this its OK, good.
Are you check and clean internally the pump and filter? So try cleaning it yourself, it is easy even with basic skill. You will need a star screwdriver, a scare-screw driver, pliers.
Remember, better have the machine empty before doing anything, because you'll be working on the drain line.
Hope this helps.
Jun 22, 2011 | Washing Machines
My konica minolta bizhub 7145 b/w copier is showing error code F-51-5 The copier will power up and then seize. The copier is about 5 years old with a total count of 320,000 copies
Hi the problem is going to be with the M1 motor most of the time replacing this motor will fix the issue However in rare cases if it still gives you the same error after replacing m1 motor then you will need to change CB Main Body control board my advice is to replace the motor and if it still gives error code replace the cb board but it will fix your problem
Mar 09, 2011 | Konica Minolta Bizhub 222 Black and White...
Code error 47:01
47:XX is a Starwheel motor mailfunction.
Look for any obstruction in the starwheel and move it in a up and down motion, try and lift it gently.
Either the lifter motor or main pca will need to be replaced if it doesnt dissapear.
Some people have stated that it was a slight crack in the lifter motor housing...aparently this is the cure of 90% of these problems.
Thanks.
-Sa_Les_Ski
Feb 28, 2011 | HP DesignJet Z2100 InkJet Photo Printer
Erorr code c49 in di470 photo copier
Hi this error code is an issue with paper source option vertical transport cooling fan motor or the control board check and replace motor if it dose not resolve the issue change the control board If you check vertical transport cooling fan motor rotation the voltage across pj14a-3 on power supply board and ground is dc0v after malfunction os reset
if yes change control board if no check cooling fan motor and replace it
Jan 27, 2011 | Minolta Office Equipment & Supplies
What does code F1 mean for a Kenmore Elite Oasis model 27032?
Here is a link to some good information on your error code. This should explain the error code you have.
http://www.theworldofwashers.com/2009/03/reader-mail-f1-error-code-on-kenmore.html
Nov 21, 2010 | Kenmore 27032
We had the no-spin problem. Bought a new control panel as suggested. After resetting the error codes we get the E6E error.
Hello, After checking your last post the problem here is you were advised to buy the wrong board. The problem you have is with the spin control board or motor control board. this is normally located at the floor of the machine to the rear right side if you are looking from the front. It sometimes can be located at the front left also. It's always best to check out the experts background before excepting his advice by clicking on his profile. I would return the control console and purchase the motor control. Hope this helps. Mike
Nov 04, 2009 | Frigidaire GLTF2940ES Front Load Washer
MAH8700A Error code 2E What does this mean?
According to the trouble shooting manual that came with my Maytag MAH8700A, code 2E refers to "Voltage for motor control bus is under specified limit." It states that the action to be taken is to "replace motor control board."
Nov 04, 2008 | Maytag MAH8700A Front Load Washer
Re: Error Code 5010
Call Canon technical support.
Dial 1-866-261-9362, Monday - Friday 10:00 a.m. - 10:00 p.m. ET (excluding holidays).
See also a previous related question here! (a scanner issue)
http://www.fixya.com/support/t1232529-error_code_5010_cannon_mp460_printer
Sep 02, 2017 | Canon PIXMA MP460 All-In-One InkJet...
Frigidaire ATF6000ES Front Load Washer Logo
20 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
