Question about Dryers
Square D (Nelco) MWA 2420 Forced Air with a broken heating coil
I have a Square D (Nelco) MWA 2420 Forced Air in-Wall Electric Heater whose heating coil has broken and which needs to be replaced. My wall opening measures 10'' X 17''. Can you recommend a replacement? Can it be replaced?
    President:
  • 1,922 Answers
If its a coiled "nichrome"wire,get the wattage off of it and order a re-string kit from an appliance parts retailer and re-string it yourself,if its a solid-element as in an oven bake element then go direct to the company web site for replacement cause its probably a special shaped element
Posted on Nov 19, 2009
I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Electric Heaters and Accessories - Grainger
www.grainger.com/.../electric-heaters-and.../heaters/.../N...
W. W. GraingerCount on Grainger to supply high-quality electric heaters and accessories for ...Electric Wall Mount Heaters ... Electric Space Heater,Fan Forced,120V, ... SearchQ&A ... This fuse is used on driers heater elements, I'm unable to locate these in .... in Ask and Answer are not intended to replace or supplement any professional, ...
DAYTON Electric Space Heater,Fan Forced,120V, - Portable ...
www.grainger.com/.../DAYTON-Electric-Space-Heater-...
W. W. GraingerShop DAYTON Electric Space Heater,Fan Forced,120V, (3VU33) at Grainger. ... Item # 3VU33; Mfr. Model # 3VU33; NSN # ... Country of Origin China Country of Origin is subject to change. ... Alternate Search Terms ... I need a replacement fan motor .... Where can I find parts for Dayton fan forced wall heater mod.5ZK54D.
Dayton Industrial Fan: Amazon.com
Dec 21, 2015 | Dayton Heating & Cooling
Blower motor not coming on for electric heater
Talk about a misnomer? Electric heat works way diff than gas heating. On electric heat multiple strips and a fan of course. But if they all come on at the same time then the breaker would trip so they use a sequencer for that job. Gas heat uses a bi-metal probe which twists around and turns the fan on when the temp reaches 110 in the plenum. Yall either have a bad fan or capacitor OR the thang that turns the fan on ain't doin it.
Nov 04, 2011 | Coleman Propane Forced Air Heater...
Dryer blowing cold air . No heat!
Check the "Bias thermostat" for continuity with a multimeter. IF it is bad, replace with this part.
Nov 29, 2010 | GE DBXR463EDWW Electric Dryer
MWA 2420 Wall Heater Motor Replacement
From what I can see you are asking me to tell you how I fixed the problem for free ye you want me to pay you for the solution, I don't go for that kind of business!
Jan 05, 2010 | Dryers
American standard thru-wall heater air conditioner (PTEC1501GAA) will not heat. When wall mounted thermostat is turned up for heat, the fan turns on but no heat comes out. I opened it up and checked the...
sounds as if the heater coil itself is burnt out. These coils may be repaired if you can get an universial coil repair kit and rewire the heater coil yourself. Since the age of the unit is in question I don't know if it is possible to get a kit for repairs but you never know. I would check an a/c supply house for this kit. Good Luck on your repairs
Dave
Nov 03, 2009 | Carrier 52PQ307 Wall/Window Air...
HOW TO LIGHT PILOT ON EMPIRE CORCHO WALL HEATER MODEL R 15
I have tried to light my empire wall furnace by pressing the button and I have the gas on and it won't light
Oct 17, 2009 | Reddy Heater RLP100 Portable Forced Air...
Kenmore 64942300 Electric Dryer runs, no heat
This may seem too simple of an answer based on your extensive troubleshooting thus far, but the most common reason for cold air running of any electric dryer is a broken heater coil. This is simply a coil of wire that is heated to warm the air in the fan duct. These often overheat and break if the vent duct is blocked, too long, or has odd bends that can restrict flow. Recommend replacing heater coil and use smooth wall vent pipe. Avoid coil type flexible duct.
Jul 03, 2017 | Kenmore 64942 Electric Dryer
Electric Heater Coils Always On
i suggest that the thermostat or the switch is at fault, contacts may be stuck. hope this helps
Jan 16, 2007 | Sanyo STW0923H2 Thru-Wall/Window Air...
Dryers Logo
451 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
