Question about Pentax ZX-M with 28-80 lens 35mm Film Camera
Film loads and after one shot the film rewinds for no reason
Film rewinds when loaded
Align film leader at mark, then close the camera back for prewind loading. Film rewinds as each shot is exposed. Built-in motor for automatic winding/rewinding. Film advance: Automatic. Single-frame and continuous (1 fps). Automatically rewinds film leader into cartridge when designated number of frames have been exposed (midroll rewind available).
sorce: http://www.canon.com/camera-museum/camera/film/data/1996-2000/1999_eos3000.html?p=2
Canon Camera Museum Camera Hall Film Cameras
good luck
Dec 20, 2014 | Canon EOS-AE-1 35mm SLR Camera
Film not going through camera
E indicates empty.
try resetting the camera. Pus both the rewind buttons (plus/minus button by release button and bracket button on side of mirror box). Push them at the same time. Let the camera run until it stops (just a few seconds). This resets the camera. Then try loading the film again. Make sure the leading edge of the film isn't bent and is the edge is within the red rectangle under the take up spool. It should then load the film. Note: the N75 pulls all the film out of the cassette and then rewinds it back I one shot at a time until you reach '0'.
Aug 12, 2014 | Nikon N75 35mm SLR Camera
When i try to advance my ae-1 camera it takes a picture! how do i fix it
The magnets that control the shutter are the likely suspect. Dirt and debris can cause them not to hold properly. Hence, it fires the shutter when you advance the film. It is something you can repair yourself. ............or.
you can also try....
i'm not an expert on the AE-1. It is a camera I've never had any desire to own. But on most older slr camera the rewind knob will turn when the film is advanced. But only after the slack has been taken out of the film still in the canister. Since you've already taken a few shot the film shot be very secure on the take up spool. To check that it is, slowly crank the film rewind crank clockwise. After a few turns the film should become tight in the canister, and you will feel the tension. If this happens then the film was loaded properly. If after quite a few turns you still feel nothing, then the film was not properly inserted into the take up spoll. If the film was not loaded correctly the film leader will go inside the canister as you crank. But that is not a problem. Any photo lab can pull the leader back out. Just make sure they know what happened.
Thanks.
Mar 12, 2011 | Cameras
Camera does not rewind after end of film it spins, but does not engage the film. Joe M.
it is likely that this model of camera spins the entire roll onto the take-up spool, and then slowly rewinds one frame at a time until the last picture is taken. Then it has already almost rewound,
This shows up when you load the film. The cameras digital counter counts up to the number of pictures available, and counts downward each picture taken.
Sep 08, 2010 | Canon Sure Shot 80U 35mm Point and Shoot...
My Canon AE-1 Program will not rewind. I shot the whole roll, rewound a little, and then accidentally opened the back cover. The counter reset to S, and the rewind crank just unscrews when I try to...
I think you have already ruined the film except the frames that are rewind back to the film cartridge.
You can take the film out from the camera, push in the rewind button at the bottom, pull out the film from the film take up reel.
On the film cartridge, turn on the long tube in the middle clockwise to wind all the film back into the cartridge.
If you had the back opened briefly, do manual film rewinding in the dark room.
May 21, 2010 | Canon EOS-AE-1 35mm SLR Camera
The films rewinds as soon as I close the lid. It
One reason may be that the film is not pushed far enough to the receiving spool and the camera thinks it's empty thus rewinding the film.
If this is not the case it needs to be repaired.
Nov 19, 2009 | Canon EOS Rebel G 35mm SLR Camera
Hi: I have a nikon n75 I have film in the camera but looking for the rewind button. Not able to locate my manual. First time doing this.
There is no rewind. When the camera loads the film, it pulls it out all the way. Each time it takes a shot, it rewinds the frame back into the can. At the end of the roll the leader is wound back into the can. As soon as you hear the motor stop, you can just open it and take out the film.
Oct 05, 2009 | Nikon N75 35mm SLR Camera
Can't advance film, press shutter, no result
Do you have film in the camera? If so, is it an old film or you have just loaded it?
If it's an old film, could it be at the end of the roll - to check this, 'lightly' turn the rewind lever backwards and forwards. As the camera is pointing away from you, turning the rewind knob clockwise will normally rewind the film (don't press the rewind button in, we don't actually want to rewind the film yet), turning the knob clockwise should be tight and a firm stop, if the film is at the end, you will feel the same tight firm stop if you turn it counter-clockwise. Don't turn the rewind knob backwards (counter-clockwise) too hard, you'll unscrew it and it may fall apart. If turning it backwards rolls freely in a full circle, then you have film left.
Another option is that, since it's been so long since you used it, the loading of the film may have gone amis and sometimes the cassette will flip backwards, jamming the film in place so it wont advance - if you have loaded the film and not taken any pics or have not been able to advance it at all, it should be safe to open the back as the film will be in it's original loading position, if you have left the film in it from some time and don't know what stage it's up to it may be best to take it to a camera store where they will have a "Black Bag" to put the camera in and manually open and unload the film. Make sure you get an experienced person - some pimply-face teen that's never used a film camera can easily put their fingers through the shutter while it's in the black bag - I've seen it plenty of times.
OK, that's enough to get started, did this work or do we need to try more options?
**.The best way to acknowledge contribution is to rate it's relevance.**
Feb 03, 2009 | Canon EOS-AE-1 35mm SLR Camera
The film automatically loads then rewinds when a new film canister is added
Hm. Well, the way this camera works is actually very clever. When you first load a film into it, it winds the entire film out of the cassette and into the camer. As each shot is taken, the film is rewound back into the film cassette. The advantage of this is that if the back of the camera is accidentally opened, the shots which have already been taken are already safely back in the film cassette and will not be damaged by the light ingress. However, your camera is behaving strangely. I would check that the electrical contacts where the film cassette goes in are clean. You can clean them using a cotton bud moistened with methylated spirits.
Apr 13, 2007 | Canon EOS Rebel G 35mm SLR Camera
Pentax ZX-M with 28-80 lens 35mm Film Camera Logo
Top Pentax Photography Experts
Bill Eager
Greg Cann
Greg Cann
Are you a Pentax Photography Expert? Answer questions, earn points and help others
