Question about Craftsman Garden
Used sea foam to clean intake now it back fires/craftsman 18hp not new will valves set eventually
  • 169 Answers
Sparkplug is fouled. replace it then go from there. hard to diagnose over an iphone :) good luck!!
Posted on Nov 19, 2009
Very hard starting and won't run full throttle
try valve clearences check air cleaner and check pilot and main jet again in carby
Jun 19, 2013 | Husqvarna Garden
2.2 litre 1995 gmc sonoma idles rough no trouble code. found hole i brake booster vaccum line fixed that. replaced and changed fuel filter, idle air control valve, got spark at coil packs, put new spark...
Three things you should check using a good code checker which can read sensor outputs - the throttle position sensor (TPS), the mass air flow sensor (MAF) and the EGR valve. While you are at it, replace the PCV valve.
Jul 30, 2017 | 1993 GMC Sonoma Club
17.5hp OHV Briggs & Stratton w/ Nikki Carb sputters & backfires thru carb & muffler
Hi, run a number drill through the main jet. Even though you have carby cleaned it a thin layer of residue will remain on the walls of the jet. The problem you have is a lean misfire. Regards Phil.
Jun 11, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
1996 volvo 850 pcv valve location
These have a PCV oil trap, not a valve. It is located under the intake manifold. The hoses run from under the spark plug wire cover all the way down to the oil trap and over to the throttle body. Over time the PCV oil trap becomes brittle and clogged. You will need to buy a new PCV kit for around $150 and replace it. Before you do, you must clean out the engine block where it attaches at its lowest point on the engine. I used sea foam, compressed air, and a coat hanger. I did an oil change at the same time so I could drain the sea foam out of the oil pan. Make sure you clean it out good because it will spray oil out of the dipstick and oil filler cap even after replacing the PCV components.
Apr 13, 2012 | 1995 Volvo 850
Car running lean on bank 2, changed intake gaskets and pcv valve
what does exhaust smell like you may have carbon build up in engine try removing o2 sensors and cleaning with brake clean and reinstalling reset code and see if it comes back and how long it takes to reset also you can put a can of berryman in the gas tank with at least 1/2 tank of gas or more also buy a can of sea foam and install through vacuum booster hose you may see lots of black smoke from tail pipe if so after following instructions for application drive some what hard and if the black smoke continues fore at least a mile keep driving and if you notice a diff in runability but still have a little black smoke buy another can of sea foam and repeat service NAPA has sea foam on sale this month
Apr 11, 2012 | 1996 Chevrolet Impala SS
It works for a certain time but after it run for several minutes its begun to have a problem og low compression or rpm then sloely it will *******
Your problem may very well be related to fuel.
Will it idle if left alone to warm up?
Has the bike been used or has it been setting for a while?
Do you mean that you throttle it and eventually it will become sluggish?
If you are using fuel with Ethanol in it, it will cause your valves to build up. Go to Wal-Mart and get some Sea Foam and fill up with Premium fuel - then add the suggested amount of Sea Foam. You may have to use the Sea Foam for two fill-ups or more, but if it's fuel related, this should clear it up and save you mega bucks by not having to take it into the shop.
Jan 08, 2011 | 2004 Sym Husky 125
Fireing out carb
It could be an intake valve that is not sealing due to sticking or burning and in some cases mal-adjusted. When was the last time the valve lash was adjusted?
May 21, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
MY 89' CHEVY WITH 305 IS BACK FIRING THROUGH THE THROTTLE BODY
Chk. your egr valve, that it is not sticking and you got vacume to it. could be carboned up and is not working.
Feb 13, 2009 | 1989 Chevrolet C/K 3500
Garden Logo
43 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
