Question about LG VX8350 Cellular Phone
LG VX8350 was recording video just fine, and now doesn't. Nothing traumatic has happened to it. I've tried changing the settings (record length, saving to the phone, saving to the mem card, etc.) and nothing is helping. I press the button to record video and it brings up the camera screen just fine, but then I press "record" and it gives me a "FAIL!" error.
Wavepad
Give it time. It will need to process the data. Test with a brief recording. If it takes more than ten times the length of the recording, try reinstalling the software.
Jul 13, 2013 | Computers & Internet
No audio after recording from sat. Reciever
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
Aug 31, 2012 | LG DR389 MULTISYSTEM DVD RECORDER FOR...
Recording Playback
Does it just skip. When you try playing it on your computer or on the camara itself after you upload it to your computer?
May 11, 2012 | JVC Everio GZ-MG30 Camcorder
Lg dvd recorder/vhs combo doesn't read dvds
Buy a DVD cleaning kit follow the instructions, sometimes brings it back to life. If no change! the assembly will need to be replaced,"not cost effective" cheaper to replace.
Mar 15, 2012 | LG XBR446 DVD Recorder/VCR
I tried contacting the Nikon tech support,infortunately they were unable to answer my question.The D5000 has a movie mode; with the camera came a 'pq1 4GB SD HC card'.According to the manual I can...
The five-minute limit has nothing to do with the memory card or the video resolution. In some parts of the world video cameras are taxed at a higher rate than still cameras. Cameras that can only record videos up to five minutes in length are not considered video cameras and thus are taxed at the lower rate.
When was the last time you saw a movie or TV scene that was five minutes long without any cuts or breaks? It doesn't happen often and very few people find the five-minute limit restrictive.
Video quality is a very subjective thing. The quality is better than that of almost all compact still and video cameras. It's not as good as professional-quality video cameras. Video has a different "feel" from film --- but which is better?
Since the recording length doesn't depend on the resolution, I'd suggest you always record at the largest resolution. Videos can always be shrunk in size --- they can't be expanded.
Aug 17, 2011 | Cameras
Cannot set the time of recording. The increment
I have the same problem! Wish someone would post a solution!
Jan 09, 2010 | ION Audio VCR2PC VHS VCR
Problem dubbing from HDD to DVD+R (LG RH7823W)
Received no proposed solution, Is this the service I can expect from fixya,com?
Jun 16, 2009 | LG DBRH197H DVD Player/HDD Recorder
Programming TV-channels on old Samsung VHS video recorder VB-520T
I tried another position of te range switches and scanned again and again and then I found the tv channels finally.
Mar 25, 2009 | Televison & Video
LG VX8350 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
