Question about Cell Phones
Top of dryer and top rear panel gets very hot to the touch
Top of dryer gets very hot to the touch as does the back of the top panel. Could this be an overheat sensor? Where is it located?
  • rjhahn May 11, 2010
    No, it is your It is your element touching the housing. This will cause your element to stay on all the time. Try unpluging the dryer to see if the top cools down or through the breaker to the dryer.
    President:
  • Cell Phones Master
  • 1,922 Answers
Yes,check the hi-limit switch on the case of the element housing,it will have 2 heavy wires attached to it and it probably isn't opening up to let the heat element cycle,also check the heat cycling switch in the unit also this can be in the exhaust vent or numerous places to moniter heat for drying clothes
Posted on Nov 19, 2009
GE dryer very hot on top--hasn't been used
Often times the element has broken (burned out) and is now touching the element housing causing it to heat up and stay on even though the dryer is not even running.
Mar 10, 2014 | GE Dryers
Dryer surface too hot to touch
this dryer is an electrical heated dryer i suppose, ask an electrician to check the heat sensor, for this should trigger the on and off switch of the heater according to the drying cycle you set your dryer.
Dec 07, 2013 | GE DSKP333ECWW Laundry : Washer/Dryer...
Top of dryer and the back panel get too hot.
Of course they get hot, that is normal.
Jun 30, 2017 | Frigidaire AEQ6700FS Dryer
The dryer isn't drying. The top an the control panel are very hot to the touch.
Hello Rodney.
What the most probable trouble with the dryer making it very hot to the touch while at the same time not drying is a poor air flow problem. That could a be a broken blower wheel,a blocked or restricted vent.
GENE
Nov 12, 2011 | Dryers
Dryer gets too hot, so hot you cannot touch outside top of thr dryer. drum sizzle if you sprinkle water on it.
Inside back panel on the outside of the heater element enclosure there are over heat thermostats..round with two screws...
Oct 06, 2009 | GE Dryers
Clothes not drying but back panel of dryer extremely hot
Disconnect power. Next, you will have to remove the screws passing through the front panel into the front edge of the top so the top can be swung back. Remove the screw on each side near the top which are holding the front panel onto each side panel. Set the front panel off to the side. (most times you do not have to remove any wires to do this) Use your long thin arms to reach under the left side of the drum to unhook the drive belt. Now, you can remove the drum out the front of the dryer. Inspect the heating coils for breakage. Replace them with a new element set WE11x10007. (includes instructions, but don't stretch them as much as they say, so that you can leave a little tension on them as you install them. You don't want them too long) Replace the rear drum bearing WE3X75 to get rid of the squeak. Inspect the front drum slides (which support the drum at the top of the front panel) to see if they need replacement also.
May 24, 2009 | GE DBXR463EDWW Electric Dryer
Dryer makes squeaking noise
If it has not been squeaking for an extended time you can get by with just changing the rear drum sleeve bearing (WE3X75). To do this, open dryer door, remove screws going up into top, allowing top to swing up and back. Remove screw holding front panel to side panel near top just under where the top was. Tilt front panel forward and lift off bottom pegs. Swing to side (you don't have to remove wires). Pull drum forward about 6 inches. (you don't even have to remove the belt.) Change sleeve at center back of drum. Make sure to inspect the front drum support slides WE1M481dark ones and WE1M333 white ones (about 1/2 inch x 2.5 inch strips at the top of the front panel which support the front of the drum), as about the time the rear bearing goes, these may be wearing also, especially the one on the left side.
Nov 18, 2008 | Dryers
Frigidaire dryer overheating
the other tstat is on front of blower housing..lift top remove screws at top of front panel from inside remove switch wires front lifts off ..be sure to ck vent first most dryers have thermal fuses that will blow if overheating does occur since yours seems to be working i would suspect vent first..if your concerned about dryer being hot to touch along top rear this is normal heating element is located just below console at rear
Nov 13, 2008 | Dryers
Top and back of Kenmore dryer feels very hot to touch
this alway in a indication of a venting issue it would seem that it is not in your venting that you can see but it may be plugged up in the wall somewhere in this case you will need a pro. chimney sweep or THE DRYER VENT WIZARD if there is one in your area to come and clean your vents
Jun 01, 2008 | Dryers
FDE436RES1 - Frigidaire Overheating
tstat possible but make sure vent is open completely to outside ..may try load with rear hose off to verify
Apr 24, 2008 | Dryers
Cell Phones Logo
55 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
