Question about Linksys Wireless-G WRT54G Router
Linksys 54g
I go on the internet and I have a connection of 54mps, after awhile it varies from that to 48, 25, then goes back to 48 and then fluctuates
  • xenocide May 11, 2010
    1. how far away is your router?
    2. are you using a laptop?
    3. do you have any 2.4ghz wireless phones, or devices that run on the 2.4ghz frequency in your house?
What channel are you using? the standard channel 6?? try 11 or any other channel.where are the antennas pointing to??
Posted on Jan 11, 2008
Does it mean my adapter is bad if it just stays lite up green and doesn't flash to try & connect to the internet? I installed everything correctly but it still isn't working. Any ideas? I have a belkin...
The Linksys adapter should have a program you open to find and connect to your router. If not, you can use the Windows Network settings to find your router and connect. Although 54G is a slower speed, they should still connect.
Jan 28, 2018 | Linksys WRT54GX2 Wireless-G Broadband...
Have a WRK-54G Linksys wireless router. Have a
I had a TEW-421 card for a time, and it can not do WPA encryption, only WEP. It's not a driver shortcoming, it's the hardware in the TEW-421 card.
Sorry to tell you it's a dead-end, but at least now you know.
Oct 18, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
1 forgot my passwords for each computer on linksys router 54G
You can press the reset button on the back for a minute and it will reset the router back to default.
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
Vista keeps losing internet connection
open device manager and  look at network adapters and right click on your device and go to properties and uncheck the power management box that allows pc to put device to sleep. this should resovle your problems since windows id defaulted to put device asleep when idle to save power. hope this helps.
Mar 14, 2009 | Linksys WCG200 Wireless Cable Modem 54G...
Connecting a linksys wrt54g to a netopia modem
Is this an ISDN modem?
Generally: Netopia Ethernet out -> Linksys WAN port with a standard ethernet cable.
(Not the yellow LAN ports! - They are for your computers/printers.)
Dec 28, 2008 | Linksys Wireless-G WRT54GS Router...
Unable to connect wireless
Since you are unable to go via wireless, follow these steps:
1) Access your router configuration pages by typing in 192.168.1.1 into your web browser.
2) Click the tab that says Wireless.
3) Make sure the wireless broadcast option is enabled. If it isn't, enable it and select save settings.
4) Set up the wireless network through your Vista PC by going to Start > Network.
5) At the top of the window, select add a wireless device. Follow the onscreen instructions to add your Linksys Wireless Access Point.
6) Once added, right click on Wireless-G Router (name varies) and select configure. Follow the onscreen instructions to configure your router. (You can find your router pin by following steps 1-2 and selecting Wi-Fi Protected Set up.)
7) Once completed, attempt to connect to the internet via wireless router.
Dec 15, 2008 | Linksys Wireless-G Broadband Router
Slow Speed on Wireless Connection
As you said , try upgrading your routers firmware, but the better fix would be for a n router with a n card you will have a proper synchronisation and good speed.. or else the speed will vary, for a g router and n card..
Oct 23, 2008 | Linksys Wireless-G WRT54G Router
Speed
no not really, but 54mps is a wireless speed not the actual internet connection speed... if your lagging try wire the xbox and see if that fix's
you could also disable the wep/wpa security for the xbox and hardcode the xbox MAC address into your router
Mar 05, 2008 | Microsoft Xbox 360 Console
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
