I HAVE A TOSHIBA TELEVISION MODEL NUMBER CX32D60 THAT WONT TURN ON. POWER BUTTON BLINKS WHEN PLUGGED IN AND THEN WONT DO ANYTHING ELSE.
  • 2 more comments
  • 2coolnurses Nov 19, 2009
    How do I fix this problem?
    are you just talking about a new plug?
    Ok thanks how would I go about getting a new one and is this hard to get too ... could you explain how to get to it and remove it ... thanks for your help
    Thanks for the continued info ... having trouble locating a power supply for my model a Toshiba CX32D60 television any help would be appreciated
  • 11,896 Answers
Sounds like the common power supply failure. You can test power from wires to main board with a voltmeter. Make sure it is putting out enough power.
Posted on Nov 19, 2009
  • 2 more comments
  • Nate Stansfield
    Nate Stansfield Nov 19, 2009
    I fyou find that the power supply is bad or high voltage transformer is bad, you can use a soldering iron to heat up the connections to remove them from the system board and solder in the new one.
  • Nate Stansfield
    The box inside tv that the power cord connects to. (power supply)
  • Nate Stansfield
    It is not hard to get to. They are right there in the back. Some have an easy pluging that just unplugs. Others are soldered in.
    Shopping results for toshiba tv power supply
    PD2237D-2 PCB - POWER SUPPLY MAIN FOR TOSHIBA 27HLV95 TV - DS-7209
    $179.99 new - Discount-Merchant.com ...
    APS - 219 PCB - POWER SUPPLY MAIN FOR TOSHIBA 50HP66 TV - E135516
    1-873-817-12 PCB - POWER SUPPLY AUX1 FOR TOSHIBA 37HL67S TV - INY ...
    $179.99 new - Discount-Merchant.com ...There are some videos on youtube and howstuffworks.com that show how to replace these. Videos are nice!.
  • Nate Stansfield
    Other than the power supply.
    The most common failures are the flyback transformer assembly and
    sometimes some of its support components, and or there is the
    possibility of a short in the CRT electron gun. In either case, the
    power supply is going in to protect mode, and the uPC is sending this
    flashing error code to the front LED.
    I have no idea if the flyback transformer assembly is still available,
    but I am very sure the CRT is no longer available. In any case you will
    find the cost of servicing your set to be expensive for its age. The
    last time I checked, the cost of the CRT exceeded the replacement cost
    of the set.
Tv not coming on has a blinking power button
Toshiba CX36F85 36" TV Blink - Questions - Fixya
www.fixya.com > ... > Toshiba > Toshiba CX36F85 36" TV
Toshiba CX36F85 36" TV, blink related issues. ... Every brand TV will have its ownblinking ... stand by light blinks 6 times, wont power on tv is only 4 years old. ...From the number of blinks occur at one time switch ON, you can get an idea ...
Toshiba CX36F85 36" TV Blinks - Questions - Fixya
Toshiba CX36F85 36" TV, blinks related issues. Get free help ... Every brand TV willhave its own blinking codes. From the ... Push power button and it ... and then ... stand by light blinks 6 times, wont power on tv is only 4 years old. Junk! it wont ...
Toshiba power light blinking not turn Standard (CRT ... - Fixya
www.fixya.com > ... > Standard (CRT) Televisions
Jan 10, 2016 | Toshiba CX36F85 36" TV
My 40" Toshiba LCD TV (model 40RV525U) won't turn on. While plugged in the green power light constantly blinks, but the TV won't power on. Unplugging the TV stops the power light from blinking, but once...
These blinks are fault indications, and are called blinking codes. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. If you're sound in electronics, this will make the repair easy. If you wish to get more details about these blinking codes, check this link. Blinking codes to many brand TVs are described in detail. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 06, 2013 | Toshiba 40RV525U 40 in. LCD TV
Toshiba 50HP95 timer/Rex light blinking green. Tv wont turn back on.
place to begin if you are able is examine the power board for puffed up caps and or voltages coming into the board and out of it.
Aug 27, 2012 | Toshiba 50HP95 50 in. Plasma Television
My panasonic cinemavision 1081 wont turn on the power button just flashes
Model number please? Also count the number of blinks: 3 or 5 or?
SD TECH
Oct 28, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Wont come on
Howdy,
It sounds like the lamp has failed. It easy to replace, you cann find price and number on this site.
Good Day, big IRISH.
Dec 28, 2009 | Toshiba 52HM95 52" HDTV Projection...
Toshiba 57h81 red light blinking
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 14, 2017 | Toshiba 57H81 57" Rear Projection...
Television wont power on
Is the led blinking? If so please let me know how many blinks its making before pausing for a second.
Apr 13, 2008 | Sony KP-51WS520 51" Rear Projection...
62inch phillips bigscreen tv
how many times does the power light blink, that can be an error code indicating whats causeing the set to not start. Let me know how many blinks its blinking and also let me know your model number.
Dec 07, 2007 | Toshiba 43H70 43" Rear Projection...
Screen shuts off
my screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. there might be problem of loose contact in power supply Thanks
Sep 11, 2007 | Toshiba 32AFX61 32" TV
My TV will not come on but the power button blinks red!
Very interesting. I have a Toshiba 53 H71. Same issue. It occurred to me after a move.. No one has offered any help on it. Posted about a week ago. Guess no one knows anything about these TV's....
Sep 02, 2006 | Toshiba 50HX81 50" Rear Projection...
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Electro Med Services...
