Question about Nintendo Wii Console
Wii sensor bar is acting up
Got a new wii, played it a few weeks, turned it on, it recognizes the remote, i am in front of the sensor, but pointer is still not working
  • Anonymous Aug 08, 2008
    you **** ***
Wii sucks stuff quits working too quickly
Posted on Aug 08, 2008
  • 97 Answers
Wii snsor is very sensitive has it fell or had any cracks on it. play around woith remote more, maybe it will pick up the pointer, if not available online or in some stores.
Posted on Jan 11, 2008
Tip
Wii Cursor is off-center, jerky, erratic, disappears, etc.
  • Verify that the Wii Remote's pointer lens is free of obstructions and contamination (stickers, heavy smudges, etc.). The pointer lens is the tinted rectangle at the end of the Wii Remote. If the Wii Remote Jacket is being used, verify that it's securely in place on the Wii Remote. If the Wii Remote Jacket is askew, it might be partially blocking the infra-red sensor on the front of the Wii Remote.
  • Try a new set of batteries. Occasionally weak batteries can cause this type of behavior.
  • Reset the Wii Remote:
    1. Take the batteries out of the Wii Remote, wait for one (1) minute, and then re-insert them.
    2. Wait a few seconds before pressing any buttons to wake up the Wii Remote.
    3. Re-sync the Wii Remote by using the steps listed above in the white box titled "Try these steps!".
  • Check the Directional Sensor Functionality by holding the Wii Remote with the button side down. Without using much force, tap the button side of the remote against the palm of your other hand. Doing this does not take a lot of force, so be sure not to tap the Wii Remote very hard.
  • Verify Sensitivity Setting dots:
    Go to the Sensor Bar's sensitivity setting in the Wii menu.
    • If only one or no dots appear on the sensitivity screen, there is likely a problem with the Sensor Bar.
    • If there are more than two dots, then it appears there is an additional light or infrared heat source being picked up by the Wii Remote. Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
    • If both dots appear and the erratic behavior continues even when you move closer to the TV, there is likely a problem with the Wii Remote and it will need to be repaired.
on Mar 04, 2010 | Video Game Consoles & Games
Tip
The hand on the screen from the wii remote jumps all over the screen.
There are a few reasons that this would happen.
1) Make sure that you are not to far away from the sensor bar, this can lead to a week signal for the pointer!
2) Make sure that you are within the range of the sensor bar, and by this I don't mean close to the sensor bar, I mean the angle you are opposed to the sensor bar. If you are to far of an angle to the left or right of the bar, it will have a tough time reading the signal input from the Wii remote. Best to stay as close to center while you are playing as possible.
3) Double check the battery level in the remote, which you can do by pressing the "home" button. If the batteries are to week, they will not send a good signal to the sensor bar!
Hope this helps! :)
Sep 14, 2011 | Nintendo Wii Console
Bought nintendo wii last xmas and had played quite frequently. then after a break in play of a few mths the remote controls dont seem to be being picked up by the sensor. i chenged the batteries and still...
Hello there
Hold the Wii Remote upside-down with the buttons facing downward.
Tap the remote firmly against the palm of your hand three times to remove any dust sitting between the buttons and the electronic circuit board inside the remote.
Turn the remote upright and press one of the buttons. If the problem continues, Open your Wii Remote's battery door
Check that your Wii Remote contains two new "AA" batteries or a charged battery pack. Check that no corrosion is present on the battery's metal elements/connectors.
Use a cotton swab to clean the remote's battery element/connectors if corrosion is present.
Check that the Sensor Bar cable is inserted firmly into the back of your Wii gaming system. The Sensor Bar needs to be centered above or below your television so the Wii Remote can transmit signals to the gaming system.
Stand three feet away from the Wii gaming system/Sensor Bar.
Aim the remote and press any button to test the device.
If the remote is not working, stand five to 10 feet away from the gaming system and try the device. The Wii Remote works best three to 10 feet away from the gaming system/Sensor Bar.
Move any objects blocking the signal from the remote to the gaming system/Sensor bar--candles, other remote controls (TV/cable box) and wireless computer devices/cellular phones.
Also, if any sunlight is coming in through a window, close the curtains or blinds to keep the light from interfering with the remote's signal.
Turn off and unplug your Wii gaming system. Leave the unit unplugged for one minute. Plug the gaming system back in.
If the remote still aint working;
Turn the Wii system on. Press and hold the red "SYNC" button for 15 seconds when the "Health and Safety" screen appears on your television. The "SYNC" button is behind the small door on the front of your Wii unit.
Release the "SYNC" button. Remove the battery cover and batteries/battery pack from the back of your Wii Remote.
Press and release the red button located under the battery compartment. The blue lights on the front of the remote will blink
Press and release the "SYNC" button on the front of your Wii gaming system. The "Player" light on the gaming system stops blinking and stays on, the resetting process is complete
Oct 01, 2010 | Nintendo Wii Console
Unable to setup second hand control , now doesn't recognize either
Hold the Wii Remote with the button side down. Without using much force, firmly tap the button side of the remote against the palm of your other hand a few times. Doing this does not take a lot of force, so be sure not to tap the Wii Remote very hard. Check for proper response. If the problem is not solved, please follow the rest of the instructions on this page. For all Wii Remote issues: If you are experiencing problems with a new Wii Remote, or are having difficulty with a Wii Remote that was previously working properly, please carefully read and follow the instructions on this page. Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen (more info). Make sure you are using fresh batteries in the Wii Remote. The Wii Remote Controller should be used between 3 to 10 feet from the TV. Make sure no objects are blocking the signals between the Sensor Bar, the Wii console, and the Wii Remote. Check for interference from infra-red light sources, such as candles, sunlight, fireplaces, and stoves. Radio frequency interference may cause the Wii Remote to work erratically. Check for wireless devices such as cordless phones, wireless computer keyboards or mice, or other similar devices, and move or turn them off.
Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common: Getting the Wii console to recognize (or "sync" with) a Wii Remote, especially one that did not come in the box with your Wii console, may require doing a few additional steps before it can be synced. Additionally, a Wii Remote that was working, but is no longer being recognized (or has "lost its sync") may need to be re-synced. Please use the troubleshooting steps listed below, Try these steps! Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes: With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture). When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4). This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
Feb 22, 2010 | Nintendo Wii Console
Using the Wii Wheel, uncontrollable
you might have a bad wii remote, because the wii wheel is just a case for the remote to sit in. try playing it without the wheel and see if that works. if you dont have any luck, you need a new wii remote.
Jan 13, 2010 | Nintendo Mario Kart (Wii) for Wii
Wii remote not sensing motion
The senser might not be working this happened to me and we googled and we just ended up buying new remotes or the batterys. the light will be on if they are dead. well ours did.
Jul 21, 2009 | Nintendo Wii Console
After I turned on the power, The pointer was missing, so I can not select the program or function
There is a simple thing to find out if you need to by a new sensor bar. Becareful when doing this. Take 2 candles and set them apart, about the distance ofthe sensor bar. Your Wii remotes operate off of UV/infared. This is an alternate way to play the game with out having a sensor bar installed. Really cool the first time I did it. Any way if this brings you pointer back then you need to get a new sensor bar. They are only about 5-10 dollars at nintendo.com. If this does not fix the problem then that means that you need a new remote. You can also get that at nintendo.com you could also get them cheaper at game stop or something of that nature.
May 11, 2009 | Nintendo Wii Console
Cursor does not appear
exchange it
    Cursor not appearing
    Please note that our experience shows that this troubleshooting is best performed using only one (1) Wii Remote at a time.
  • Some games do not use the cursor feature of the Wii Remote; Make sure the game you are attempting to play uses the cursor by reading the game's instruction manual. You can also exit out of the game to return to the Channel Menu and use the Wii Remote to see the cursor. If the cursor still does not appear, continue with the steps below.
  • Trying to use multiple Wii Remotes in the Mii Channel or Photo Channel? These Channels only allow the Wii Remote designated as "Player 1" to function.
  • Check the battery power level by turning off the Wii console, then opening the battery cover of the Wii Remote. Press and release the red "SYNC" button to check battery strength. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength. Our experience has shown that as your battery strength decreases to one (1) or less lights flashing, the cursor may not appear. For troubleshooting, if possible, try using fresh batteries so that all four lights illuminate. For guidelines on using batteries, please click here. If after inserting brand new batteries, you are still seeing less than all four LEDs flash, then your Wii Remote will need to be repaired. Please click here for repair information.
  • Is the Wii Remote properly synced?
    Press the POWER button on the Wii Remote to see if the Wii console powers on.
    • If it does, the Wii Remote is synced with the system. Please skip to the next section.
    • If the power doesn't come on, power on the system manually and try syncing the Wii Remote.
      • If the Wii Remote will not sync, there is likely a problem with the Wii Remote. Please click here for repair information.
      • If the Wii Remote will sync and the cursor still does not appear, try another Wii Remote if possible.
        • If at least one Wii Remote is working, there is likely a problem with the first Wii Remote and it will need to be repaired. Please click here for repair information.
        • If you have only one Wii Remote, or none that are working, please continue troubleshooting.
  • Make sure that the Wii Remote is being used between 3' and 10' directly in front of the TV and that there are no bright light sources affecting the Wii Remote's operation (review Game Play Guidelines for more information), and that the Sensor Bar is placed properly (see Sensor Bar setup).
  • Check the cord on the Sensor Bar for any frayed wires or kinks, and verify that the Sensor Bar is free of obstructions.
  • Check the button functionality, and that the Sensor Bar is operating correctly, by accessing the Wii Main Menu. Use the "+" and "-" buttons to scroll side-to-side through the Wii Channel screens.
    • If you are able to scroll with the "+" and "-" buttons, but the cursor is not appearing, then there is likely a problem with the Sensor Bar. Please click here for additional Sensor Bar information.
    • If there is no response, there is likely a problem with the Wii Remote. Please click here for repair information.
Dec 11, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
246 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
