Question about ViewSonic N1750w Television
I need the part number PWTV1762CP1 it's a power supply card.
  • ViewSonic Master
  • 8,457 Answers
Tries Shopjimmy.com or Ebay.com
Posted on Nov 19, 2009
Hi, I have a Tv wich works for 30 secondes and stop. . Please Help THANK you Tony
The power supply is going out. It can be replaced fairly cheaply and is easy to do. You will need to remove back cover and look at serial number on power board sou can order same card. The power supply is the card the power cord plugs into.
Sep 16, 2015 | Televison & Video
Replace integrated Radeon 4200
You can't replace integrated graphics, the chip is on the motherboard.
See what you have for PCI-E slots, a forty dollar graphics card is three times better then your 4200.
Apr 14, 2013 | HP Pavilion Computers & Internet
Replaced graphics card now monitor and keyboard does not work
Need to know;
A) What is the computer manufacturer name, and model number,
OR;
what is the motherboard manufacturer name, and model number?
B) What is the manufacturer and model number of the graphics card?
C) Am I to understand you replaced the Power Supply?
1) Manufacturer name and model number of it also.
2) Is it new, or pulled from another KNOWN to be working computer?
D) What was the original problem?
Why?
1) Want to make sure it's the correct graphics card for the motherboard.
2) Want to make sure you have enough power out of that Power Supply, to not only support the graphics card, but the rest of the computer system also.
Motherboard, Ram Memory, Harddrive, Optical Drive/s, Fans, etc.
3) Need to know about the original problem, to help determine the solution.
I need All questions answered. Post back in a Comment.
Regards,
joecoolvette
Mar 01, 2013 | Computers & Internet
I have ati hd 4850...and its overheating...im thingking about changung the power suplly..any advice what wattage can i use.. or you therse a problem between the board and the video card??..i have core i3...
If your graphics card is overheating, it isn't because you have a weak power supply. It is because it is working too hard. Clean the Fan/s and make sure there is a good supply of air circulating inside your case. The wattage you need from your power supply will depend on a lot of things, not just the graphics card. Processor, number of hard drives and no. of optical drives as well as any case lighting and extra fans you have fitted. But I would suggest at least a 600watt psu for a low end machine to 1000 watts or more for a cutting edge machine. Always buy a named brand of PSU such as Coolermaster, Akasa, OCZ or CIT these all have good reputations and are readily available. Buy the best you can afford- your supply will only provide as much power as you system needs, not all of it at once.
Feb 18, 2013 | Computers & Internet
How to install riser card compaq evo
Finding a compatible graphics cards may be a daunting task if you know little about your computer's components and technical specifications. To find a video card that is compatible with your system, you'll need to uncover information about your motherboard and power supply by opening your case and peeking inside. From there, you can perform additional research and make an informed determination of the types of graphics cards compatible with your computer. If your warranty is still in place, consult your computer manufacturer or builder to obtain the information you need
Physically open your case and examine the number and types of slots on your motherboard. Unplug any cables connected to your computer prior to removing the side panel, but make a note of where your monitor connects. Remove your case's left side panel (when facing the front of the case). You may need to remove screws or to adjust latches. Please see your case or computer manual if you are unsure how to remove the side panel. Locate the current graphics card. By matching the port your monitor plugs into with the graphics card, you should be able to easily locate your video card. If you have an on-board graphics chip, the monitor will not connect with a card but with ports directly on the motherboard. Measure your case interior and the card slot. Make a note of how long the current card is. You must also measure for prospective maximum expansion card length. For example, if you measure 7.5 inches from the slot cover to the nearest obstruction (obstructions may include other slots, chips, or the processor), you will not be able to buy a card that measures 8.5 inches in length. The card you install must not affect any other components on the motherboard. Write down any brand name or model number so that you can verify the measurements by researching the card's specifications. Locate a serial number, brand name or product number for your motherboard and write it down so that you can research the motherboard and its specifications. Locate your power supply. Generally, the power supply will be in the upper-left corner of the case. Power cables connected to your drives, your motherboard and possibly your video card will run to the power cable. Make a note of the wattage, the brand name, and any model number. Perform research to verify the power supply's specs. Replace the side panel, and plug in all cables. Find a graphics card that will work with your motherboard and power supply and fit the motherboard's measurements. The card should both fit into the slot physically and be designed for the type of slot on your computer. Ensure that the card has drivers for your operating system. Hope this helps.
http://www.4allmemory.com/video-card/compaq-hp-evo-d510-series/
Jan 01, 2013 | Compaq Evo D510 PC Desktop
I HAVE A HP PAVILION SLIMLINE (S5310F) AND WANT TO PUT IN A VIDRO CARD, SO I NEED A LARGER POWER SUPPLY. HOW DOO I DO THAT?
Replacing the Power Supply DEPENDING on the power needed? you might have to settle for a slower, weaker performing video card. Make sure you check the video card power supply specs needed.
Chances are you will max WATT at about 300WATTs less then what you'd need to power a gaming video card. OR you could do as I'd do.
Remove everything and place it all in a standard tower case - install a 650WATT power supply in to the new mid/full size case and BAM solution found.. Have fun and a great day to ya.
Oct 10, 2010 | HP (0950-3952) (09503952) 425-Watt Power...
I have a model PS-5301-08HA power supply in my HP computer. I am adding a video card and cannot tell which power lead from the power supply is used for powering a video card. They are bundled together and...
There are two types of video cards, Ones which power themselves for the Slot and other high end ones need to be powered from the supply. Most video cards are provided with a cable like this one.7c6778b.jpg You will need this cable in order to properly connect your video card to the power supply.
Hope this solves your problem.
Apr 20, 2010 | Lite On Computers & Internet
Power supply compatible with cooler master cac-t05-uw
Power supplies are not matched to a case. Any one you buy will fit in the case. You need to make sure it has the correct power capacity and plugs for your motherboard, video card, and anything else you will have plugged into it.
Mar 27, 2009 | Cooler Master CAC-T05-UW ATX Mid-Tower...
Xps gen 4 desktop power supply upgrade possibility
Buy a generic case that will accept the power supply you need. Of course you will need to transfer everything from the old case to the new case.
Dec 05, 2008 | Computers & Internet
ViewSonic N1750w Television Logo
22 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
