Question about Hobart H600 Stand Mixer
Trying to find what the shaft assembly looks like on a Hobart H600 Mixer
  • 235 Answers
B1sam - You might try using the very easy "Hobart" smartparts webapp on the Hobart website. Cut and paste this into your browser Address line: http://catserv1.itwfeg.com/Hobart-Root/assynode.cfm From there you can select from 19 assemblies to review. Each assembly includes a parts list and an exploded view of the assembly. Based on your comment 'shaft assembly', I believe you want to look at either #12, Transmission Unit or #13, Planetary Unit.
Good Luck... I hope this is helpful.
Howard, Burke, VA
Posted on Nov 19, 2009
  • Howard Lincoln
    Howard Lincoln Nov 19, 2009
    I was a bit hasty providing the link above. I failed to mention that you first have to register with Hobart to access their Hobart 'smartparts' app. It's well worth the effort. See the msg from Hobart below:
    Public access users
    If you have previously registered via the www.HobartLink.com site, please access www.HobartLink.com via the www.HobartCorp.com site. If you are a new user please register via the www.HobartCorp.com site.
    Sorry for the confusion - Howard
I needed to know the PH for a h600 11344142 Hobart mixer... And is it a single Or 3 face??
Hello Jbabajanov,
I understand that you want to know about the HP (Horse Power) of a H600, 60 quart mixer and weither it is a single or three phase.
All H600 Hobart mixers are equiped with a 2 horse power motor.
As to wether it is single or three phase you will need to look at the service tag of the machine. If is listed on it weather it is single or three phase.
Thank you for choosing FixYa.com
Justin
May 13, 2011 | Hobart H600 Stand Mixer
What oil can you use for the hobart h600
on the hobart h600 we use 120 oz of 140 weight gear oil.
Mar 04, 2011 | Hobart H600 Stand Mixer
About how many time you must change the oil.
For most applications once every two to three years should be fine.
Feb 02, 2010 | Hobart H600 Stand Mixer
Hobart HZ (h600?) Raising handle is acting up
You will need to confirm the model number. An H600 or L800 have a wheel to manually turn to raise and lower the bowl. The M802 and V1401 hav a belt driven bowl lift clutch, operated by a lever. When you push the lever up or down, you are engaging a small transmission between the motor and main housing. You would need to remove the top cover and see what's happenning. It may be there is something other than the proper spiral pin joining the lift lever to the clutch input shaft, giving alot of backlash and insufficient selector movement.
Aug 18, 2009 | Hobart H600 Stand Mixer
Electrical connection of hobart h600
it requires 3 phase with ground it is a four wire system
Jul 24, 2009 | Hobart H600 Stand Mixer
Oil leaking from shaft after wew moved it
Oil seal around the shaft probably dried up. Before replacing, try penetrating oil at seal, wait a day; if no better, replace seal.
Jun 25, 2009 | Hobart H600 Stand Mixer
Hobart H-600-T Mixer Shuts down while mixing bread dough
What you replaced were the contacts on the overload,correct?These 'heaters' look like springs?If so you have other issues.I'm a hobart tech and repair these mixers often.Are you mixing pizza dough?
Mar 06, 2009 | Hobart H600 Stand Mixer
HOBART H600 Leaks oil.
There's an o-ring that goes around the attachment shaft,if you get a flashlight and look into the hole you will see a screw (left handed threads),remove screw and pull out shaft.Put the o-ring on and install the shaft and screw.
Feb 24, 2009 | Hobart H600 Stand Mixer
Hobart H600 bowl wheel slips
Some of the older H600s do not have a bowl lift lock. Look to page 18, items 57-72.
http://www.hobartlink.com/Extranet/ExtranetManualsAndCatalogs.nsf/6E1A88214EC64B59852568E1006A99F9/$File/F18797%20Rev%20B_lk.pdf
Take off the cover and see if the assembly is there. If not, get a bungee cord for the handle. If it is, when you start the mixer the solenoid should fire and lock the gears in place.
If the assembly is there and not working, check the it is not binding. If it is, free the assembly up and check the solenoid. If it was frozen it usually causes the solenoid to overheat and burn out. Good luck - Mike
May 08, 2008 | Food Mixers
Hobart H600 Stand Mixer Logo
133 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
