Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door opener cuts when its opening or closing
    President:
  • 3,197 Answers
If you mean cuts out when running you need to check the wiring connections. Make sure they are all tight.
Posted on Nov 19, 2009
Craftsman 1/2 H/P garage door opener door goes closed but then opens
Try adjusting the "closed switch" forward a little in case the door is going too far when trying to close.
Sep 03, 2014 | Building Materials
Craftsman 1/2 HP Model 139.53914 The wireless outdoor keypad will not open the garage door but it will close it. The two garage door openers work just fine and the indoor keypad works fine. Replaced the...
Sounds like it has lost signal strength and the door cuts it down to the point that the receiver never gets the signal when the door is in the way. If it did that before you replaced the battery then you will have to replace the keypad.
Dec 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlin garage door opens to top limit bounces back to return down about 6 inches and then returns to open limit. What adjustments are neccessary?
The limit switch of both the sides are not reached. The drive must be realigned to work till the door closes fully so as to touch the limit swittch to switch off.
Similarily the open door must go to the extreme point to cut off with the activation of the limit switch.
Sep 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman remote won't close my garage door
If the remote opens and closes while inside the garage but not outside , there are a few things it could be. Assuming it was working fine before..
1. weak battery in remote.
2. remote itself could be bad. (unless you have more than 1 remote acting the same)
3. Logic board in opener is going bad causing limited range.Is the wire that hangs down from the opener straightened out? That is your remote antenna.Some people have coiled or even cut it off..reducing range.
4. Less likely but this can happen- interference from another electronic device, wireless routers, cell phone, new appliances etc.. can reduce remote range. Any new electronics recently purchased?
Jan 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman garage door opener opens fine. When I try to close it the door starts to close, stops, the light flashes and it goes back up. I replaced the two sensors thinking one must be burned out. Before...
Make sure the sensors are wired correctly. The solid white wire from each sensor goes to terminal #2 and the wires with the black stripe go to terminal #3.
Each of the sensors has a small light that must be on for them to work properly. There is a possibility you could have a bad wire. Check to make sure something like a staple hasn't cut the wire.
Nov 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Opens & closes arbitrarily on it's own
This is usually cause by a bad wall control or the wiring going to it. Sometimes the staples used by the installer will cut through the insulation and intermittently short the two wires together. The wall control just goes bad from use.
Jul 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Raynor garage opener-remote only works close up sometimes
check to seee if the little wire that hangs out of the operator is hanging out. This wire is the ant. if this is not the problem replace the 12volt battery you can buy them anywhere. make sure you didn't cut off the ant. wire (I have seen customers cut thios wire thinking its an extra and not needed or place the wire inside the box very little signal that way have to be very close)
Jun 05, 2009 | Building Materials
Same as above....
check to see if the battery needs replaing or if someone cut or pushed the wire that hangs down about 6in on the back of the opener.
Jun 04, 2009 | liftmaster Chamberlain Garage Door Opener...
Garage door will only close with keypad code it will not open
UNPLUG THE UNIT AND WAIT 5 MIN.
WHEN YOU PLUG IT BACK IN CLAER ALL CODES BY HOLDING DOWN THE PROGRAM BUTTON FOR 20 SECONDS.
NOW TRY TO PROGRAM EACH REMOTE AND KEYPAD - IF THERE IS STILL A PROBLEM CHANGE THE BATTERIES AND REPEAT THIS PROCEDURE.
I HOPE THIS HELPS
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens on it own and light blinks
  • Stuck remote control button. Check all remotes. check LED on receiver.
  • Staples around Multi-Function Control Panel bell wire could be cutting into that wire. Remove wires from opener and test. Replace staples causing intermittent short.
  • Multi-Function Control Panel could have sticking door control push bar. Remove wires from control panel and test. Replace control panel if defective.
Dec 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
48 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
