Question about Sony VAIO GRZ660 Notebook
Auto shut down due over heat - Sony VAIO GRZ660 Notebook
  • 192 Answers
I recommend you check all your air vents for dust buildup. Use an old toothbrush to brush the dust away from the vent holes and blow air through the vents using one of those compressed air cans made for cleaning keyboards. Many laptops have more than one vent. Look carefully to find them all. One time I had to take a Sony laptop apart to remove all the dust buildup. However, most of the time cleaning the vents from the outside works. After you've cleaned the vents If you still think you have an overheating problem I recommend downloading a free piece of software named FanSpeed. Here's a link. http://www.softpedia.com/get/System/System-Info/SpeedFan.shtml I'll let you read the description for yourself, but in short it allows you to monitor the temperature inside your computer and to adjust how the fans react to this temperature. I hope this helps you out.
Posted on Nov 19, 2009
  • 27 Answers
Very Very Carefully disassemble the laptop, and clean out the processor fan, and any other "vent" looking things. Lots of times hair (especially pet), dust and other pollutants will clog these, or they may stop working all together, and need replaced.
How can I stop auto shut down?
Do you block the air flow in any way? I use a metal laptop stand that I can elevate the back of the laptop. The surface the lap top rests on is wire mesh so there is no reduction in airflow. Never had a problem with it.
Nov 16, 2015 | Computers & Internet
Whirlpool dryer doesnt heat, time and shut off when you open the door
if you have it on time dry and it doesn't count down the timer is bad but it should stop when you open the door unless you have a broken door switch too,just open the door and push in on the switch with your finger,it should make a clicking sound,if not the door switch is also broke,if you have the timer on auto or more or less then it won't move without heat.on auto the heat comes on when the dryer reaches temp. the heat shuts off and the timer will advance a little,then the heat starts again and the timer stops,it will do this until the clothes are dry by using a sensor instead of time.
Feb 16, 2014 | Whirlpool GEQ9800P Electric Dryer
While browsing net r watching movies my lap(acer extensa 4630)shut down itself
The processor has to perform large amount of work while surfing , especially while usingvideos and animationMultiple windows/tabsnumber of browserwhich in turn produces lot of heat . The heat produced is managed by the interneal heat sink and inbuilt cooling fans.But this cooling process may get affected by the blockage in air vents due to dust.So to safeguard the laptop form overheat, it automatically shuts down.
One simple try :Go to the Adobe flash properties and disable Hardware acceleration for online content. That ought to stop the system from rebooting or crashing.
Else...Its better to call a technician when it shuts down often.....
Apr 10, 2012 | Acer EXTENSA 4630Z COMPATIBLE LAPTOP LCD...
Shuts down randomly
check if the Notebook shutting down due to heat sinking. Make sure the heat exaust panel cleaned properly. Also uncheck the option "automatically Restart" from Startup and Recovery.
May 03, 2010 | HP Pavilion ZV5340US Notebook
Amana dryer not advancing on auto
Make sure the vent from the dryer to the outside is clean.
Reduced air flow can cause your symptom.
You can remove the vent hose from the dryer and operate the dryer in the automatic cycle.'
If the timer advances you know the vent needs cleaning.
Clean the lint filter housing also.
A flashlight helps to see all the way down the housing.
Jan 20, 2010 | Amana ALE643RB Electric Dryer
I have a Rowenta Pro. Iron, model DE-86.1A with auto shut-off. It sticks on auto shut-off. I have to move it around for it to heat up, as indicated by the sensor light on the top.
I believe that is how the safety feature works.
Once the iron detects no movement for a certain period of time (the iron assumes you have finished ironing) the iron will shut of the heating element.
One you have moved it around, the timer should prevent it from auto shutting down for a period of time.
Jul 22, 2009 | Rowenta Irons
Engine cuts out when hot
every generator has an auto-shut down system that turns the engine off when over heated..u can dislocate the wire coming out of the engine and into the on/off switch...and then it till never shut off unless u tell it to....
but be carefull!!!!!!!!!!!!!:when u dislocate it...u r turnning off the auto-shut down system...so if the engine over-heats.. it will not shut down...
if u have any further questions email me at sal_kh_sab@yahoo.com
Jul 13, 2009 | Coleman Powermate Powermate 5000W...
JVC HD DILA 56G886. replaced lamp and now it shuts down after 10
we found that it is an auto shut off system on the TV due to over heating. The lamp, if not cooled correctly shuts down. We added a mini fan in the back and it seems to work fine now.
Jan 25, 2009 | JVC HD-56G886 56" Rear Projection HDTV
Shuts Down
is the bottom of the laptop extremely warm ?
the fan and heatsink may need cleaning as it could be shutting down due to heat (thermal) issues.
Robert
Sep 08, 2008 | Acer Aspire 3000 Notebook
Sony VAIO GRZ660 Notebook Logo
591 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
