Question about Kenmore 46123 Stainless Steel Electric Kitchen Range
Back Clearance for building cabinets around stove
What is the clearance for this model? Is it zero or do I need to leave some room?
  • 1,314 Answers
You should have gotten a set of installation instructions with it but if you didn't send me the model number off the serial plate ill see if i can find out but don't rate me till we finish and you do need some clearance
Posted on Jan 11, 2008
How much breathing space does a refrigerator need NONE, 1/2 inch or 1 inch above the top of the cabinet for air circulation. Sears has told me all 3. WHICH IS CORRECT?
For airflow it would be the back that needs clearance of a couple inches. Top of unit shouldn't matter. Inside the fridge itself if you plan on packing it as full as possible except for the amount space needed to allow airflow,. I would just atleast leave 1 inch on every side. But outside of fridge just leave clearance in back and front. Google manual and it will tell you
Oct 24, 2016 | Refrigerators
Refrigerator not Cooling ?
1. Make sure condenser is clean.
2. If you have a "static" condenser (black coil on back) make sure it has enough room around it for air to circulate. Not against the wall and if under cabinet should have about six inches clearance.
on May 29, 2010 | Refrigerators
What clearance do I need between the wine cooler and surrounding cabinets and counter top?
According to "," the rule of thumb for non-front ventilating, free standing units is a 3" clearance all around. Hope this hel
Nov 06, 2014 | Dishwashers
How high should the microwave be above the stove?
In our area the bottom of the cabinet that you are mounting it to needs to be a minimum of 66" from the floor. You should check around with someone in your area to see what local codes are for mounting your microwave. Most of the time this will put the bottom of your microwave anywhere from 16" to 20" above your stove. See the following link for a listing of many types of appliances and their clearance needs.
Oct 01, 2014 | Kenmore 30" Microhood Combination,...
Premier free-standing gas range, 20", how much clearance from wall?
If you are seeing the bubbled paint on wall when you open the oven door, it is more than likely heat loss past the door gaskets. They are easy to install clip on gaskets
Feb 05, 2013 | Premier Kitchen Ranges
My Subzero 650 does not stay on 34 degrees consistently. It is not now and I have turned the unit off for 15 minutes but to no avail. It has done this before but after a 36-48 hours it is back to 34...
You need to check the following to make sure your fridge is working properly:
Vent blockage - Air flows between the freezer and refrigerator sections to provide proper cooling via air vents.
Condenser coil - When the condenser coil is dirty it causes the sealed system to overheat and therefore the refrigerator will not cool properly.
Defrost Cycle - When the refrigerator goes into defrost, the cooling mode stops and a defrost heater energizes to remove accumulated frost from the evaporator (cooling) coil, which causes the freezer temperature to rise slightly.
Proper Air Circulation - Refrigerators require a specific amount of clearance around the cabinet to allow for air circulation. If the refrigerator does not have the minimum clearance required, the refrigerator cannot cool properly.
Hope this helps.
Apr 23, 2011 | Sub-Zero Refrigerators
Is it possible to install a wood stove in a room with carpet floors
Yes, but you need to put down ceramic tile down around the wood stove. Go to your local wood stove dealer and ask for there recommendations. It can be done.
Feb 14, 2011 | Heating & Cooling
Clearance around air conditioner
For clearance you need to have a minim of 1 foot around open.
May 17, 2010 | Weather King 10AJA3601AH Air Conditioner
Presently have a regular hood, would like a microhood. How many inches clearance do I need between the top of the stove to the bottom of the cabinet?
This is a good question to ask at the point of sale. The measurement varies for different models and makes, but 33 - 36 inches is ideal. If you have a 12 or 15 inch tall cabinet above the stove, you are fine. A microhood does require a dedicated electrical circuit. When powewring off the current hood circuit, check to see if any other lights or outlets go off.
Jul 07, 2009 | Microwave Ovens
hi you need at least 3 inchs clearance from the back ribs to the wall for good ventilation if there is no ventilation back there you will need to do 1 if to whole room is hot then you can install a fan that will cool down the heat from ribs good luck
Dec 20, 2005 | Kenmore 13485 Wine Cooler
Kenmore 46123 Stainless Steel Electric Kitchen Range Logo
94 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
