Question about Technics SA-AX720 Receiver
Have se-ch515dp-k reciever want to know how to set time on clock
My 812 amp is not working stand by is blinking please help me
Posted on Nov 19, 2009
Even with brand new batteries inserted into the Reciever, I still can't get an outdoor temperature. Why ?
Make sure they are both set to the same channel (normally channel 1) put them next to each other then press reset on the temperature unit only.
www.serendipity-gifts.co.uk
Jun 19, 2012 | La Crosse Radio Controlled Atomic Clock
How do you set the time on the DB365usb in dash reciever?
The following manual is found through Crutchfield's site:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/020/020DB365US.PDF
On Page 21 of the manual is "Setting The Time/Clock":
2-1. Select "CLOCK (E)".
3-1. Press the [PLAY/PAUSE] button.
3-2. Press the [ PREVIOUS TRACK / NEXT TRACK ] lever upward or down-
ward to select the hour or the minute.
3-3. Turn the [ROTARY] knob to set the correc
time.
* The clock is displayed in 12-hour format.
3-4. Press the [ PLAY/PAUSE] button to store the time into
memory.
Note:
• You cannot set the clock when it is displayed with
only the ignition on. If you drain or remove the car's
battery or take out this unit, the clock is reset. While
setting the clock, if another button or operation is
selected, the clock set mode is canceled.
I hope that works well for you.
Jun 18, 2010 | Clarion DB365USB CD/MP3 Player w/USB
My Nokia 5310 XpressMusic has problem with time settings. Whenever i set the clock 5min faster, after some hours i find the clock settings 5min slow OR if i switch off and then on my Handset, my clock is...
If there is a problem in the received mesage time, Do set your time settings as :
Time Zone: GMT +5:30
Day Light Saving as +0
And do restart your handset. This will solve your problem.
Mar 19, 2010 | Nokia 5310 Cellular Phone
Setting the delay on the oven
To correctly proceed you have to know the format the timer program is working in. SO you need to know
1Time format IE 12 hour AM - PM or 24 hr military time 2If a day, date is required M-Sun...or IE Sat 12th of March...(some times this is not a peramiter needed)
With the clock and calendar set the delay time should require a "timed mode setting" prior to being able to set the timer. Once in this mode you will have 1 of 3 ways to set the time delay depending on how the timer is set up to read your instructions. .
1 the actual time of day it is to start (set in actual clock time like the equalivant of 3:05 PM or if in military time, 24hr clock 15:05) or 2 the actual delay time until the program is set to start (again set in hours and minutes 2:10 = 2 hours and 10 minutes from now) 3 also is the stop time, when you want to program to end (also set in the format the timer is programed to recieve instructions)
Also the calendar could be waiting for input as to which day to start the program
Jun 12, 2009 | Kitchen Ranges
Hang problem
check the DRAM clock in bios setting,. don't set in to auto,.just make sure you have same clock timing RAM module if you have more than 1
May 10, 2009 | Gigabyte GA-945GCMX-S2 Motherboard
Cannot get the correct time on my car reciever pioneer deh-11e
For most Pioneer single CD players, you can set the clock using the following steps:
  1. Press and hold the SOURCE button until the unit shuts off.
  2. Press and hold SOURCE again until the clock appears.
  3. Press the left or right arrow to select the segment of time you wish to adjust.
  4. Press the up or down arrows to increase or decrease the numbers in the blinking segment.
  5. Once the clock is set correctly, press the SOURCE button to exit.
Mar 29, 2009 | Car Audio & Video
Accuwave DS Clock
The radio may not be able to get a strong enough or clear enough signal to process (night is best away from TV, computers and radios).  To regain "control" of the clock, take the battery out, wait 30 seconds and then reinstall it.  This will reset the clock.  You can then manually set the clock.
Press SET for a few seconds until the hour starts flashing in the display.  Then press the ADJUST button to set the hour.  Press SET to move to the different functions (Hour -> Minutes -> Seconds-> Month -> Date -> Year) each time using the ADJUST button to correct the setting.  Finally press MODE to exit the setting mode.
If the time zone is incorrect for your area (default is PST), press MODE to enter the Alarm Time Mode; then press SET to flip through the time zones; then press MODE again to exit.
The little "reset" is for use if the LCD display doesn't come on when the battery is changed. It doesn't affect any of the clock settings per se.
Nov 02, 2008 | Audio Players & Recorders
Time set Alpine Reciever
Push on the clock display button until time starts flashing. Let off of the button. The numbers 5&6 button have a small h and m on them for hour and minutes. Push these buttons one at a time until you get the minutes and hour you desire. Don't hold the button down constantly. You have to punch them until you get the right time.
Sep 05, 2008 | Car Audio & Video
Hitachi F392 VCR
Do you have the manual?...accordianman
Feb 08, 2008 | Televison & Video
Remote Sensor
make sure your time is set and the atomic clock time is recieved, then leaving the rear cover off of the transmitter, push the "tx" button not the "c/f" that is just for centegrade or ferenhight. you will see the red light on the front of reciever flash in a few seconds. The temp should display on your clock screen. If not, did the red l.e.d. light on transmitter flash. If not, its not sending data to clock. I have to reset and hit transmit every time I replace batteries on transmitter. Had no problems for over 2 years of using outside. If your not getting a reading with transmitter sitting next to clock after hitting "tx" button you may have defective transmitter.
Jan 13, 2008 | Homedics Sound Spa Premier SS-5000 Clock...
50 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
