Question about Sony Cyber-shot DSC-W70 Digital Camera
My Sony DSC W80 18 months old has started malfunctioning - when turn on lens goes in/out but get an error messsage advising turn off/on again - but doesn't solve problem and can't take pictures. Any advice much appreciated
stevetrevino
  • 31 Answers
SOURCE: DSC-W80
I checked everywhere online to use the sony camera as a webcam and found no results, unless your a serious hacker, it would probably be to complicated.
Posted on Oct 29, 2007
  • 188 Answers
SOURCE: DSC W80.
Whenever you switch on the camera the lense comes out to a certain places, stops and the camera is initialized to take the picture. In some cases when there is a friction in the movement of the lense, it does not comes out fully up to the proper position. so the camera mechanism draws it back and again pushes it out. this happens 3-4 times and if still the lense does not reaches its position it displays "turn the power off and on again" and the problem continues.
Your camera needs a repair of the lense assembly.
Posted on Jul 08, 2008
welcomejee
  • 10594 Answers
SOURCE: Lens cover opens only a **** on Sony DSC-W80
Please read carefully below procedure how to remove "Barrier Block" (what you call Lens Cover)..
Turn camera power ON so Lens will extend.
Take out battery so lens will remain extended.
First silver ring needs to be removed with help of tweezers as shown in below image..
Now you will see 2 screws at front of lens, unscrew to remove barrier block (lens cover) as shown in below image..
You need to have new barrier block with following part number..
A-1205-001-A BARRIER BLOCK ASSY
Subject part is available in Part Store
Install new barrier block as shown following image..
Insert battery and power up camera to check does barrier block works fine.
Need further info, let me know.
Good luck.
Posted on Feb 10, 2009
  • 65 Answers
SOURCE: Sony Super Steadyshot DSC W80 and lens keeps going in and out
Hi, Focal lens out of sync. camera cannot initialise. Lens requires manually resetting. If you in the U.K , I can help you out.
p.m me at kiddo242@hotmail.com
Posted on Aug 11, 2009
  • 43 Answers
SOURCE: I have a sony dsc-w80 that won't turn on. I
you have a bad power switch, you will need to take the camera apart and clean the inside of the switch with alcohol
Posted on Aug 18, 2009
MY Sony cyber shot DSC W35 camera's shutter is open and close repeatedly and asks for power off and restart but nothing is happening. PL advise
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera, press the RESET button located inside the Jack cover of the Camera using a sharp pointed object like ball pen or paper clip. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Jul 17, 2011 | Sony Cyber-Shot DSC-P52 Digital Camera
When I turn on my Sony Cyber-shot DSC-W35 the screen is dark with the word "Access" on it, moments later it tells me to power it off adn on again, any ideas?
Its lens error in your DSC-W35 camera.
Lens mechanism is either stuck or not retract completely and system control sense this error. Please replace lens assembly to get it fixed because lens mechanism is not repairable.
Thanks.
Dec 20, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
SONY CYBER SHOT NOT WORKING
Hello samtx930, "turn off the power and on again" its a very commen problem and occurs when the lens block assembly start malfunctioning. Actually the slide motor not work properly and until the lens not come out completely the camera will not work, that's why the error message appears "Access" and then screen shows "turn off the power and on again". In this situation you have to replace lens block assembly.And the part No. is with description is given below: 1-788-363-11 OPTICS UNIT (ED13A) Thanks for using fixya.
Jun 14, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
When the camera turns on the screen stays black and the lens will not come out.
Hello, "turn off the power and on again" its a very comman problem and occurs when the lens block assembly start malfunctioning. Actually the slide motor not work properly and until the lens not come out completely the camera will not work, that's why the error message appears "Access" and then screen shows "turn off the power and on again". In this situation you have to replace lens block assembly.And the part No. is with description is given below: A-1512-913-A LSV-1250A Thanks for using fixya.
Jun 14, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Access Probelm with DSC-W50 camera
abrakati,i have the same problem,still unsolved.however,to access the menu i depressed the button to view 'shots' taken.while in that mode i was able to access the menu but resetting did ****.i still get the same malfunction.chris.
May 27, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
Sony cybershot DSC-w5 shows error " turn power off and on again. The shutter is not opening at all. I tried tapping and slightly opening aperture but that does not work too. what needs to be done
    The LENS BLOCK ASSY is in problem the sledge motor is being malfunctioning. And you have to change the lens block assy.
You can contact any sony service centre nearby to you. For your convenience please visit:
www.sony.net
or
www.sonyworld.com
Here you can find contact info of nearest service centres.
Thanks for using FIXYA.
Jan 18, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony DSC-S500
you are right it has defective mechanism,  a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Oct 11, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Lens malfunction
hello, you are right. Actually there is some problem with lens assy.. When you turn on the camera the processor of camera start to check whole camera including mechanism. when it find something abnormal,it will not let to turn on the camera. This is the problem. I think there is some problem in lens mechanism and i and processor also suppose something abnormal in lens mechanism which makes buzzing sound. it is advisable to go to sony for professional repairs. hope you got it...
Aug 01, 2006 | Sony Cyber-Shot DSC-P92 Digital Camera
Sony Cyber-shot DSC-W70 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
