Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Ice maker door does not close - Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
  • 105 Answers
Maybe it has iced up
remove ice maker unit and check if there is ice build up there otherwise maybe door is deformed
you may need to replace
Posted on Nov 21, 2009
I have a GE Refrigerator that the ice maker keeps getting frozen up, I have changed the ice maker and the water valve out and it has started doing it again now...works good for a couple weeks maybe???
check the ice chute door,where the ice comes out of the door,sometimes the door doesn't close or it's broke,warm air gets up into the freezer and will start icing up everything the air hits,or the door gasket has a tear in it but if it's not water leaking from the ice maker then it's an air leak causing this issue.
Nov 02, 2017 | GE Refrigerators
Tip
Hot point side by side with ice maker
My Hot point side by side has water and ice dispencer, when we use the ice maker the trap door stays open we have to close it by pushing it with our finger. We tried some lubricant on the hinges still stays open. We were wondering if there is a solinoid that acuates the door closed.
on Apr 30, 2008 | U-Line CO2075F-B Echelon Refrigerator Ice...
Ice maker not working just changed the filter water works but ice maker not working
Check the plastic lever on the door. It usually moves closed when the door is shut to turn ice maker on. The lever can freeze and stop the ice maker.
Sep 23, 2013 | Whirlpool Gold GI6FARXXF 25.5 cu. ft....
Shoot door (flap) for ice maker wont stay closed causing frost
the gear that pulls it closed is bad. some have small plungers instead of gears
Oct 28, 2009 | Refrigerators
Ice maker is overflowing
Older icemakers have a bar that drops from above your ice bin; once the bin is full the bar is raised and trips turning the ice maker off so that it won't dump. If your's is this style, try manually pushing the free end of the bar upward so that it locks in the upward position. Newer ice makers with the ice bin in the door have a small panel that moves to the open position when the door opens and closes when the door closes. Mine also includes an optical sensor that is visible when this panel is in the closed position. Try placing a non-clear tape over the optical sensor (don't know if that will work or not but worth a shot). If effective in stopping the ice flow then call a repairman. If none of this works, turn off the water supply coming out of the wall to your freezer.
Sep 08, 2009 | Kenmore Freezers
No water in ice maker
check water supply
check water valve
check for frozen water tank
check if the ice maker is calling for water by cycling the ice maker (remove cover, put jumper wire between holes marked T and H close door switch and let ice maker advance till it clicks, remove jumper wire, close door and give it several minutes to activate water valve, if it never does you need a new ice maker.
Jul 14, 2009 | Refrigerators
Ice Maker abruptly quit
is the ice bucket in the door ? if not and there is water or ice inthe maker and your frezer temps are right[close to 0]the its the ice maker.some maker have a moduel you can replace but the surest way is to replace the whole maker.if bucket in the door theirs other posibilties.God bless,tom
Jan 02, 2009 | Maytag MSD2754G Side by Side Refrigerator
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
Ice maker
MAKE SURE THE DOOR CLOSER IN THE DISPENSER IS OPERATING PROPERLY. IT SHOULD SLOWLY CLOSE THE DOOR AFTER YOU STOP PRESSING ON THE PADDLE.
EITHER THE DOOR IS CLOSING TOO QUICKLY, NOT AT ALL, OR THE DISPENSER IS RUNNING AFTER THE DOOR HAS CLOSED. CHECK THE OPERATIONS OF EACH OF THESE AND SEE IF YOU CAN TELL WHICH.
Apr 03, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice Maker Making Noise
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
Feb 09, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
74 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
