Question about Sharp AL 1631 Copier
I've lost my manual. Does the red light that
I've lost my manual. Does the red light that looks like a cylinder or "drum" indeed mean I need a new drum rather than ink cartridge? Barbara
  • 34 Answers
The red light that looks like an empty cylinder on the Sharp AL 1631 Grayscale Copier panel is the "drum replacement required" indicator. The "cartridge replacement" indicator is represented by 6 dots forming a triangular shape.
The drum replacement indicator lights up when there are about 1000 copies left until its end of life. It is only when the indicator starts blinking that the drum really needs replacement.
The part number for the drum is AL-100DR.
I hope this helps.
Posted on Nov 19, 2009
How do i change the color of riso drUm from red to burgundy?
How-to: Convert Z-type Color Drums ' stencil.wiki
stencil.wiki/how-convert-z-type-color-drums Procedure for converting the color of a Z-type drum. Steps 1 - 9 also work ... Z-type Color Drums. Posted: 17 Oct 2014 14:04 by issuepress Last edit: 01 May 2015 14:20 by issuepress ... This tells the Riso to recognize newly installed ink tube.
Riso RP3505 drum color change - CopyTechNet.com
www.copytechnet.com > Forum > Technical Forums > Digital Duplicators Sep 9, 2008 - 3 posts - ‎3 authors Is there any way to change an RP color drum to black? How to change a drum color on a Riso MZ 770E? (I'm new ... 3 posts 8 Apr 2014 Riso gr3750 Drum versus GR377\GR373 Drums. 6 posts 1 Jul 2013 Riso RP3700 Print drums wont ink up 7 posts 28 Sep 2012 Riso GR 3750 alignment, drum and colour change ... 9 posts 3 Oct 2009 More results from www.copytechnet.com
change color drum riso Questions & Answers - Fixya
www.fixya.com > Forum > Tags Find solutions to your change color drum riso question. Get free help, tips & support from top experts on change color drum riso related issues.
Risograph GR drum conversion.mp4 - YouTube
z? 0:25 https://www.youtube.com/watch?v=YCttIfFdu0Q Jun 30, 2012 - Uploaded by SpareResidency Used citrus solvent to clean the exterior of an old red drum then switched the ink for a new tube of blue.
My Top 7 Risograph Lessons - Alfalfa Studio
alfalfastudio.com/my-top-7-risograph-lessons/ Jun 16, 2014 - When you need to add another color, you open up the drum door and change the drum to use purple, for example. The Risograph prints one ...
Replacing The Print Drum (cylinder) (color Change ...
www.manualslib.com > ... > Printer > RZ1090 > User manual Riso RZ1090, RZ1070 Manual Online: Replacing The Print Drum (cylinder) (color Change), Replacing The Print Drum (cylinder) (color Change), Removing The ...
Riso printing - Instructables
www.instructables.com/id/Riso-printing/ Risograph The underlying technology is very similar to a mimeograph. ... This master is then wrapped around a drum and ink is forced through the ... Change the color drum, change the paper on the glass sheet, make a master layer and . ... Remember that every different color you want to print, you have to print separate.
Jan 31, 2016 | Office Equipment & Supplies
Why it prints grey background
Either the toner cartridge is very close to empty or the drum unit needs to be replaced. Check your warning lights. Yellow = toner, red = drum. If no warning lights, pull out the toner/drum unit and remove the toner cartridge. Have a look at the cylinder in the drum (DR2125) - if it is very black and matt looking you will need to have it cleaned or just replace it.
May 20, 2014 | Brother HL-2170W Laser Printer
My Sharp AL 1000 has quit copying!
The triangle or stack of 6 dots is the toner cartridge light. The drum light looks like a cylinder or aa battery.
If you open the right side door, then the front door you will see the 2 cartridges. The toner cartridge is on the left and should have a large green button you push down on to release and slide out. Later or when needed you can slide out the drum cartridge AFTER you remove the toner.
You might have a local source to get your toner cartridge refilled. Or just order a new one and unpack it, then slide it in and your all set.
About $50 for refill or about $100 for new.
Good Luck
Nov 25, 2009 | Sharp AL-1000 Copier
Brother Printer HL 5250DN
A solid red STATUS light with a solid yellow TONER light indicates toner out...replace according to pg. 63 in the manual.
It can also indicate a cartridge position error. Take the DRUM UNIT out of the machine and re-install.
A solid red STATUS light only means:
Front cover open
Fuser cover open
Dust on drum
Too many trays
Buffer error
Print overrun
Memory full
Download full
Font full
See pg.48 ofthe manual.
Oct 02, 2009 | Sport & Outdoor - Others
Brake petal goes to the fioor once and well.
you have indeed changed almost everything.  and sadly many parts that you didn't need changing.  Could you have a bad hose at the wheels or a leaking caliper?  if all else fails I would start by blocking off one circuit of the braking system...with a plug, and checking for leaks in the active system and then switching sides.  Is the system being totally bled?  that means first at the master cylinder, then at the abs cluster and then each wheel...twice.
Mar 30, 2009 | 1997 Plymouth Breeze
Red light
The triangle dots are "need toner"
the cylinder is "need new drum"
the jagged line W means "paper jam"
Sep 16, 2008 | Sharp AL 1631 Copier
Red cylinder looking error message
That is the drum replacement indicator. Timing on those things can make a person insane at times.
You need to now replace the drum cartridge.
Mar 21, 2008 | Sharp AL 1631 Copier
Sharp AL-1641CS Lase Copier
http://www.retrevo.com/s/Sharp+AL-1641CS?rt=pd
Here is the location for your copier manual. You'll be able to view & download. Good Luck :0)
Jan 10, 2008 | Sharp AL-1641CS Laser Digital Copier
Sharp AL 1631 Copier Logo
234 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
