Question about Chips Computers & Internet
Bought a ultimate tuning and performance chip that wires in on my 96 f350 but dont know where it gos
The (magic) chip connects to your IAT (intake air temperature) sensor, you can usually find it by your air filter. I do not recommend using this (as I've said) magic box because it is simply an expensive resistor that will make your car think it is running colder than it is, resulting in hotter running temps and wasted fuel.
Posted on Aug 27, 2010
    Brigadier General:
  • 10,406 Answers
Buy the Service Manual for the 1996 Ford F-350, and follow the instructions.
Or, look at all the chips on the firewall -- look under the protective covers, too.
Posted on Nov 19, 2009
What two wires on my iat do i hook up my innovative performance chip up to in my 2006 toyota tacoma
your what ? into what ? on to the alternator of a toyota
The implicit-association test (IAT) is a measure within social psychology designed to detect the strength of a person's automatic association between mental representations of objects (concepts) in memory.
the proper way to hot chip tune is replace the main chip inside the toyotas ecu
external plug in performance chips have been proven useless
http://www.gainmpg.com/performance-chip-for-toyota-prius
Apr 28, 2017 | Toyota Cars & Trucks
Won't idle, runs rough under throttle
Check all of your tune-up parts. (Distributor Cap, Distributor Rotor, Spark Plugs and Spark Plug Wires) Also perform a compression test if no problem is found with the tune-up parts. Check also for vacuum leaks and the Intake Air Control Valve (IAC) for the "won't idle" problem.
Apr 10, 2011 | 1990 Ford F350
I want to know which IAT wires to tie into for my new performance Chip. I have a 1994 Toyota 4-Runner with the 3.0 Motor. Thank you. Oh yeah, there are 6 wires that I found. Only 2 go to the IAT.
That chip is a waste of time and money, and your mileage is going to suffer. Why dont the instructions tell you which wires? The THA terminal is wire color Yellow/Black. the E2 wire is Brown/Black.
Dec 23, 2010 | 1994 Toyota 4Runner
I dont know what gos to what
Radio 12V- white/yellow
Radio Ground black
Radio Ignition yellow/red
Left Front Speaker (+/-) blue/green - gray/black
Right Front Speaker (+/-) red/green - brown/black
Left Rear Speaker (+/-) blue/yellow - gray/white
Right Rear Speaker (+/-) red/yellow - brown/white
Jun 08, 2010 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
Need a pic veiw of 2004 ford f350 6.0L diesel EGR
1st of all when Ford started out with putting "EGR's" on those diesel engines, they rushed it and are nothing less than a pain in the ***! i recommend having an EGR cleaning service performed by your local Ford dealer, i know they charge up the wazoo, but they're the best people to perform the service period.this is a VERY common problem with those engines and that service is "supposed" to be performed every 30K I believe. i dont recommend attempting to remove and service it youself, this WILL only make it worse.
Mar 26, 2010 | 2004 Ford F350
02 sensors wiring
The yellow and white wires take any white wire.I dont now why they dont tell you that.And just fit black to black and grey to grey that simple good luck pippall.
Aug 08, 2009 | 1996 Jaguar Xj Series
How do you change the glow plugs and relay in a F350 1997
Hello, here is the proceedure. Any questions please ask. Good luck. CAUTION The red-striped wires on the 1994-96 DI Turbo engine carry 115 volts DC. A severe electrical shock may be given. Do not pierce the wires.
  1. Make sure the ignition switch is OFF.
  2. For 1994-96 engines, remove the valve cover.
  3. Disconnect the wire connector from the glow plug.
  4. Using a 10mm deep socket, with enough clearance as to not break or bend the wiring connector, unscrew the glow plug from the manifold.
To install:
  1. Place anti-seize on the threads of the glow plug and screw it into the manifold.
  2. Tighten the glow plug to 12 ft. lbs. (16 Nm).
  3. Plug the wiring connector.
  4. Connect the negative battery cable.
  5. For 1994-96 engines, install the valve cover.
0900c152801cd773.jpgFig. 4: Disconnect the wire, then remove the glow plugs as shown
Jan 23, 2009 | 1995 Ford F350
Sluggish '96 chev 4x4
id start off with a basic tune up..you never know when u first buy a car when this stuff was lasted checked up on..i would first change the fuel filter if its clogged its really going to slow you down..then i would do and oil change to it and maybe the plugs and wires..check all of the fluid levels especially the transmission fluid..if you want to add horsepower and performance i would put better oil better wires and plugs and maybe a k&n filter instead of a paper one..
Oct 28, 2008 | 1996 Chevrolet K1500
Computers & Internet Logo
2,635 people viewed this question
Top Chips Computers & Internet Experts
Alun Cox
cwradio73
Are you a Chips Computer and Internet Expert? Answer questions, earn points and help others
