Question about Car Audio & Video
1994 ford f150 i have no power to radio - Car Audio & Video
    Problem Solver:
  • 5 Answers
Check the fuses in the back of the deck and your main fuses for your car also check the battery wire, ground, and ignition wire.... check to make sure everything is tight to so its not loose.... you may have to bypass and make your own power wire to your battery in case you maybe shorted out your factory amp or shorted something else out.... those few things at the top would be what i would check first though
Posted on Nov 19, 2009
  • trentonbutle May 11, 2012
    How would you run the power to the radio from the battery
1994 Ford F150 will not start.
I had that happen also.
I discovered the steering column was worn out on the inside.
There are parts inside the column that can break or wear, causing this.
Options are a used steering column or a really good mechanic to tear it apart and try to fix it.
Those particular parts may not be available anywhere except a junk/salvage yard.
God bless your efforts.
Jul 21, 2016 | Worldwide 1994 Ford F150 Pickup 4.9L...
1994 ford f150 suddenly goes into a high idle.
Just an F150? no further information......... I'll give it a shot.
Possable causes
Bad power steering pressure sensor
Bad IAC Circuit
Intermittent Vaccume leak (V8's have this issue with the PCV tubing)
Floor mat stuck over throttle :P
Oct 23, 2013 | 2004 Ford F150
Seat belt light flashing 1994 ford f150
check for a bad buckle switch jump it with a paper clip to test it
Oct 06, 2012 | Worldwide 1994 Ford F150 Pickup 4.9L...
Can i set the idle on a 1994 ford f150 4.9liter
if this prob has appeared after bin running fine check fuel filter /fuel pipes then air filter injectors or carb jets if was running fine then no ajustment needed
Aug 12, 2012 | Worldwide 1994 Ford F150 Pickup 4.9L...
1994 Ford F150 Head light bulb
i will assume you mean the headlight bulb. in the engine compartment directly behind the middle fo each headlight is the plug and bulbs. turn the round piece(will be either gray or black) and the bulb pops out. install is reverse of removal.
Oct 17, 2008 | 1994 Ford F150 Styleside Supercab
Speed Control and Radio don't work
check with your dealer on the speed control i have received many letters about that as a recall problem.
Oct 09, 2008 | 1994 Ford F150 Styleside Supercab
1994 F150 Ford
could be a tps sensor or map sensor. have truck scanned for exact codes
Oct 07, 2008 | 1994 Ford F150 Styleside Supercab
Car Audio & Video Logo
43 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
