Question about John Deere Garden
Jd 05 i think 4310 wont move fwd or rev trouble code flashes four times one short ,long, short, short?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 197 Answers
This is fault code 1.Fault-forward pedal.Cause of fault-Voltage signal out of range.Result of fault-Output current zero machine does not drive.Required action-get signal in range,,,recalibrate sensor.If this code does not match up to your symptom let me know and I will look into it.
Posted on Nov 19, 2009
How to remove starter jd 4310 ?
It probably the starter relay, or ignition switch. What does it do when you try to start?
Jul 23, 2014 | John Deere Seat 4210 4310 4410 4510 4610...
05 harley sportster signals flash 6 times, won't start, diconnected batery, reconnected got d1a9 code
With a TSM if the four-way flashers flash 6 times shortly after the ignition switch is turned to ON you should check for DTC's that have been set. d1a9 is not a 2005 Sportster code.
Apr 17, 2014 | 2010 Harley Davidson XL 1200N Sportster...
4310 john deere e hydro
call the dealer for a service call.
Mar 12, 2014 | Garden
4310 john Deere e hydro
Check to make sure the brake is completely return to the off position, all the way back, it cancels the cruize when depressed
Mar 12, 2014 | John Deere Garden
1989 toyota sr5 transmission
i would say if you have a lot of oil everywhere you have some kind of source where the oil is coming from power wash area and check where this oil is coming from repair as needed or may require total rebuild
Jul 13, 2013 | 1989 Toyota Pickup SR5
JD 4310 tractor hydro problem
Jeff I am having the same problem. Have you found a fix for this yet? your post is right on but for some reason we are the only two withthis problem and my local jd dealers have never seen this. , Brent
Jun 16, 2012 | John Deere Seat 4210 4310 4410 4510 4610...
John Deere indicator code
Call your JD dealer they should help you it could be as simple as a light bulb out.
Oct 22, 2011 | John Deere Seat 4210 4310 4410 4510 4610...
My John Deere 4310 compact tractor hydrostat transmission does not work. I got on top of a tree stump and now it will not move. Trouble code light flashes one long then three short flashes. Please help.
You likely knocked a wire out of the forward or reveres potentiometers,which are located under the right floor pan and are attached to the foot pedals.If they are in place then they may have bee hit and now need to be re-calibrated,if so call your J.D. dealer.
Jun 14, 2010 | John Deere 4020 Gas & Diesel Tractor...
Complicated GE clock radio/CD player
To set the time:
Hit the SET Wake/Time Button closest to the CD player until the clock face appears in the bottom left hand of the display.
Use the TRACK Rev Search Fwd Arrows to adjust the time.
Rev will decrease by minutes and Fwd will increase by minutes.
Hope this helps.
Jan 10, 2008 | Audio Players & Recorders
Garden Logo
489 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
