Question about Whirlpool Duet GHW9150P Front Load Washer
I can hear a coin rattling under the drum of my duet front load washer. How can I remove it?
  • rjhahn May 11, 2010
    Take the front panel off under the door. It will be either a phillips or a star bit.
  • Whirlpool Master
  • 3,463 Answers
If I were you, I would leave it, and it should find it's way into the filter.
To try and remove it is quite an involved task.
Please rate my solution.
Thanks.
Posted on Nov 19, 2009
Even after removing and cleaning the filter in the whirlpool elite washer, I still hear a coin like rattling sound, also the water is not draining properly. What's my next step? Mike
check the drum veins you may need to remove the top of the dryer or lift the lid to get at the screws to the drum veins. remove each one clean them out and this should solve your problem
Feb 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Sounds like coins between the basket and drum. How do I remove the coins?
If it has baffles for washing, check to see if you can lightly press the baffle to one side (press firm but don't snap it out) while rotating the drum by hand. I do this with my Whirlpool Duet and the coins eventually just slide out and into the drum where I can see them.
Dec 06, 2010 | Maytag MAH8700A Front Load Washer
I have many coins under the drum of my washer,
Yes, it is. You must first remove the screws in the top and the front will come off easily afterwards.
We hope this information is helpful to you.
Thanks, Ella
Nov 17, 2009 | Washing Machines
Front load washer sounds like a marble is loose
You washed something from your pockets. coins, marbles, I even removed a nail clipper before. Use a flashlight and try to look through the holes. If you can get front panel off. Put light under tub and see if you can see something that way.
Oct 22, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
LG WM2077CW small item trapped behind drum
you would need to remove bottom exit rubber pipe from drum and use a flash light to free coin or screw,hope this helps
May 27, 2009 | LG WM2077CW Laundry XL Front Load...
Coin stuck in front loader washer
GO TO www.repairclinic.com IN THE BRANDS WINDOW CLICK ELECTROLUX THEN IN APPLIANCE TYPE CLICK WASHING MACHINE AND LOOK FOR PART 1154917 CLICK ON THAT PHOTO AND LOOK AT ADDITIONAL PICS.YOU WILL SEE THAT IT SNAPS INTO PLACE. FROM HERE I THINK YOU CAN TAKE IT OUT AND RETIEVE YOUR COIN. GOOD LUCK
Apr 24, 2009 | Electrolux AWF1235 Front Load Washer
My Whirlpool duet washer is not draining. I am
If you hear the pump running and not draining, then take the toe panel off. Should be 3 1/4" screws on bottom. Remove the "coin catch". It looks like a BIG screw and it's white. Turn counterclockwise. There may be a sock, change ect...clogging it up. Dump it out and run machine. Have towel or bucket ready when removing coin catch.
Mar 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Coin trapped between rotating drum and casing
Get underneath the machine and remove the big black house coming directly out of the drum,this is held in place with either a screw tie or pinch type tie.
Put the machine back level and see if the coins drop out (they should) or have a feel around inside the drum.
Please make sure machine is unplugged and empty before carrying out this procedure.
Some water will come out of hose.
Nov 19, 2008 | Zanussi ZWF1430W Front Load Washer
Whirlpool Duet Sport Washer from Costco
remove the sump hose from the outer drum and try to fish it out with a bent piece of wire. the sump hose is usually at the bottom of the drum and after taking it off will leave a hole big enough to remove the object
Jul 24, 2008 | Washing Machines
Coin stuck under tumbler on Duet front load washer
If you dont have screws on your tumbling vanes, you can take a very small screw driver and lightly lift the vain enough for the coins to slide out.
Oct 18, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet GHW9150P Front Load Washer Logo
369 people viewed this question
Dan Webster
Dan Webster
Sal De
