Question about Sunbeam 4039 Iron
HI, I DONT KNOW HOW TO OPEN MY SHARK RETRACTOR IRON, IT HAS 2 SCREWS AND I PUT THEM OUT....BUT THE PROTECTOR DOESN´T RELEASE....HELP
Right below the button that you press to select fabric is that black rubbery piece. Use a screw driver to pry it up and then remove the three screews holding down the rest of the retracter. Mine was getting power to the circuits so I trashed it. I won't ever buy this brand iron again has it did not last very long.
good luck
Posted on Dec 15, 2009
The power cord on my Shark model #G146810 is loose and doesnt heat, can this problem be fixed?
Hi!!
It should be an access plate fasten by a couple of screws right below the power cord, remove them and fix the cord's terminals/contacts or the cord itself.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Mar 19, 2011 | Euro-Pro Shark GI490 Iron
My shark iron get hot but it will not put out any steam none
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Sep 26, 2009 | Euro-Pro Shark GI490 Iron
Steam iron will not heat.
pry rubber feet from the bottom below the two lower screw holes there two screws under the rubber feet :)
Jul 30, 2009 | Euro-Pro Shark GI490 Iron
My Shark iron is 2 months old and just suddenly stopped working. No heat no lights Is there some setting I don't know about?
All the settings should be visable..
Check the return policy where you got it..
I know that Wamart has a 90 day return on these type of things..
Hope this helps !!
Rate me good ;o)
Jul 10, 2009 | Euro-Pro Shark GI490 Iron
Shark euro-pro iron cord replacement model 4750
six screws on bottom plate two hidden under rubber feet on bottom under lower screw holes
Nov 18, 2008 | Euro-Pro Shark GI490 Iron
Shark Iron
The brown residue is probably caused by iron in the water. I would suggest you put a solution of half vinegar and half water into the water chamber and leave in the iron overnight.
Then switch it on to steam and holding the iron over the sink or over an old towel, the dirt (residue) comes out of the holes on the soleplate. Sometimes if the iron is badly scaled you might need to repeat the descaling.
Once complete fill with water and steam away, to flush any of the remaining vinegar out of the iron.
Depending on how often you use your iron and how much iron is in your water, you might consider performing this flush process every 2 or 3 months. It will help extend the life of your iron.
Good Luck
Aug 11, 2008 | Euro-Pro Shark GI490 Iron
Shark euro pro x
We fixed ours today. Take the iron plate off (bottom of the iron shaped like a triangle). You are looking for a thermal fuse (or thermal-protector fuse) pictured here for less than $2 at Radio Shack(http://www.radioshack.com/product/index.jsp?productId=2102788&CAWELAID=107599331). You will need needlenose pliers to gently remove the old fuse and the wire cutters to trim the long wires to the same length as the old fuse (less than 1/2"). Also, since the old fuse was 240 C and we only could find a 228 C replacement - we cannot use the iron at the same high temp. So we limited the dial by marking out a portion of the dial. The iron stopped working after I kept the iron on high for an extended period of time. My electrician husband explained that I over heated the iron - breaking the fuse. Not time I'll turn the iron off or down when I'm not using it. This was so easy, I'm going to check out our other broken irons.
Jul 05, 2008 | Euro-Pro Shark GI490 Iron
Sunbeam 4214 Clothes Iron with Retractable Cord won't heat.
first, i'll apologize for not posting pictures with this, but i didn't have a camera handy when i "fixed" it. i'll do my best to explain the sitch.
i also have a sunbeam 4124 whose retractor was jammed...the cord would not release more than two feet or so, nor would it retract. i was able to disassemble it, but broke some internal retaining clips meant to hold the retractor housing to the iron. WARNING!! do not attempt this if you do not want to void your warranty. i can only assume that the manufacturer did not want you to disassemble the cord return housing and as such, hid the retaining clips where it would be impossible to disengage them. i got lucky and only broke one set of the retaining clips....if you carry on, you stand a chance of breaking both sets, which will not allow you to reattach the retractor housing to your iron securely. best thing to do is call sunbeam and have them send you a new iron, but if you're bent on fixing it yourself, here's how i did it (you'll need one medium philips head screwdriver):
1) remove the rubber feet from the bottom of the iron. this will expose two screw holes (the third foot under the retractor button has no screw; this is the side where the reaining clips are buried).
2) remove the two screws
3) WARNING! this is where you have a good chance of breaking your iron. pull the base of the iron really hard, rocking it from side to side. there are two sets of retaining clips recessed in the housing of the iron. the button will come with the base of the iron, the entire cord retraction assembly is self-contained. you can carefully use a screwdriver to pry the two halves apart. also, be careful not to pull too hard as the electrical connections between the iron and the retractor assembly has only about 2 inches of slack, though the connections are just wire-nut'd together and could be reassembled in a pinch.
4) after the retractor housing is separated from the iron, remove the housing cap by unscrewing the four screws.
5) carefully separate the two halves of the housing; the spring may be loose inside and could snap out at you.
here's where my iron was broken....the coil spring is contained by a plastic tray that had snapped, probably due to somebody pulling the cord out too hard. a section of the tray had jammed itself into the inside of the housing, immobilizing the winding mechanism. my only recourse was to completely remove the spring and permanently extend the cord all the way (not one of the features i bought the iron for anyway, so what the heck). PLEASE be careful unwinding the spring if you have to do it....wouldn't want anybody poking out an eye inadvertantly.
6) reassemble the retractor housing by screwing the cap back on with the four screws
7) if you're lucky enough to keep one set of retainer clips, snap the base of the iron back on and reattach the two screws located under the feet.
8) rubber pads back in and voila!
hope this helps!
Mar 17, 2008 | Sunbeam 4214 Iron
Retractable cord
hope this helps!
Jun 12, 2007 | Sunbeam 4214 Iron
Sunbeam 4039 Iron Logo
274 people viewed this question
Top Sunbeam Irons Experts
Tony
Wayne Fellows
Wayne Fellows
Craig Butler
Craig Butler
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
