Question about Sharper Image Ionic Breeze 3.0 Air Purifier
It worked well until I plugged it in to a non-grounded receptacle. Now it doesn't turn on. What do I do? Bruce
  • 546 Answers
It's likely Ground Fault GFI 'compliant' and needs to be grounded.look for a GROUND ADAPTER PLUG at a home improvement or hardware store.It's an adapter with three holes on one side ,two prongs and a wire on the other.connect the wire to the screw in the center of the receptacle cover to ground it.
Posted on Nov 19, 2009
Ionic breeze wire
I tried the guitar strings, they burned out quickly. The wires that came in the unit are not steel, they are not affected by a magnet. We suspect they may be tungsten or some other type of non ferrous wire. Until we find the right wire, we cannot repair them to last. Any assistance in locating the correct type of wire for use in ionizing air cleaners would be appreciated.
Jun 15, 2014 | Sharper Image Air Purifiers
Hand vacuum doesn't charge
If the plug in charger works, the batteries are boiled out and need replacement.
They should not be left on charger all the time. Just charge them for 10 hours and use them until the performance has dropped off, then and only then put it back on charge for 10 hours.
Sep 28, 2012 | Dirt Devil Extreme Power Wet Dry Hand...
Why it do not turn on?
You need to check a few things: 1. Is the plug in the back fully seated into the plug receptacle?
2. Is the filter in the back installed correctly so the plastic tab is depressing the safety switch?
3. Do you have a ceramic plate installed in the grooves with the metal tabs touching on both sides?
Erich
Jul 27, 2011 | Alpine Air XL-15 Air Purifier
I "won" a Rainmate from
No, not that I'm aware of. But, the problem itself, may be in the electrical receptacle. A loose wire, a bad connection or interior damage could all cause the circuit breaker to trip. Or it may simply be the case, of line that air purifier is plugged into, is simply overloaded, because of other electrical appliances are on the same circuit of tripped the circuit breaker. Most air purifiers have their on circuit breaker or fuse built-in to the unit. And that, will usually trip before the circuit breaker in the breaker panel of your home.
Here's how you test that theory: Plug the unit into another outlet, that is on an entirely different circuit than the original one and turn it ON. If this trips a different circuit breaker, then you know it's an internal problem with the unit. If it doesn't trip the circuit breaker, the problem is with the original receptacle or the line that feeds that receptacle and it's circuit breaker.
Hope this helped you to troubleshoot and solve the problem.
Jun 13, 2011 | Rainbow Rainmate Air Purifier
It will not turn on it says it locked how do i get this off of the screen and get it to turn on quiet flow is the nameof it
Crystal, first turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12-15 minutes before plugging the unit back in. After you plug it in, turn the Master ON/OFF Switch to ON and set the controls as you wish. Hopefully, during that 12 - 15 minute timeout, the unit reset itself and should now work normally.
If that doesn't solve the problem, you can call Hunter Technical Support. In the US dial 888-830-1326.
In Canada dial 866-268-1936
Apr 15, 2011 | Hunter Air Purifiers
My Ionic Breeze Model S1637 just stopped working and I don't know what to do. Is there a solution for this. It appears as if the unit is not getting any power?
Test the outlet that it's plugged into, to make sure it's still functioning properly. There may be a loose connection at the receptacle or the circuit breaker in your home's circuit breaker panel, for that receptacle may have been tripped. If it is, before resetting it, make sure the air purifier is not plugged in to it. Then plug the unit in and turn it ON. If the circuit breaker trips again, there's a wiring short in the air purifier. Contact Sharper Image for possible repair or replacement.
Apr 04, 2011 | Sharper Image Ionic Breeze 3.0 Air...
WILL NOT START....NO POWER? BOUGHT AT SEAR JUNE OF 2010. HONEYWELL MODEL 17000
Make sure that the receptacle that it's plugged in to is still working. The circuit breaker for that outlet may have been tripped in your home's circuit breaker panel. Or there may be a loose wire or bad connection inside the outlet box. May not be air purifiers fault at all.
Mar 29, 2011 | Honeywell 17000 Air Purifier
Trouble indicator came on after a power outage and
When was the last time the backup battery was checked? The trouble indicator could mean a weak or non-working battery. If the system is 12 years old, the battery should be changed.
Mar 07, 2010 | Air Purifiers
Working Fine UNTILL I unglugged it and cleaned it.
I don't actually know how I fixed it. I left it unplugged for about 24 hours. I assumed that because I did not ground it, that maybe it eventually unground itself. I have no clue. I do know that my friend who was trying to help me cracked one of my ozone plates because they no long came on. I'm planning to replace the plates and I figure it will work fine. Thanks.
Sep 07, 2008 | Alpine Air XL-15 Air Purifier
Red Light on front of Filter Queen Defender
When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking. It cured my problem.
Mar 06, 2007 | Filter Queen Defender Air Purifier
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
125 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
