Question about Ricoh Aficio 2015 Copier
Ricoh aficio 2232c sc542 error - Ricoh Aficio 2015 Copier
  • Ricoh Master
  • 19,396 Answers
SC542 means that the thermistor hasn't detected right temperature in given time.
Often you only have to reset service code.
Try this reset:
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
from http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/ here is another service procedure:
  • Press Mode(The Yellow Button)
  • Enter 107
  • Press STOP Button for 3 second (RED Button)
  • Copy Sp
  • 5810#
  • Execute
  • Power Off
  • Power On
Posted on Nov 19, 2009
  • Ginko
    Ginko Nov 19, 2009
    The reset is different for each Ricoh model try this:
    press the yellow “C” button
    enter 107
    press the red “C” button and keep it hold till the display changes
    turn the power off with the big red switch on the front side
    turn power on again.
    If that does not work there are more models here :
    http://www.fortc.com/2007/06/17/ricoh-cl...
    2232c is not listed but must be compatible with the procedure above. The above works on the similar model 3228c
  • fineline362 Feb 14, 2011
    The second list of procedures is the correct one for the 2232c. Power on/power off must be done with red main switch.
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Ricoh Aficio 2232C Error Message SC393-02
I had the same problem after transit of copier. Try removing the yellow developer unit and give it a good shake. You may need to do it with the other units too.
Apr 16, 2013 | Ricoh Aficio 2232C Color Copier
I have error fc 824-1401 on my ricoh aficio 2232c. i need help
Self-diagnosis error: Standard NVRAM The controller cannot recognize the standard NVRAM installed or detects that the NVRAM is defective • Loose connection • Defective standard NVRAM • Defective controller 1. Turn the main switch off and on. 2. Check the standard NVRAM is firmly inserted into the socket. 3. Replace the NVRAM. 4. Replace the controller.
May 13, 2010 | Ricoh Aficio 2232C Color Copier
Ricoh aficio cl7300 error sc542 what does it and how do ifx it
This error is power related... their are two possibilities either... your fuser is blown or your machine needs a reset... here is a link to try the reset...
the reset should be all you need...
reset link
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Feb 08, 2010 | Ricoh Aficio CL7300 DT2 Laser Printer
My Ricoh 2232c copier has displayed error SC374 can you tell me what this means?
SC322 Laser synchronization error SC324 LD drive current over SC390 TD sensor error 1 SC374 Development bias leak SC393 TD sensor error 2 SC401 Transfer roller leak error 1
Jan 14, 2010 | Ricoh Aficio 2232C Color Copier
Ricoh Aficio 2232c printer without power. Need to
The main fuse is close to where the cord plugs into the machine. You can follow the wires, (black white and green) to an inline fuse or the main power board.
Sep 22, 2009 | Ricoh Aficio 2232C Color Copier
Ricoh Aficio 2015 Copier Logo
3,383 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
