Question about Cell Phones
Stopped charging - Cell Phones
Why does my Tp Link M5350 3G wifi turn on and off?
When ”high temperature” shows on the OLED screen, the device is too hot, so place it in a cool, ventilated location. When the temperature is high enough, the device will stop charging/functioning in order to avoid damage.
This device responds to overheating whether or not it is charging.
When the device is charging:
• The device is powered on. When the temperature is higher than 113°F/45°C but lower than 140°F/60°C, it will not show “high temperature” but it will stop charging.
• The device is powered on. When the temperature is higher than 140°F/60°C, it will power off & stop charging. Also the OLED screen will show ”high temperature” at that time.
• The device is powered off. When the temperature is higher than 113°F/45°C, it will stop charging & the OLED screen will show ”high temperature."
When the device isn’t charging:
• Only when the temperature is higher than 140°F/60°C, will the OLED screen show “high temperature” & this device will power off.
May 04, 2015 | Computers & Internet
My visual land android tablet wont charge it started to charge then jst stopped
If it just stopped charging and you have tried other chrgers, then the probable cause would be the battery for the tablet has failed. This is fairly common and would require disassembly of the tablet and replacement of the battery to fix.
Feb 15, 2015 | Visual Land Prestige 7L Android 4.1 Jelly...
"Charging error: Stop charging!"
sir please give to the sonyericsson service center to change the charging jack of the phone and they will check the battery status of the phone.for charging in a normal condition
Dec 23, 2010 | Sony Ericsson K618i Cellular Phone
Phone not charging,display says error stop charging
If your phone is not charging and the screen read error stop charging, you can look at the problem from angles, firstly, i suggest you try get a similar charger to charge the phone and see if it will charge it, if it does, it means the charger your charger is the problem and will need to be replace.
But, if after trying to charge with a similar charger and the screen of your phone still reads error stop charging, then, the problem is the charging port of your phone. In this case, you will need to replace the charging port of your phone, in order for your phone to charge.
Check either of the two stated above to solve the problem with your phone.
Take care.
Jul 17, 2010 | Sony Ericsson Z610i Cellular Phone
Sony NW-E505 player stopped all functions while charging from computer
That's normal. While it's charging the only thing it does it charge.
Nov 05, 2008 | Sony NW-E507 MP3 Player
Sony ericsson k8ooi
i was charged my mobile k850i then one massage came my mobile seirious error,stop charging your mobile, stop using & plese contact sony ericsson call centre.
Aug 12, 2008 | Sony Ericsson K800i Cellular Phone
Kenwood dpx 4020
The iPod will stop itself from charging when the battery is full, and will not overcharge. I'm pretty sure you can't disconnect the power to the iPod (would stop it from charging) and still use the Audio to your stereo.
Aug 19, 2007 | Kenwood DPX-4020 CD / Cassette Player
Sansa won't hold a charge
change the battery you can buy it at sandisk.com.
Aug 14, 2007 | SanDisk Sansa e250 MP3 Player
Cell Phones Logo
41 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
