I have a dv4017ap laptop ... was working properly yesterday my daughter closed the laptop without shutting down and now the laptop is completely dead
  • simon_rob560 Nov 19, 2009
    i have a dv4017ap .further to previous emails i was using a car charger to keep the machine powered up
    i changed the battery,the power supply,and no change ...the machine is totally dead
    i put the car charger back on it and it blew a fuse in the fitting
    machine is still dead
    any ideas??
    i have changed the power lesd and the battery .....
    i have tried to power up the machine with no battery and different lead
    i dont know whether or not you got my last post about thre machine running on a car charger yesterday..was working perfectly and charging normally for over 8 hrs
    i put the same charger in today and blew a fuse in the car charger
    it charges my other machine perfectly after changing the fuse
    even put my battery into another computer it worked perfectly
    something has fried in the puter as it blew a fuse ....is it too much to hope its the pin where the power supply goes in????
  • Computers & ... Master
  • 1,113 Answers
Hi, I'm Steve, Can I get you to try something for me, please remove the battery pack, and power the unit just from the wall adapter without any battery installed.
I have seen battery's give out their last breath, and when some do they develop a short circuit not only effecting battery but all power trying to get to machine.
If this doesn't help please confirm a few of the following and we shall dive deeper
- Is there a light on the adapter itself to indicate power?
- Do we get any lights on laptop, or lke a display flash on power ups?
Hope it is a simple as a dearly departed battery, if we have no power at laptop then first step really I do as a teco is confirm power at the power adaptors output with a multi meter, but some have a light on the power supply so you can tell it is working as these often fail too
If all of the above and you have double checked the wall outlet several times, and the adapters working and the battery not dead, then at best it is the connector that goes from the adapter into the lappy, it cops abuse over time and breaks internally.....and if not then it is the motherboard, and that pretty much is the end of the story.
But if we have light (any light) there is hope.....;)
Hope this helps
Cheers
Steve
Posted on Nov 19, 2009
  • Soulvisitor
    Soulvisitor Nov 19, 2009
    Please confirm you have run it without any battery pack installed, from any known source, otherwise it is the same as my own.... burned on the power circuitry, it may go direct short on main P.C.B or open, but if the adaptor works and battery is not installed and plug is good, then it is a right off with any lappy, main boards only get changed by warrany customers or fools with too much money....., afraid if you open it up you will find a section of burned components, all main board, all not ecomomical to repair...no fuses to play with, no componts to change, welcome to our modern world... all compact intergrated one board chuck away babys...
    Might have to get a second hand one, for quite cheap, no point in new ones really, people are always just upgrading and discarding last years quite fine ones, governments do rollouts of the new and all the old go cheap at auction with licenced software in most cases,... greys online, I have found works for me, then you can just switch you hard drive, go threw about 2000 window driver updates ;), and all will be as good as old.
  • Soulvisitor
    A very very few of the lappys come into the workshop dead and with good power supply and it has turned out to be a resolder of the power socket pins, but there few and normally seem to be HP's, and it has sometimes worked although time costs, renders it not worth chasing the faint hopes of customers, the boards are multilayer, if it is the socket then you should be able to get light with a wiggle, but for it blow fuses, that's a short and not a disconnected solder joint..direct short...compontent burn and melt...
    .....sockets.dry joints tend to cause open circuit ie disconnection, to get a short we have a bridge of electricity, does not happen from breaks normally. If we had it even on a wiggle, one is going to have to strip it, spend 2-3 hrs, and try to reolder and reassemble.
    There not a brease, and break very easy, many tabs and connectors and cables, they are not designed with much regard for disassembly, although it is possible, keep note of long and short screws placement to prevent inflicting more shorts, be ultra carefull on connectors to ensure to release any clasp prior to pull the correct direction without too much gusto.. , Pull off the little covers for the Hard drive, Ram, inside you will see marked screws K or an arrow, these release keyboard, then remove keyboard, without bustin the clips, then more screws, disconnect monitor cable, remove hinges, remove screen...remove cover screws, to release top shell from bottom, remove main board from base to get to underside...still with me?
    Anyway before this stage you know it is not supply, so your option is, take a look....there is always hope if one looks, but from here without looking, hearing I have no lights ever, ensured supply, no shorted battery pack, Mister Wiggle wont help, then I know it main board, they don't like being soldered, but there is certainly no harm in removing all screws, your going to need to strip it, to get to bottom soldered side of suspected power inlet connector which is soldered directly to main-board, try you luck, there is nothing to lose but time and Patience.
  • 11,896 Answers
Remove battery, press and hold power button for 3 seconds, wait 5 more minutes, put battery back in and turn it back on.
  • 1 more comment
  • Nate Stansfield
    Nate Stansfield Nov 19, 2009
    Internal power supply or motherboard is shot. I would test internal power supply first with a voltmeter. You can test wires from power supply to motherboard. If there is no power, then supply is bad, if there is power and laptop does not boot up, then either the motherboard is fried or the internal memory chips could also be bad.
  • Nate Stansfield
    Other possibilies could be faulty ribbon cable from screen to motherboard could be pinched, Memory chips could be faulty, or internal power supply could be faulty. You can test power supply to motherboard for power with a voltmeter where they connect.
    Last possible solution would be faulty motherboard.
  • Nate Stansfield
    You can check the pin with an ohmmeter. Put one probe on pin and other probe on the opposite end to see if there is contrinuity. Capacitor's also tend to burn out. They usually swell up or get burn spots on circuit board. You can also test any capacitor on the motherboard with an ohmmeter as well. 25-30 ohms is the norm for capacitors.
    The pin or wiring could be fault or shorted out.
    You can also try removing one memory stick at a time and see if that helps any. Faulty memory chips are common and cause pc not to power on.
When I close my lid, pc crashes
Laptop shuts down / crashes after closing lid - used to hibernate ...
en.community.dell.com/support-forums/laptop/f/3518/t/19496556
Dell
Mar 13, 2013 - 16 posts - ‎7 authors
Now shuts down after closing the lid after several hours - at least .... My computer crashes when it goes to sleep regardless of the lid's position. E7440 - sleep Issues and display issues - General ...
Apr 17, 2014
crash after sleep/close lid - General Hardware - Laptop ...
Nov 21, 2012
More results from en.community.dell.com
Laptop Sometimes Crashes When Close Lid to Sleep - Windows
Dec 01, 2015 | ASUS Computers & Internet
Toshiba Laptop L650-12Q will not shut down
Windows needs to be shut down properly to keep it stable, if hibernate mode is being used it eventually corrupt windows causing all kinds of symptoms, I recommend you make a backup recovery disc, and disable the hibernate feature to prevent complete window failure.
May 07, 2012 | Toshiba Computers & Internet
My computer is on but no picture. It says windows was not shut down properly
Hello Pattiaknight,Make a desktop shortcut to shutdown and include a switch that forces all open apps to shut down without warning.
Just right click the desktop, New, Shortcut, type:
Shutdown -f
Shutdown -f closes any open programs without warning.
Now instead of shutting down the usual way, just use that shortcut to shutdown. If the error stops it means some program wasnt shutting down properly on occasion.
Please let me know if you any further questions or concerns.Also please rate it if you like the answer,it helps alot.
Thanks.
Apr 19, 2012 | Sony Computers & Internet
To whom iut may concern, i purchase your laptop cooling station,when i close my laptrop down the station keep running is this normal.
FixYa does not sell any computer equipment, you need to ask the person who sold it to you.
Most cooling pads have a separate power source and therefore needs to be shutdown separately.
Aug 22, 2011 | Computers & Internet
I undocked my compaq 6320 laptop - just after accidently hitting the dock- power button (before hitting the eject button). I ejected the computer but noticed it began to start-up but shut down because my...
Try removing the laptop from the doc, pulling out the battery, hold the power button down for 10-20 seconds, and re-install the battery.
This should drain out the laptop and it should boot up properly without the dock.
May 27, 2011 | Computers & Internet
Proper shut down
Hi doodu13appa,
Nothing beats a complete "Shut Down" through the Start menu in the lower left-hand corner of your Windows screen. This allows all open windows to be properly closed, with current data saved, memory and cache cleared. This is like going to bed at night with nothing on your mind, sleeping soundly, and waking up refreshed in the morning.
Then, when the computer is powered up the next time, it will be operating at its optimum performance levels without being "bogged" down with excessive leftover garbage from previous sessions. There's nothing wrong with powering your laptop, or desktop, down by clicking the power button and letting it go into standby, sleep, or hibernate mode, much of the time. It leaves you with a quick-startup the next time you are ready to use your computer, and most of your open programs will still be running in the background. Clicking on your logon will have your right back where you last left off.
Sep 19, 2010 | Computers & Internet
Computer Shut Down Problem
Is the computer taking forever to shutdown in the blue screen or is it something else. Perhaps try closing the applications running with the system to help the process speed up and actually work without the usage of the power button.
Feb 06, 2010 | Lenovo ThinkPad T400 PC Notebook
Laptop shuts down after 20 or 30 minutes with one
Please refer to manual and run system restore to system default settings as if it was from the package.
Cheers.
Jan 24, 2010 | Dell Inspiron® 1501 (N11157) PC Notebook
Close lid of laptop without shutting down system
You have to configure what laptop do when the lod is closed . go to Control Panel , Power Options , Advanced . In this tab you will see an option " When I close the lid " and a drop down menu just choose do nothing and press ok . It will not shut down your laptop when lid is closed .
If you like my solution do vote for me
Farhan
www.senseapplied.com
Jan 05, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
My laptop won't shut down properly!
Is it possible that you have changed the settings of what buttons do what on your system? E.g. you could have changed the power button to "switch user" instead of "shut down", to check this (in XP) go to "Power Options" (in Control Panel" and then click on the "Advanced tab" at the top, then select "Shut down" from the drop down menu at the bottom of the window.
If this is already set to shut down then maybe you could do a system restore in case another setting has been changed, restore it to before the PC started doing this.
Alternatively try actually choosing "Turn off Computer" from the Log On screen (press Ctrl + L to get to this screen, or choose switch user/log off). If you are using Vista I beleive that there is a shut-down option from the Log In Page there (which again you can access by pressing Ctrl + L on the keyboard.
Hope this helps!
Dec 29, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
