Question about LG Dare VX9700 Cell Phone
When I dial out I can't hear the phone ringing or the person when they answer. If I call from my home phone it goes directly to voicemail.
Why does my phone only rings once, calling party hears a couple of rings and then goes to voicemail. goes to dial tone when answered after first ring.
Press menu, go to settings then scroll down to ring count and set number of rings before it goes to voice mail.
Jul 18, 2014 | Panasonic Lands Phones
When the Norstar m7324 phone is set to night mode after business hours, the caller goes direct to voicemail when the caller dials an extension. How do I change it so that it rings at the extension a f
Night service will only control if AA to answer (main greeting) or human, you!.
If people enter extension and it goes straight to vmail then the user invoked that option (Feature 987) which is what you should do when you leave your office.
Oct 11, 2012 | NorStar M7324 Telephone
My store had a huge power outage where the lines were sparking. Anyway since the power has come back on I have no ring & can not dial an extention after i dial a phone number. I have looked in the...
So you're saying you can dial a phone number, but when the voicemail system answers you can't dial an extension number ? If that's the case, that means your phone system reset. Generally that means all phones will have access to only line 1 and 2, and that they'll be ringing on all phones. The date would usually change to Jan. 1st 1980, but caller-ID might override that. All line programming would be set to pulse, which would be the cause of you not being able to dial an extension number a voicemail system answers. It would also mean that when you do dial a phone number it takes a while before you hear it ringing. (Because the phone system is dialing in pulse instead of tone, if you stand next to the phone system you'll probably hear it go)
... Long story short, your entire phone system needs to be reprogrammed. I suggest only doing a partial reprogramming, then unplugging the power for a few minutes and check to see if the programming stuck. If not, the battery in your system also needs to be changed.
May 20, 2011 | Nortel Meridian M7208 Corded Phone
Problem has just come up-We have 4 incoming lines-for some reason every once in a while now you hear a very, very brief ring (milisecond) and it goes directly to a voice mail. We are sitting here and...
If the voicemail it goes to is the on site voicemail, then try canceling call forwarding of the phone associated with the mailbox that gets the message by pressing FEATURE #4 from that phone. If the voicemail it goes to is an external voicemail as in that of a cellphone then try canceling line redirection by pressing #84 then press the line to cancel redirection on. Repeat for additional lines.
Jan 25, 2011 | NorStar M7310 Corded Phone
My lg 410g phone does not ring when there's incoming call but goes directly to voicemail
the reason the phone automatically goes to voice mail is simply because the phone has sim card has been set to do so.
The solution is for you to deactivate the voicemail.
That is when you will be able to receive your call properly.
To deactivate the voicemail, all you have to do is to dial ##002# and send.
it will deactivate the voicemail of your phone and you will be able to receive your calls aswell as your phone will also start to ring out.
take care
Jun 18, 2010 | LG Cell Phones
Tracfone LG 3100 handset. All calls go directly
I had the same problem with my LG100C. The tech support at Tracfone said that the person calling you must dial your area code too. Seems silly, but it worked for me.
Feb 27, 2010 | Cell Phones
CP100 Auto Attendant transfers direct to voicemail
The norstar extension may be setup up for Call Fwd to voicemail, or call fwd/busy. Also, Custom Call Routing may be setup to send the caller directly to the mailbox.
Nov 10, 2009 | NorStar CallPilot 100 Voice Mail, 10 mail...
Call pilot 100 hunt group
Not too sure if you really need that dial 0 point, since the calls are already ringing in on the receptionist desk.
You can create changes and make a hunt group, with an over flow with another hunt group, which will rings specific people, and if there is no answer the over flow can go to a voicemail or auto attendant... more programming than I would like to type.
Simple solution: Make sure that everyone that you want to answer the calls, they are in the same pick up group.
Then if the people that you want to answer hears the phone ringing, they just have to dial Feature 75, this is group pickup.
To find out if the people are in the same pick up group:
-> go into the system programming
-> TERMINALS&SETS and enter the extension
-> find CAPABILITIES and enter
-> hit next till you find Pickup grp: this will have a number and ensure that all the sets you want have this same number.
-> rls to back out of programming.
This way anyone that hears the phone ringing can answer anytime they want.
Mar 20, 2009 | NorStar Cics 6.1 & Call Pilot 100...
My BT Verve 450 digital phone set won't ring out /incoming call
bt cordless phone i have pressed something and it has locked can anyone tell me how to unlock it
Dec 08, 2008 | Uniden Cordless Phone
Calls automatically go to voice mail
When you pick up the handset ...do you hear a stutter dial tone? Forwarding or DND might be on.
Oct 16, 2008 | Avaya 5400 Series 5410 Phone
LG Dare VX9700  Cell Phone Logo
185 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
