Question about LG Kitchen Ranges
Oven door removal/adjustment for LG stove LSB5611SS It has gone out of alignment with top catch
5 Suggested Answers
Amigaman
  • 248 Answers
SOURCE: lp flames to top of oven
You need to tighten down the orifice spud for the bake burner. Remove drawer in bottom of oven. Look for bottom of burner tube, where the shutter adjustment is. Right below it is the orifice spud. Usually a goldish color. Take 1/2 inch open end wrench and tighten until it stops. Do-not overtighten! Try it now. If flames are still to high, tighten a little more. Repeat if needed.
Posted on Nov 19, 2007
jsrock516
  • 5911 Answers
SOURCE: oven burnout
The oven is controlled by an Electronic Range Control (ERC). This is the clock assembly on the range. The surface elements are powered by infinite switches and do not go through the ERC. That explains why the clock assembly is dead, your oven does not work, but your surface elements do. You need to replace the ERC. If you can provide me with a model number (located near the oven door or bottom drawer opening on most ranges, on the back of the console on some) I can determine what type of ERC you need and how much it might cost you. Post back with comments and let me know if I can be of further assistance. I hope this helps you.
Posted on Feb 11, 2008
  • 6 Answers
SOURCE: oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Posted on Dec 20, 2008
SOURCE: Can't Unlock oven doors after "self-Clean" maytag double oven
I was advised to disconnect power for at least 60 seconds to clear the control board. I did this several times with no luck getting the door unlocked. However, a few hours later, the door did finally unlock. Not sure what ultimately caused the door to unlock, but happy that I did not have to replace the control board.
Posted on Dec 22, 2008
How do I unlock oven door on lg gas stove..accidentally locked it cleaning
When the oven begins to clean itself the lock isn't able to be unlocked until a minimum them is reached. Be sure to clean oil and other debris that's likely to catch fire because it's libel to get out of control
Feb 17, 2018 | LG Kitchen Ranges
Lg microwave above the stove, lt is level but door wont stay open,as your putting items in it starts to close ,is there any adjustment on the door
Only gravity keeps the door in open position. You can try to tilt front down by loosening the top mounting bolts.
Apr 29, 2017 | LG Microwave Ovens
Stoves 720ef bottom door not touching seal at top
Try adjusting the hinges also check magnetic seals on door itself as well.
Feb 22, 2013 | Stoves 720EF Electric Double Oven
Have to slam door to get oven to operate
Try a) Lubricate the latches. I sprayed wd-40, you probably can use vegetable oil. Both sides, latch and receptor. Just doing this may fix your problem. (I have to admit I did part b first before trying this so I am not sure, but after doing this, it made my part b fix work even better)
b) Failing this, I found opening it up (t-20 torx screw driver) and tying a wire in the top hole, through the bottom latch body and fastening to a bottom hole of the microwave frame to force the mechanism to stay in place. You want to pull it towards the oven cavity. This will keep it from bending out of alignment. I found that it is only the bottom latch that has to catch for the microwave to sense the door is closed.
Mar 30, 2011 | Panasonic NNSN797S Microwave Oven
Dhow do i remove stoves efa600H oven door hinges?
1. Open the oven door and remove the 2 screws at the side of the inner glass window 11cm above the hinges and lift off the door. Place it somewhere safe!
2. Remove the 4 screws that you can see nearest to the left and right edges of the oven with the door removed. These secure the oven to the kitchen unit.
3. Slide the oven forwards about 20cm out of the unit, being careful not to pull on the cable.
4. Each hinge is held in place by 2 screws at the side of the unit now exposed, about 18cm apart. Remove them and slide out the hinges. Reassembly is the reverse of the above.
5. Note that the hinges have no means of adjustment. If not working properly, renew them.
Nov 20, 2009 | Stoves Premier 600EMa Electric Single Oven
I own a Kenmore stove model #639539J2. The glass
yes. open the oven door to the first "click". it kind of stops about a quarter of the way open. most ovens you grab both sides of the oven door and pull up. some models have a couple of screws you have to take out before you can remove the oven door. then lay it down with the insie of the door facing up and take out all the screws holding the oven door together. some may be on the sides or the top and bottom of the door. when apart, clean first with easy off, then clean several times with windex till streaks are gone. assemble door in reverse and put back on stove.
Oct 10, 2009 | Kenmore Ovens
LG Range LSB5611SS LHS element stays on
I have the same model and there is a recall on that model and others as well. The control panel will be changed for free. There is a site where you can check it out http://www.healthycanadians.gc.ca/recall-alert-rappel-avis/hc-sc/2012/15538r-eng.php then contact LG
Sep 01, 2009 | LG LRE30451ST Electric Kitchen Range
New Cornu Fe Stove - Oven door pops open
I had the exact same issue with my Cornue Fe (only on the right hand side oven). The other symptom I noticed was that the door itself didn't close as smoothly as the left hand side oven.
Take a look at the alignment of the "post" sticking out from the oven relative to the spring loaded catch on the door. These need to be *very* well aligned vertically in order to keep the door closed as it heat cycles. You'll notice that the post has a depression at the end of it (furthest away from the door). The door catch has an upper and lower spring loaded roller that is supposed to "catch" on both sides of the depression. If you are misaligned vertically, then only one side of the catch will be applying sufficient force to the depression.
In my case, the post and the catch were misaligned by about 4-6mm. In fact, I noticed that repeated opening & closing of the door was actually causing some wear on the upper roller of the catch. To fix, I needed to raise the door, which was accomplished by adjusting the hinges.
I removed the door from the oven, which can be done by removing the screws on the hinges. The hinges consist of a bottom & top knob that slot into the door (similar to the way refrigerator hinges work). The hinges themselves are made of ~1/4" metal (could be stainless, but it's relatively soft stainless). I put the lower hinge in a vise (appropriate covering to prevent scratching) and *gently* bent it up to adjust the door upwards. Putting it back together required some help (the door is heavy), but after a bit of work it was all back. Thankfully the alignment was right the first time. This whole process took about 20 minutes.
In my case, I suspect that either the wife or kids had put too much weight on the door at some point and bent it out of alignment. The problematic door had about 4-6mm of "play" between the top and bottom hinges prior to my adjustment--the working door had zero "play". You might want to check to see if you have any such play before you do this work (you can either look at the hinge itself or simply lift up on the door at the hinge point to see if it moves). If you don't have this same play, but you do have misalignment, then you'll need to adjust both top and bottom hinges.
The other possiblity is that you might have a weak spring in the catch mechanism. You can check that by gently pushing a flat head screwdriver in between the two rollers and feeling for how much force is required to separate them.
Of course, you can also just call the La Cornue service folks and have them check it out.
Mar 21, 2008 | Kitchen Ranges
KDRP407HSS oven door adjustment
I found a solution. Remove door (very simple procedure listed in Use and Care Guide). Make a shim and attach it to the end of the hinge arm (the part of the hinge protruding from the door that goes into the slot in the frame). I used metal shears and a coffee can and made a metal strip that I wrapped around the arm 3-4 times. Reinstall door and it should be tight at the top. (Unfortunately I suspect this fix will be temporary until the ill-designed hinge mechanism starts bending again.)
Nov 12, 2007 | KitchenAid KDRP407HSS Dual Fuel (Electric...
Kitchen Ranges Logo
310 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Oloyede Monsuru
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
