Question about HP DesignJet 1050c plus InkJet Printer
HP 1050C PLUS 128 M RAM (THE MAX) FIRMWARE 52.02 (THE LATEST) DRIVER VER 4.70 (MOST RECENT) I HAVE COMPUTER DO THE PROCESSING, I PRINT IN DRAFT MODE BUT IT ALWAYS LOCKS UP WHEN I PLOT FULL SIZE 30x42 DRAWINGS IN .PDF FORMAT. AutoCAD DRAWINGS PLOT WITH NO PROBLEMS AT ALL. I AM RECEIVING ERROR CODE 04C300 I/O CARD ERROR BUT IF IT PLOTS CADS OK HOW CAN IT BE THE ETHERNET CARD?
    Scholar:
  • HP Expert
  • 123 Answers
This error is being caused by the JetDirect card or the HDD if installed.
Posted on Apr 15, 2010
Processes but won't print
Sometimes a plotter will show that is receiving data from the computer but will not print. I assume this is what you are describing. This can be caused by a couple of things. The first suspect is a corrupt file. Try a smaller file to see if it will print. If it does, the problematic files are probably from Photoshop or a CAD program. If a file has more than one level when it is sent to the plotter, the plotter has a hard time digesting it. Try "flattening" the file (makes a single level) and then send it to the plotter.
Another possibility is that the printer driver is no longer matched to the computer operating system or is simply corrupt. Go to HP.com and get the latest driver for the plotter. Windows XP Pro 64 drivers work well with W7 and 8.
Lastly, the Jetdirect card could be faulty. Reseat or replace the card.
Jul 09, 2014 | HP DesignJet 1050c plus InkJet Printer
I am trying to print a diagram to my HP 1050c plotter. Goes from Ready status to Receiving Low Memory without printing anything. What does Receiving Low Memory mean and what can i do to print my...
You need to do setting in Driver Properties printing preferences in advanced tab, select computer memory if printer runs out of memory, if it configured on the network then set properties on computer where driver is installed.
Jan 07, 2011 | HP DesignJet 1050c plus InkJet Printer
We installed the HP designjet on a pc windows vista and we can print everything we want to, the printer is also installed on a mac osx 10.6 snow leopard but there we have some problems for printing our...
HP Design Jet 1050C Plus is supported by MAC OS 10.6. If you are having problems with printing, it is recommended that you may update the drivers of your printer. Click here to download the latest drivers.
Good Luck!
Hope this helps!
CreativeTECH
Dec 15, 2010 | HP DesignJet 1050c plus InkJet Printer
My Design Jet 1050c does not like to print PDF's. It says receiving low memory right now and is taking an extremely long time
Two questions:
1. How large is the PDF file and is saved on your local hard drive?
2. How is the plotter connected to your computer? Network or directly connected via parallel or USB?
Try changing how the printer processes the print job.
On the driver properties / preferences, select the Advanced tab and change the Process Document to "in computer" and then try printing again.
Aug 06, 2009 | HP DesignJet 1050c plus InkJet Printer
HP Designjet 1050c plus freezes during print
try setting up spooling on pc not printing directly to printer that may help you.
Oct 27, 2008 | HP DesignJet 1050c plus InkJet Printer
1050C plotter
Here is the drivers page if you need a new set:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=33712&locale=en_US&taskId=135&prodTypeId=18972&prodSeriesId=24023
Aug 27, 2008 | HP DesignJet 1050c plus InkJet Printer
Hpdj1050c plotting problem
1. make sure you are using the correct print driver.
2.check that printing preferences are set correctly in said drivers.
3. if these suggestions don't work, then make sure your application settings are set correctly, and order the most recent firmware dimm you can find. this machine cannot be flashed and in order to upgrade the machine "BIOS", you must install a new firmware dimm onto the emod (electronics module). Good Luck!
Aug 25, 2008 | HP DesignJet 1050c plus InkJet Printer
1050C plotter
replace the network card, then reconfigure the IP address in the machine and that should take care of you. if not then you could have a bad emod (electronics module). also check the cat5 cable and the network drop for functionality.
Oct 11, 2007 | HP DesignJet 1050c plus InkJet Printer
HP DesignJet 1050c plus InkJet Printer Logo
246 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
