Question about Philips 34PW8502 34" TV
Wiring i have a **** for a repair man... and i have waited on gettin my tv back for the past 4 days and now he can't remmeber what wires go where so i want to see if u can help me out it would be very nice if u could
HUH?? what wires???
Posted on Jan 11, 2008
Rmp's high 2-4
Is the check engine light on?
Jan 31, 2013 | Volvo S80 Cars & Trucks
Simpson 1200p won't heat. Sure the element has been disconnected during repairs.
When you repair a unit for one issue and after suddenly have different one it is usually man made--someone should go back over what was done to see if a plug or wire is not connected etc.
Dec 21, 2012 | Dryers
Hitachi rear projection model 57f59a makes loud popping sound from time to time
Yes and it is common---the set uses 3 picture tubes and where the high voltage (well over 10,000 volts) goes into the side of each tube via a spark plug type wire (with good reason) they completely seal the rubber clip that inserts the wire into the side of the tube.
You are describing almost perfectly when one of the tubes arcs around the anode (what the opening is called--2nd Anode to be precise)
Two things are going to happen--when it pops it can instantly burn the coating off of the offending tube's screen resulting in a burn mark--usually dead center and if red tube arcs the mark will be yellow(only red and visable in that area of the screen.
This damage is permanent once it happens-----Second is that it will arc hard enough to blow some other part out in the set.
let me know if questions.
Mar 19, 2012 | Televison & Video
Im here in candaba,pampanga,my 32''inches philips tv is cannot open.the repair man man said,because of thunder thats why they some wires burn....the repair man said,go to philips service...
Hello -
So, you reside in the Philippines. I suspect it was a nearby lightening strike which damaged some of your TV wires and not thunder.
This is the link to the Philips Philippines home page:
https://www.philips.com.ph/
Note: I found the web site for Philips Philippines by using Google, my favorite search engine, and using the following search phrase:
Philips TV Philippines
On that page you will find the link for SUPPORT. Click or tap on that link.
You will be brought to the Philips (Philippines) Consumer Care page:
https://www.philips.com.ph/c-m/consumer-support
Scroll down that page to find the icon and link for SERVICE AND REPAIR. Click or tap on that link.
You will be brought to the page for CONTACT PHILIPS PHILIPPINES:
https://www.philips.com.ph/content/B2C/en_PH/support-home/support-contact-page.html
Scroll down to see the telephone number to call regarding Philips LED TVs. Call the telephone number listed to find where the nearest Philips TV repair center is located.
I am answering from the USA.
Best wishes.
Feb 14, 2018 | Televison & Video
My Maytag Washing Machine model LAT8608AAW simply stopped w/ a full load and filled w/ water. I've emptied most of the water. It'll refill if I turn the dial to do so, but it'll do nothing...
If it refills change repair man problem is either lid switch could be checked by lifting lid slowly and listen for two clicks if there is probably bad timer
Jun 04, 2011 | Washing Machines
New JVC flat screen cuts off 10 sec. after cutting on
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
Mar 26, 2009 | JVC LT42P789 42 in. LCD TV
Philips 34PW8502 34" TV Logo
54 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
