Question about Desa International Reddy Heater R40 40,000 BTU Kerosene Heater
My igniter doesn't work, fuses are ok on an All-Pro # R115D(T)
  • 456 Answers
If its a glow coil igniter it could be cracked, it will usually be
cracked in the back
Posted on Dec 28, 2009
Have a PRO F-Sports 4 Stroke 150cc Scooter. Headlights don't work. All other lights are ok.
Hi, Dan if your headlight is not working the first thing to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
1. Faulty ground or power supply to headlight bulb socket.
2. Faulty hi/lo beam switch.
3. Faulty ignition switch.
4. Fuse is good but no continuity on both sides.
5. Faulty wiring between battery positive and headlight bulb socket.
Good luck and have nice a day.
Aug 10, 2015 | Motorcycles
Cleaned my gas hob but now when you turn the gas on the automatic ignition doesn't switch on. Model candy pl 40 ax. I have checked the fuse on the plug but that's ok is there another fuse I should kno
Is it pluged in. Check to see if the plug Still works behind the stove It might be on a GFI plug needs to be reset somewhere along the backsplash counter
Jul 19, 2013 | Cooktops
Flame on dryer goes on off
see this causes and use the common sense.God bless you
If your dryer doesn't heat, check these: Igniter Gas valve coils Thermal fuse Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too. To determine if the igniter is burned out, watch the part testing video at the bottom of this page. The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.) To determine if the thermal fuse has blown out, watch the part testing video at the bottom of this page.
Sep 19, 2012 | Frigidaire GLEH1642DS Front Load Stacked...
03 chevy venture rt.front parking light&turn light don't work replace bulb&socket
The rapid flashing occurs because of the light problem. If the 20A PARK LP fuse in the underhood fuse block is OK, the front marker lamps and the park lights should turn on when you set the headlamp switch to PARK. If the 10A T/SIG fuse in the instrument panel fuse block is OK, and the ignition switch is on, moving the turn signal multi-function switch to signal a right or left turn should cause the turn signals to flash. If this doesn't happen, check for a missing ground connection to the socket you replaced and check to be sure the replacement lamp was not forced into the socket backwards (it happens).
Sep 17, 2012 | 2003 Chevrolet Venture Passanger
Nissan sentra radio doesn't work. all fuse OK but radio still doesn't work
the fuse for the radio is under the hood next to the battery
Mar 10, 2012 | Cars & Trucks
I have 30 Volts AC going to the igniter and the igniter doesn't glow. I replaced the ignier but still no luck. what is the input voltage for the igniter and what may be the problem. There is 120Vac...
Should have 120 v to igniter. Ohm out the burner coils on the gas valve. Should be less than a couple Kohms. If ok bypass thermal fuse temporarily by connecting its two wires together and see if it lights.
Sep 21, 2011 | Dryers
I have an All Pro 115,000 Btu Kerosene Heater. One of the models listed on the label is R115d(t). It has a good spark. It runs for a minute or two and stops. How do I trouble shoot? I don't have the...
Sounds like Flame sensing probe or some call it a thermo coupling, Should be located near the igniter Try cleaning with steel wool if that doest work might have to replace it.
Dec 19, 2010 | Heating & Cooling
The headlight does not work. fuses are ok
Check your ignition wiring, normally for AHO bike headlight are connected to ignition switch.
May 27, 2010 | 2002 kawasaki ZX-6R
Heating & Cooling Logo
105 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
