Question about Apple iPod nano
NO POWER MY iPOD WANT COME ON. WHAT COULD THIS BE? HELP!
  • 97 Answers
This is a very comon problem. the only solution for this is to either click buttons all day and evry day unitl it comes on cuz das what i did, switch the hold button on and offf, or click menu and center button together and hold for bout 5 sec. then repeat. also you could plug into computa see if that works. i had same problem and i just kept clicking for 2 day
Posted on Jan 11, 2008
I restore my ipod, then after restoring it wont turn on anymore. there is an icon appear, its like plug in to the power source. Please help. I need my ipod back working again =(
Just format the ipod and then right click on the ipod drive , click properties and click tools and click both the options and click start and enjoy
May 21, 2010 | Apple iPod Photo-60GB Power Hot Sync and...
HELP i forgot my apple ipod toches password and it
You will need to do a 'Hard reset' !
This is how the the procedure goes for the ipod touch:
- While plugged into ITunes, Hold down the power and home keys down for 10+ seconds. - - Screen will go black
- Release the power button but keep holding the home key until itunes says 'We have detected an itouch in recovery mode'
- Restore as normal via iTunes
Hope it helps!
Dec 24, 2009 | Apple iPod touch
How do you restart an Ipod?? I was trying to
IF IPOD ISN'T FROZEN.
  1. Hold the Power button until you see the "Slide To Power Off" slider.
  2. Let go of the Power button, and slide the slider.
  3. Wait until it turns off completely, press the Power button again to turn it back on.
IF IPOD IS FROZEN.
  1. Press and hold the power button and the square home button at the same time.
  2. Wait some time it will reset eventually.
  3. Be patient.
Hope this helps - good luck!
Sep 17, 2009 | Apple iPod touch
Ipod not recognized as a drive.i need help. it is an ipod touch 8 g 2nd gen
Plug your ipod into a USB 2.0 port and see if that helps.
or try a different port on your computer. make sure your not connecting the ipod
through a hub. Sometimes the hubs don't carry enough power to drive the ipod.
if this doesn;t help get back to me and I will help further.
Apr 20, 2009 | Apple iPod nano 3rd Generation
Screen gone dark
It is natural to ipod the screen will be dark if has no power unless the LCD of your iPod is defected even it has a power its remain dark that’s the symptom of defected LCD screen. I hope your problem is a power failure only. Make sue your iPod is fully charged and then toggle the hold switch on and off. Then reset your iPod nano; Toggle the Hold switch on and off,(Slide it to Hold then it off again). Then press and Hold the Menu and Center (select0 buttons simultaneously until the apple logo appears ,about 6 to 10 seconds .You may need to repeat this step . If you having difficulty resetting your iPod set it on a flat surface .Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel,and not near the center. Then If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try your iPod nano with a different USB port on your computer, not a USB port on your keyboard or hub. iPod will stop charging if the computer, or portable computer, it's connected to enters standby, hibernation, or sleep mode. To charge your iPod, connect it directly to a computer's USB port and make sure standby, hibernation, or sleep mode is turned off. If using a portable computer, make sure it is plugged in to a power source and that the lid or display is open. If the lid is closed the computer may go into either standby, sleep, or hibernation mode and iPod will not charge properly. If you have an Apple iPod USB power adapter you'll be able to charge your iPod without leaving your computer powered on. If all procedure above for power to on is not working then its better to replaced the battery with anew one so its works normal again.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Apple iPod nano
My ipod says www.apple.com/support/ipod My computer locked up and so my ipod disconnected before ejecting. At first it locked up bur I reset it. Now it shows a cross and tells me to go to...
im not sure if this will work, but, hold the menu button and the select button for about 8 seconds, or until the screen turns off, then u will get the ipod logo, and then it should boot up like normal
Jan 17, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod
maybe bad ipod try another computer
Aug 04, 2008 | Apple iPod MA446LL/A MP3 Player
Problem with IPod Nano Model A1137
Try holding the menu button and center button at the same time. this should reset the ipod completely. Its a force power up and power down similar to Zapping your PRAM on a computer. this should reset the configurations
Hopefully that helps
May 13, 2008 | Apple iPod nano
Computer won't read my ipod.
It might be that your USB port is not giving the iPod enough power to connect and charge etc. but you can go into device manager and change how much power is fed into it.
Apr 17, 2008 | Apple iPod nano 3rd Generation
Problem unlocking
need help lock 8gb ipod need big help now
Dec 05, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano Logo
19 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
