Question about Compaq Presario 5000 PC Desktop
Monitor locked up
When powering up the monitor says out of range
  • martin bay Apr 01, 2008
    Starting Windows XP with a Dell monitior, I receive a blue attention box stating 95k/59hz frequency is out of range.
    Have tried changing the display settings in safe mode but does not seem to make any difference
  • 589 Answers
I know this sounds odd... but is the monitor cable connected to the computer? Is the light by the power button green, or orange?
Posted on Jan 11, 2008
    Genius:
  • 1,226 Answers
Solution: boot your system to safe mode and then delete or uninstall the VGA driver in the device manager.
to to this; when booting press " F8" to select the boot mode.
and then after booting; click start , point "my computer" then right click "properties".
click "hardware" tab, "DEvice manager" tab and then in the . click + sign of the Dispaly adapter.
then unistall the driver.
after unistalling restart the system to normal mode.
if the system need and installation driver you should supply it.
Get rid of "Out Of Range" message on e218c1 monitor.
The device driving the monitor is exceeding the horizontal and vertical frequencies that the monitor can display .....thus the "out of range". The specs for this state that the Horizontal Freq. is 80Khz and the Vertical Rate is 75hz. If you are driving this monitor from a computer running Windows, reboot the PC and use the F8 key to put it in SAFE mode. This will cause the video driver to default to a rate that the monitor can handle. Then go into the screen resolution settings and reset them. The native resolution of the monitor is 1680x1050 at 60 Hz. Exceed that and you'll get the "out of range"
Sep 10, 2014 | Envision Peripherals 22"" envision e218c1...
OCD LOCKED pops up at random
There might be signal issues from the source device; with intermittent problems, I recommend cleaning all the pins on both ends of the connectors and then removing and re-inserting the plugs a couple of times in hopes that it is a connection problem on one of the cable ends.
Sep 25, 2017 | HP Compaq W17q Monitor
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
SOYO DYLM24E6 DISPLAYS OUT OF RANGE WAS TOLD MONITOR HAS A RESET BUTTON IF SO WHERE OR IS THERE A FIX FOR THIS MONITOR IT IS NEW
Restart your computer in Safe Mode
(or reconnect your previous monitor).
Set the screen-resolution to 800 by 600 at 60 Hertz.
Shutdown, connect the new monitor, and restart, and your Soyo monitor will be able to display something, using these "NOT-out-of-range" values.
Try changing the resolution to 1024-by-768, or 1280-by-1024,
and "test' these values, to see what values are "in-range" for your new monitor.
Jan 07, 2010 | Soyo DYLM24D6 LCD Monitor
Monitor will not come on power light blinking blue
According to the manual, the frequency may be out of the range of the monitor. Adjust the frequency to the range needed by the monitor. Normally 60Hz will work fine.
Nov 04, 2009 | Samsung 941BW LCD Monitor
Monitor is stating signal out of range but it is not wireless and nothing has changed except it has not been used for 2 weeks
this is your screen resolution issue.
For that first check your monitor connected to vga port perfactly.
Also check num lock key if it is on /off when u press num lock key then your cpu gives dispaly to monitor proeprly but if not on/off then u have to do 2 things.
Refix RAM memory on motherbord.
Clear cmos settings for that pull cmos cell from motherbord for 10 minutes then all settings are factory defaults.
then when you power up the computer press F8 key then enter in enable vga mode then change screen resolution to 1024*768 or 800 *600
then check .
Aug 15, 2009 | Computers & Internet
Our viewsonic monitor tilts forward. how do we tilt it back?
Hello again.
The ViewSonic VG1930wm has a height adjustment range of 3.2", TILT capabilities, and a swivel range of 360 degrees.
So yes your monitor should be able to tilt back and forth.  Most likely if you hold the base of the monitor, and press somewhere on the front at the top or bottom (do not press on the screen itself) then it should easily tilt back and forth.  Occassionally there is a switch you may have to hold while you push on the front-top/bottom of the monitor which acts as a lock for the tilt angle.
Hope that helps, and don't forget to vote/rate!
Height adjustment range 3.2", tilt, swivel range 360º
Mar 12, 2009 | ViewSonic VG1930WM LCD Monitor
Out of rang vw193t
Pls temporarily install a older monitor then check the display sttings ,set it to the lowest resolution apply and then check whether its working on the old monitor.Then shut down and connect the new monitor and power on the monitor should work
Jan 24, 2009 | ASUS VW193T Monitor
Oven door locked, F9 indicator signal
F9 has to do with the door lock/latch monitoring switch, i would try to remove the oven for mthe counter andremove the back panel, in the approximate hieght levle of hte top of the lower oven mounted to the right side( standing behind) unit youll find a small lacth / motor assy, that drivesthe self clean latch, WITH POWER TURNED OFF> i wouldlook closely at the switch mounted to the assembly make sure its not out of line , (perhaps twiste doff to the side, not making contact, or something else real obvious.. definalty related ti a faulty read of that switch .chances are it got 2 hot and distortred teh mounting and/or function of that part.. worth a try any way good luck!
Nov 27, 2008 | Kitchen Ranges
Out of range
acer ac 713 crt monitor picture incorrect (left&right)
Nov 22, 2008 | Acer AC713 17" CRT Monitor
Compaq Presario 5000 PC Desktop Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
