Question about George Foreman GR82
My chicken is not turning in the rotisserie and i don't have a manual
    Problem Solver:
  • 7 Answers
DO not use a chicken larger than 5 lbs. Tie cooking twine around the chicken to hold it together so it doesn't touch the sides. I use two or three pieces of twine - wrap it around and tie - cut off the ends of the twine close to the knot.
Posted on Nov 20, 2009
Rotisserie squeaks
That is perfectly normal, enjoy your chicken Sally.
Oct 24, 2014 | Toaster Ovens
Need a manual for modal #HR0101
Hobart might be able to supply instructions
Jun 04, 2013 | Hobart Commercial Rotisserie Oven
Where can I buy a George Foreman GR82 rotisserie?
I don't know but would possibly be interested in buying your baby George one. Thanks, mexicojerry@gmail.com
May 11, 2012 | George Foreman GR82
I just bought the Brinkman, and I am trying to figure out how to use the Rosterria. Can you help me?
Since a Rotisserie is an optional item for your model grill. I assume you have purchased one that is approved to be used on your model Brinkmann Grill Smoker. If not, I recommend that you Do Not use it. If it was approved, read and follow the directions that came with it regarding installation, setup and preparing to use the rotisserie.
The Rotisserie can only be used when you are not grilling anything else on the grill. Remove the grill grates directly in front of the rear infrared Rotisserie Burner. If you Don't, they will be in the way. In their place, you are going to use an aluminum pan (like a pie pan), as a drip pan for whatever you're cooking on the Rotisserie.Place that on top of the burner's flame tamers. Make sure the rotisserie motor is in place and you have electric power to it. Test the rotisserie spit, by inserting it into the motor's spit holder. If you have a Counter Balance, attach that near handle on the spit shaft just below the handle. If your rotisserie is missing the counter balance, you can not use the rotisserie.
Remove the rotisserie spit and place whatever you're planning to cook on it, following the directions that came with rotisserie kit. Make sure the spit forks are tightly embedded in the meat, whole chicken, etc. If a whole chicken, tie the legs together like a Thanksgiving Turkey around the spit..
Light the Rotisserie Burner and close the hood of the grill. Allow the temperature to reach a minimum of 250 degrees F, before opening the hood and installing the food loaded rotisserie spit.
Be careful, as the interior of the grill will be hot. Install the spit as you did earlier. Make sure it fits into both sides of the grill's hood correctly.
Turn the Rotisserie Motor ON and watch as the food turns. If it turns and then sort of bumps, when the spit turns around, adjust the counter balance to stop this. It should turn smoothly. Once all tha is completed, close the hood and allow the food to cook for whatever time, you would cook it in a kitchen oven. Rotisserie cooking is like smoking food. It's a low (temp) and slow (time) process. But, the flavor rewards are GREAT. Only check the food occasionally. The more you open the hood to peek, the longer it will take to cook. Each time you peek, add 10 minutes to the cooking time.
All of this, was sort of a thumbnail sketch of rotissering food. Search the web for recipes and techniques. You'll be amazed at what's out there.
Hope this helped you. Please let me know and Happy Grilling!!
Jun 22, 2011 | Brinkmann 5 Burner with Smoker 8101750S
I have all new burner element, starter and thermometer,,,because I had a MAJOR fire from deteriorating fire unit Now I used grill to rotisserie a chicken, cleaned everything and when using it to grill...
When you cooked the chicken on the rotisserie, did you remove the cooking grates and place a disposable drip pan on the flame tamers below the chicken? This will prevent the grease from dripping down into the bottom of the grill when you use the rotisserie. The bottom of the unit needs to be kept clean so the grease will run to the drip pan and not get caught in the bottom of the unit. When you are done cooking, if you will close the lid and turn the grill on high for 10 to 15 minutes it will help to burn off any grease build up and prevent fires in the future.
Jun 11, 2011 | Dynasty DBQ-30 (LP) Grill
Where can i get parts forit.I have lost my Rotisserie grilling skrewere that holds the chicken in the middle and helps to turn it round
You can find a universal Rotisserie Rod (spit) at just about any home center or hardware store that sells gas grills and accessories. Take your rotisserie motor with you, to make sure you get one that will snugly fit the coupling on the motor.
Good luck & Happy Grilling!!
Apr 24, 2011 | George Foreman GBQ100 Grill
I just bought this oven & my daughter lost the manual that goes with it. I need to know how to use the rotisserie feature. Also need to know if the rotisserie can be used for a roast. Thank you. =)
You might not want to use it again after your first experience. Make sure you get your food balanced as the motor on this thing is very weak. I cooked 2 chickens and a loin roast when I first got it and they were no better than pan roasted and a lot more trouble.
I have posted the complete manual (3 language edition) here:
http://216.92.50.93/Manual.pdf
Dec 30, 2010 | Hamilton Beach 31197 120 Watts Toaster...
Rotisserie
Are you sure that one wasn't supposed to be included? Blue Embers are premium products of Fiesta and may include the rotisserie. (At least the Blue Embers that HD sold had the rotiss in the box. I love it for BBQ chicken with the rear burner.)
Check with your retailer. If he didn't supply one, call Fiesta parts 1-800-396-3838.
Mar 27, 2010 | Fiesta Blue Ember Gas Grill
I have a baby george foreman rotisserie. I don't
Cook it until the interior temp is at 170 degrees F or more
Mar 08, 2010 | George Foreman GGR62 Grill
Re: george forman baby rotisserie manual
Here is a link to the DVO website with contact information. http://www.dvo.com/contact.html. Hope you have success they should be able to email you a manual.
Jan 09, 2009 | DVO Enterprises Cook'n Rotisserie Chicken...
George Foreman GR82 Logo
164 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Mike
Gerry Harvey
Gerry Harvey
Angel Joseph Jr.
Angel Joseph Jr.
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
