Question about Brother DCP-9040CN Laser Printer
Printing HBN3 & Smiley Face Every Time Turned On!
Every time my printer comes on line it automatically prints a page with HBN3 & a smiley face?
headstrong
  • 233 Answers
SOURCE: printing black shaded on complete page
I assume you mean the pages are coming out dirty or gary versus white and black text.
change the drum/cartridge, if you get the same results it could be the hi-voltage power supply. most common is the drum.
Posted on Jan 07, 2008
  • 215 Answers
SOURCE: Lines of copies utilizing automatic feeder
look to the side of your big glass and you'll see a piece of glass about 1.5" wide. thats the galss that is used for scanning from the feeder. theres got to be something on that glass. possibly white-out or even a small speck of toner can cause that. look closely.
hth,
razors
Posted on Mar 16, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Brother MFC-7820N Printer--vertical lines
You need to clean the scanner glass. Also known as the strip glass. It is a 1 inch wide strip of glass that runs from the front to the back. Your documents pass over this glass when they are scanned. Some of the wax crayon probably smeared off onto the glass and now when you scan the scanner sees these marks as stationary and thus records them as solid lines. Just look into the scanner section where your documents are fed in or depending on model, some are just to the left of the large original glass.
Good Luck and thank you for using Fixya.
Posted on Feb 25, 2010
  • 85 Answers
SOURCE: the printer keeps printing the same pages over and over again
Clear the memory in the printer. Try unplugging it for 2 mins.
Posted on Apr 19, 2010
  • 1684 Answers
SOURCE: Ghost printing
You have a worn image drum. The drum is the part of the printer that the print image is created on before it transfers the toner to the paper. This part is coated with a very thin layer of Teflon so the toner does not stick. When it gets worn the toner starts to stick and that produces the shadow or ghost image approximately 3 inches down the page because the diameter of the drum roller is 3 inches. You will need to get the part DR-350, Office Depot has them as well as many places on the internet.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
Posted on May 14, 2010
Testimonial: "I really appreciate the answer! I will go buy a new drum. Thanks again for your help! I appreciate it very much! "
How to stop smiley face and *** printing constantly
Clear the DRAM and SRAM memory. Doing so will remove all setting convert back to default setting. DOCUMENT
Feb 07, 2014 | Minolta QMS PagePro 9100 Laser Printer
Separator Sheets with smiley faces
Attempt to restore printer to factory defaults to cure this issue.
Sep 06, 2017 | Lexmark T644 Laser Printer
I turned emoji on..it downloaded, it's now on my keyboard. When I type a message the smiley face/symbol appears in my message. The recipient of my message is not seeing the smiley face.
This is because the recipient system is not supported with smiley. Recipient have to download the same or else have to make smiley ON.
Sincerly, Thiyaga
Aug 30, 2011 | Computers & Internet
Hello, I have problem with Printer Kyocera FS-1300.. when i connect it to pc, it starts to print some symbols, like smiley face on left corner of page, and i cant stop it, when i disconnnect my device...
Hi. I would suggest that you unplug the printer, reinstall software and check you computer for viruses. If i continues, try letting it print out. maybe someone set so that 30 pages with a smiley would be printed next time you plugged it in. I how this will fix you problem.
Jun 08, 2011 | Kyocera Fs-1300d Printer
It prints gibberish before the print job.
I have had this happen before, this could be you need to change the drum kit on the printer itself, check the indicator light.
Jul 28, 2009 | Dell 1720dn Laser Printer
HP 1300 randomly printing pages with tiny smiley faces and square
Try reinstalling your drivers. The computer may be confused with two different sets because of your second printer. If that doesn't work, and you have another computer available, hook the printer up to that one and install the drivers and see if the problem persists. If it does, then I really don't know what you can do, because that means the problem is in the printer's internal control and would be very hard to fix. If it doesn't persist on the second computer, then you know it's the first computer that's causing it. If nothing else works, try running a scan for viruses and spyware because they too could be interfering with your printer drivers. The computer actually does communicate with the printer even when you're not printing anything. It basically checks to make sure it's still there and waits for a response back with the printer status, etc. Some other program (whether wanted or unwanted) could be interfering.
Jan 09, 2009 | HP LaserJet 1300 Printer
I am having problems with my deskjet 930C printer. I have just inserted a new black ink cartridge 45A. The light keeps flashing, with the arrow over the colour cartridge smiley. When I replace the new...
Your printer might be having hardware problems. You can try removing and reinserting the printer cable. It might be loose due to the constant movement it does during printing. Also, inspect your cartridge. It is possible you have not removed the plastic covering the nozzle.
Sep 22, 2008 | Computers & Internet
Brother DCP-9040CN Laser Printer Logo
266 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
