Question about Panasonic PT LC75U Multimedia Projector
My ProShow Gold production on my ACER laptop (set
My ProShow Gold production (set up with aspect ratio 1024x768) on my ACER laptop (set to aspect ratio 1280x800) showed via a BENQ projector on to a screen with the images all showing narrower than they should. I had never had this problem with other projectors. How do I fix this?
I have asked a couple of gurus I know and they seem to think the solution is to set the laptop to aspect ratio 1024x768 to match the projector. Then change it back later. I am not in the position to test this unless it happens again with another projector somewhere else. What I wanted to know was how should they have set their projector. G.
Posted on Nov 19, 2009
How do I change the aspect ratio
Aspect ratio on what? Make model and OS of laptop please.
Oct 07, 2014 | Computers & Internet
What flatscreen monitor is OK to substitute for sanpo alphascan 520?
Hi. Almost all the crt type monitors should work, it's flat screen monitors that seem to give computers problems with aspect ratios, and resolution settings.
I personally use an NEC AccuSync 70.
It might not be the newest monitor in the world, but the colors are crisp, clear, and bright.
And It allows a setting of 1024x768@85 hz refresh rate, which works great for my games.
As far as flat screens, I would probably go with an Acer, or a Dell monitor, as these two companies seem to have better quality from their monitors than most other manufacturers.
I hope this helps you out!
Mar 06, 2011 | Sampo AlphaScan 520 (White) 15 in.CRT...
I cant connect my acer laptop 1640 to 3M DIGITAL PROJECTORS...
you need to check a couple of things. First on projector, check input settings it should be PC/computer etc. Then check aspect ratio settings on your PC to make sure it's compatible with projector.
Jan 07, 2011 | Acer Aspire 1640Z Notebook
Part no. for 15.4'' WXGA LCD to suite acer extensa 5630
hello
If your original LCD Screen Resolution is more than 1024x768, Please don't use this
this LCD is worth about $100
Brand: LG.PHILIPS
Part Number LP154WX2
Size 15.4-inch Screen (13.1"x8.2")
Resolution WXGA (1280x800)
Surface Matte
Aspect Ratio Standard
Backlight Type CCFL 1-Bulb
Backlight Connector 2 pins Backlight Connector
Video Signal Connector 30 pins Video Connector
hope i served you well
Nov 05, 2010 | Acer Extensa 5630-6806 Notebook
Can someone help me connect my Acer Aspire 3680?
Your graphics card on that should push that resolution so I would probably lean toward the tv. Try changing the aspect resolution or (zoom button) on the remote to change the way the screen is delivered. As long as the resolution on the laptop is a widescreen resolution and the same for the television. Make sure in your tv settings, that the aspect is set at 16:9.
Jan 12, 2010 | Acer Aspire 3680 PC Notebook
Everything on the screen appears stretched
If you can, set the Screen resolution to the maximum native resolution your monitor supports by adjusting the slider. to 1680x1050, if you can set it to that, then Windows will automatically display at the proper aspect ratio, and the monitor will not have to stretch anything. Setting your screen resolution to match your monitor's native resolution is, by far, the preferred solution to get you the best looking display.
If that specific resolution is not available, then you'll need to try resolutions that are smaller than that, but ideally with the same aspect ratio. 1512x945, for example, would maintain the same aspect ratio. Not all monitors handle running at less than their optimal resolution well, and it may result in a slightly fuzzy display, but it won't be horizontally stretched. If this fails to fix the problem it could be a problem with your video card
Jan 03, 2010 | Computers & Internet
ACER ASPIRE NOTEBOOK MODEL ASPIRE 4736ZG, IF I CHANGE RESOLUTION TO 1024X768 SCREEN SIZE BECOMES SMALL. HOW TO ADJUST VERTICAL AND HORIZONTAL SIZE SO WHOLE SCREEN CAN FILL IN.
i have acer 4736zg ;that i bought 4 months ago my computer gets heated and shuts down automatically; it works nicely for a week; and gets heated and shut down automatically 3 to 4 times in a day; i am using windows 7 and kapresky anti virus before my computer has windows vista and mcafee antivirus. yesterday my computer showed blue screen death for six times each time i connected net ; i checked the memory status and now its ok but it shutdown for three time in last 12 hours; can u plz help me out
Dec 16, 2009 | Acer Aspire 4720 Notebook
Icons and screen not sized properly-too big and out of proportion
Right click on your desktop
Click Properties
Click on the Settings Tab
It will say resolution with a sliding bar, you can move that around untill you find the right aspect ratio. Try 1024x768..
Hope that helps let me know :)
Jan 05, 2009 | Acer AL1916W 19" LCD Monitor
Aspect ratio
display setting
from the desk top right click and select properties, then select the settings tab then change your screen resolution display setting
Sep 16, 2007 | Acer AL2016W 20" LCD Monitor
Panasonic PT LC75U Multimedia Projector Logo
120 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
