Question about Sharper Image Hybrid GP (SI724) Air Purifier
Hybrid gp problem
Needs attention light comes on after cleaning.  Automatically switches to boost and stays there until the unit turns off by itself.  No lights.  Turns back on but does the same thing.
  • 3 Answers
You have to locate the "blade" that is causing a short (usually can see it sparking; if not, reset it (turn it off then on) in a dark room and locate the problem area (this is how I figured it out).  If you can locate the offending "blade", simply tear it out of the base where the spark is occurring, fold it back against itself so the metal does not contact anything other than itself (and is no longer contacting the base where the sparks occurred).
This fixed my unit (I was just about to throw it out when I tried this solution).
Posted on Aug 05, 2008
My unit keeps turning off, attention required red ligth is blinking, I just clean te unit
make sure not to forget cleaning the corona wires. i used light grade sandpaper and gently cleaned the wires as well as scrubbed the metal grids with scotch brite pads. the unit has been running normally .
Aug 01, 2010 | Sharper Image Hybrid GP (SI724) Air...
I have a Sharper Image GP Hybrid model 1724. I cleaned the pull out blades and the inside of the unit. When I turn it on, the needs attention light comes on almost immediately. How can I get the machine...
i found a solution to the sparking problem in the ionic breeze. purchased scotch brite cleaning pads from home depot. using a long strip of pad scrub the plates back and forth especially in the areas that seem to be emitting sparks. i did this and the unit runs quiet as a whisper.
Jul 05, 2010 | Sharper Image Hybrid GP (SI724) Air...
Hybrid GP won't turn on. Tried different outlets. There is a green light thats hidden in the bottom of the unit that does stay on. I push the power button and the unit does not turn on.
The front and rear plastic grills of the Hybrid GP trigger a power cut-off safety mechanism if either of the grills is not entirely in place. The grills have a tendency to slide down ever so slightly if bumped. The tiniest amount of slippage is enough to engage the power cut-off and it's not generally noticeable unless you know what to look for. If the Hybrid GP has no power at all, you may need to slide one or both of the grills upward just a hair. You should hear and feel a slight click when the grills are properly locked into place.
Feb 28, 2010 | Sharper Image Hybrid GP (SI724) Air...
Sharper Image Hybrid GP. Unit powers on, goes to
The solution drgoff provided ( the guy that used to work for Sharper Image ) actually did the trick !!!! Super excited to have this unit working again , thanks drgoff
Jul 07, 2009 | Sharper Image Hybrid GP (SI724) Air...
I purchased a Hybrid GP germicidal Air Purifier, Model # S1724 ((Electric Air Cleaner AC110v 20w 50/60Hz)). My unit is severly malfunctioning and i nee to either send it in for repair or be given detailed...
Locate the photo electric eye that picks up the need to clean and give it a thorought cleaning. Good Luck and I hope you get it repaired. That photo cell should be your problem It's probably a little black or ruby red dot in a fin or on the housing where yhe air passes.
Jul 06, 2009 | Sharper Image Hybrid GP (SI724) Air...
Gp sharper image hissing problem
1. Unplug the unit
2. Turn the unit upside down and listen for the beeds to move along the static wires from top to bottom. Turn it upside down again and again until you feel the static wires are cleaned of grime.
3. Plug it in again and see if the hissing is gone.
Jun 06, 2009 | Sharper Image Hybrid GP (SI724) Air...
RED LIGHTS COME ON AFTER I CLEANED THE GRIDS
hi.....
u wud have to take a pair of needle-nose pliers and rip out the metal blade at the bottom where the spark is occurring and fold it back against itself so that it is no longer "seated" into the bottom of the unit where the sparking is occurring
take care to bend the parts back in line with the blade so that lined up and could be removed and replaced into the unit without scraping anything. When u put it back in, there ll be one last "spark" or probably a couple...... and after that i shud work just fine......
thank youhave a nice day good luck
Jun 02, 2009 | Sharper Image Hybrid GP (SI724) Air...
My Sharper Image ionizer after I cleaned the grid now makes popping noises and then the red light that says drying grid comes on most of the time. Sometimes the light that says attention required comes...
You are probably aware that the ionizer uses a very high voltage (at very low current) to function. If you have used a cleaner of some kind on it, you could have made the grid sensitive to moisture.
I would remove the grid again and wash it thoroughly in distilled water to remove any residue that stayed behind, then dry it in warm air before reinstalling it.
Oct 10, 2008 | Sharper Image Hybrid GP (SI724) Air...
Red Cleaning Light won't turn off
After cleaning the unit, replace the grid into the unit. Hold upside down for at least 30 seconds to reset.
Jul 19, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Sharper Image Hybrid GP  (SI724) Air Purifier Logo
239 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
