There Is problem with Bad sector or Operating System corrupt in your Hard Drive.So pls Repair the Operating system by OS CD ,if issue still not resolved then Pls Replace the RAM chip with another goods one .If still issue not resolved then Hard disk need to Zero filling.Its better to call vendor for the same.
Deleting cookies:
1. Click the Start button.
2. In the Start search (or Search for programs and files) field type in "shell:cookies" without the " ".
3. Click Ok or press Enter on your keyboard.
4. A new window will open and will give a list of text document files.
5. Delete all the files in the folder excluding the "index.dat" file by selecting all of them then press
the keys "SHIFT - DEL (Delete)" on your keyboard to delete the files permanently.
6. Close the window after you have deleted all the text document files.
Deleting temporary internet files:
2. In the Start earch (or Search for programs and files) field type in "%temp%" without the " ".
4. A new window will open and will give a list of files.
5. Delete as many files as you can in the folder by selecting all of them then press
6. If there will some items that cannot be deleted, that's alright, you can SKIP deleting them.
7. Close the window after you have deleted most of the files if not all.
Disk Clean-up:
1. Click on Start, and then click My Computer or Computer.
2. Right click on Local Disk (C:) or OS (C:) and click Properties.
3. Click on Disk Cleanup.
4. When another window appears, put a check on all the boxes then click OK.
5. Wait until the cleanup is finished then close the window.
Run a full system scan using your Antivirus program.
Please answer the question below:
1. Are you using bittorrent or other peer to peer sharing of files application?
Hi
there wickedninjao
What
to do when your Xbox Has problems with reading disks and you have
tried cleaning the disk.
This
does not mean your Disk Drive needs replacing more often than not it
just needs the laser to be readjusted.
Option
You
can send this off to Microsoft if your still in warranty because it
is included in there free fixes so they will do the collecting for
you, fix it and return the Xbox to you, all for free, but it will
take 4-6 weeks.
Option
If
you are out of warranty its the same process as above but its $130 in
cost
Option
now
a new Disk drive would cost around $75 for a compatible one and you
may need some one to fit it at a cost as well.
Option
What
I recommend is a Xbox
Repair Guide that will show you the simple steps yourself, you
will be up and running again in less than an hour and the cost is far
less than option 2 & 3
Good
Luck
John
Faulkner
Feel Free to leave me a comment if you need further assistance.
